Calculate Torque Balance to Find the Angle of a String
To find the angle of the string using the torque balance equation, the equation Wga = mgbsin(angle) is suggested. The correct approach involves using the inverse sine function to isolate the angle, specifically sin^-1(Wa/mb). There were initial errors in calculations, but after adjustments, a value of 56 degrees was obtained. Additionally, for the predicted values of P_x and P_y, it is suggested that both would be zero since there is no torque acting on the system. Understanding these calculations is crucial for accurately determining the angle and forces involved.
just.karl
<a href="http://www.flickr.com/photos/just-karl/2407404197/" title="IMG_8600 by Karl W., on Flickr"><img src="http://farm3.static.flickr.com/2206/2407404197_18ab7a3497.jpg" width="500" height="317" alt="IMG_8600" /></a>
I have to find at what the angle of the string is using the torque balance equation.
W= 167.4grams
a= 49cm
b= 98cm
m= 100grams
The angle is 51 degrees based on the measurements during the lab, but I have to figure out how to do it using the torque balance equation.
What my guess is for the equation is Wga = mgbsin(angle
Am I going in somewhat of the right direction? Also how would I get the angle by it's self. Or how do you move sin if I do at all?
Thanks.
sorry, I didn't put the diagram in right.
yes, you are correct, now just solve for the angle. You need to use the inverse sinus function.
When I punch it into my calculator I get error in the domain. It'd be sin^-1(Wa/mb correct?
yes, and it works fine for me and i get 56 degrees. try again.
if I calculate wa/mb then do sin_-1 it works out. Thanks
I have another question with this same diagram. "What are the predicted values of P_x and P_y?" Would it just be zero for both of them since there is no torque on it?
