Two blocks and pulley systemhelp on small part
The discussion revolves around a physics problem involving two blocks and a pulley system, focusing on calculating the acceleration of a falling mass and the tensions in the strings. Participants analyze the forces acting on each mass and the torque on the pulley, with particular attention to the correct application of equations. A key point of confusion is the sign convention used in the equations, which affects the calculated acceleration. After receiving advice on maintaining consistent sign conventions, one participant successfully resolves the issue and finds the correct answer. The conversation highlights the importance of clear communication and understanding of physics principles in problem-solving.
Juntao
You got to see the picture 1st.
A block of mass m1 = 2 kg rests on a table with which it has a coefficient of friction µ = 0.66. A string attached to the block passes over a pulley to a block of mass m3 = 4 kg. The pulley is a uniform disk of mass m2 = 0.5 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
a) With what acceleration does the mass m3 fall?
b) What is the tension in the horizontal string, T1?
c) What is the tension in the vertical string, T3?
Okay, shouldn't be that HARD of a problem. But this is what I've done so far.
mass 1 (right is positive)
Summation of forces in x direction
T1-u*m1*g=m1a
Summation of forces in y direction
N-m1g=0
N=m1g
mass 3 (up is positive)
T3-m3*g=m3*a
My biggest question is the following equation correct:
mass 2
(T1-T3)R=I*alpha
simplifies to
(T1-T3)R=.5*m2*R^2*(a/R)
or
(T1-T3)=.5*m2*a => is this right for mass 2 for net torque
From here I manipulated the equations until I got a=...
This is what I have so far, but I'm not getting the acceleration value right, unless I made an algebra error.
But the equations look right so far, right?
It looks like you've got your torque acting in the wrong direction. Try
\tau_{net}=T_3r-T_1r
as your torque formula instead.
Ok, I did what NateTG said, and it gave me a different accerlation of -15.008 m/sec^2 for m3. But its not the right answer. Was there something else I'm supposed to do?
To avoid premature insanity, pick a consistent set of sign conventions. You know that m1 moves to the right, the pulley moves clockwise, and m3 goes down. So... use those directions as the positive direction in all your equations.
The way you currently wrote your equations, what you call "a" in one equation equals "-a" in another. Yikes!
Thanks for the tip DocAl! I figured out the answer. Yes!
I learn something new everytime I post here. :smile:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
