Toy Gyroscope Problem: Finding Angular Speed and Upward Force | Homework Help
  • Thread starter Thread starter EvanQ
    Gyroscope
The discussion revolves around solving a physics problem involving a toy gyroscope, specifically finding the upward force exerted by the pivot and the angular speed of the rotor. Key equations include angular momentum and the relationship between torque and angular velocity. The upward force is determined to be equal to the total weight of the gyroscope, while the angular speed was initially miscalculated due to a conversion error from radians per second to revolutions per minute. Participants shared their struggles with the problem and emphasized the importance of correctly applying formulas and unit conversions. The conversation highlights common challenges in understanding rotational dynamics in physics.
EvanQ
The rotor (flywheel) of a toy gyroscope has mass 0.140 kilograms. Its moment of inertia about its axis is 1.20x10^{-4} kilogram meters squared. The mass of the frame is 0.0250 kilograms. The gyroscope is supported on a single pivot with its center of mass a horizontal distance 4.00 centimeters from the pivot. The gyroscope is precessing in a horizontal plane at the rate of one revolution in 2.20 seconds.
Find the upward force exerted by the pivot.
Find the angular speed omega at which the rotor is spinning about its axis, expressed in revolutions per minute.
angular momentum and acceleration equations eg:
w = O / t
w= w0 + at
O = w0t + ½ at^2
w^2 = w0^2 + 2aO
having a lot of trouble determining what information is relevant in this question...very little idea how to go about it sorry.
i think it has to do with L = Iw, with I being 1.2x10^4, but I'm unsure of how to get the angular velocity, and after that the force they are asking for.
PCB250??
bahahaha
now guess why I am here...
You will have to change (Big Omega) O from rev/2.2s into rad/s : O = 2pi/2.2s = 2.856 rad/s.
The upward force is equal to the weight because the gyroscope is not moving sideways, up or down so Fx = 0, and Fy = 0. Hence n = w = (m_rotor + m_frame)*9.8.
We know that O = T/L (where Torque: T = radius * w and L = I * w (small omega))
I is given with 1.2E^-4 kg*m^2.
There's an equation that tells you that L = I*w here so you just have to find the L from the equations above and then isolate w(small omega) from L = I * w(small omega).
then you'll get some number but you will have to answer in rev/min and remember that O is given in rev/2.2s but you changed it to 2.856rad/s
I have to admit that I'm in trouble finding the answer in rev/min if somebody could point out the right way to do so.
well evanQ, guess who had two attempts left when doing that. then i got the right answer! but it wasnt it revolutions per minute. so i had to convert it...and i MULTIPLIED BY 60 INSTEAD OF DIVIDED! ahhh! soooooo annoyed.
anywho, that's all in the past...now there another one to worry about. where we get marks taken off for getting multichoice wrong, nooooooo
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
