Find Thevenin Voltage & Current Across R2: Tricks & Tips Included
  • Thread starter Thread starter phyznut
    Thevenin Voltage
To find the Thevenin voltage (Vth) and current across R2, the circuit can be simplified by removing R2, transforming it into a series configuration. The Thevenin resistance (Rth) has been calculated as approximately 2.9 ohms, using the formula (R1 + R4)||(R3 + R5). With R2 removed, the current through R1 is the same as that through R3 and R5, allowing the use of the voltage divider formula to find Vab. The voltage across points A and B is the combined voltage drop across R3 and R5. Understanding this series configuration is crucial for accurately determining Vth.
phyznut
I'm trying to find the current and voltage across R2 using thenenin.
http://img209.imageshack.us/img209/4606/thv15ph.png
I've managed to find Rth, which is equal to (R1 + R4)||(R3 + R5). That comes out to about 2.9 ohms. I need help with finding the Vth (Vab) though.
http://img208.imageshack.us/img208/5002/thv28nc.png
Can someone please help me. What are the tricks involved here?
Your second picture IS the trick ... with I_2 = 0, what is V_ab ?
That is, with I_2 = 0 , all the current thru R_1 goes thru R_3 , R_4 , and R_5 .
Ok then so with R2 removed, the circuit is now series. That makes the current the same for the remaining resistors.
So if I_2 is 0, then the voltage between that point is also zero? That doesn't seem right though. I still don't get it, please give me another hint.
Can no one help.
Would I have to use the voltage divider? How do i use it?
Yes you could use the voltage divider formula. With R2 removed, you can think of V_{AB} as the voltage drops across R_3 and R_5
Look at it in this way. When you remove R_2, the circuit now becomes a series circuit. Look at where point A and B are. If you where to take a voltmeter and put the probes across points A and B. Your voltmeter would be giving you to combined voltage of R3 and R5.
