Two problems gettin on my nerve
  • Thread starter Thread starter O.J.
The discussion revolves around two physics problems related to electric fields generated by charged rods. In the first problem, participants are trying to derive the electric field at a point perpendicular to a uniformly charged rod, confirming that the x-component is zero and focusing on the integration process to find the y-component. The second problem involves calculating the electric field at the origin due to a line of charge, with users expressing confusion about the direction and the integration required to find the y-component. Participants emphasize the importance of setting up the integral correctly and utilizing trigonometric relationships to simplify calculations. Overall, the conversation highlights the challenges of integrating to find electric fields and the need for clear mathematical procedures.
O.J.
4. A thin rod of length ℓ and uniform charge per unit length λ lies along the x axis, as shown in the Figure. (a) Show that the electric field at P, a distance y from the rod along its perpendicular bisector, has no x component and is given by E = 2ke λ sin θ0/y. (b) What If? Using your result to part (a), show that the field of a rod of infinite length is E = 2ke λ /y. (Suggestion: First calculate the field at P due to an element of length dx, which has a charge λ dx. Then change variables from x to θ, using the relationships x = y tan θ and dx = y sec2 θ dθ , and integrate over θ.)
for this problem, I am not gettin how u arrive at the E field. (ie part a)
the other problem:
7. A line of charge with uniform density 35.0 nC/m lies along the line y = 15.0 cm, between the points with coordinates x = 0 and x = 40.0 cm. Find the electric field it creates at the origin.
i get the value but not the irection of the E field.
can u please help me out
PF requires that you show some work before we help you--sorry!
Now for your other problem, you can perform a vector summation pretty easily. just sum it up like Ex=int((Kdq/distance^2)sin@) where @ is the angle between the line x=0 and the line from the origin to the charge dq. find a way to sum this from one side of the bar to the other. Then get your y-component and then you should have no problem getting your direction.
I proved that E has no x component but i can't find the y component . can some1 show me a procedure (specially help withg the integration part)
as for ur suggestion for the other problem. i don't think I am familiar with the kind of math ur using... it loox weird
Once again, what have you DONE to set up the integral. Show us what you have tried.
ooo ok (i will denote lambda by @
dq = @ dx
dE = k @ dx / r^2 = k @ dx /(x^2+y^2)
E = int (k @ dx / (x^2 + y^2)) from -.5L to .5 L
i can't integrate it and i can't find the y component
too
pls also help me out for the other problem. i get the general notion of it already, but its the math where i go wrong. show me the INTEGRATIOn
Have you tried the substitution given in the hint in the question?
Hello all! I'm trying to work on this problem as well but I'm a bit lost.
So far, I know that the Ex component will cancel, so only Ey will remain.
Then I know that dq = lamda dx.
I'm defining theta as the angle adjacent to y, so cos(ᶿ)= y / [√(L/2)^2 + (y)^2], where [√(L/2)^2 + y^2] = r.
and I know that dE = (kdq) / r^2
Substituting that into the equation for dE gets me:
dE = k (lamda dx) / (r)^2 * (y / r)
From here we can take an integral to get E, so:
E = k(lamda)y ∫ dx / ((L/2)^2 + (y)^2)^1.5
E = k(lamda)y (L/2) / y √((L/2)^2 + y^2)
E = k(lamda)L / 2y√((L/2)^2 + y^2), integrating from L to 0?
I'm actually not sure if integrating from L to 0 is correct... when I tried it I got
(k(lamda)L) / (2√((L^2/4) + L^2) - k(lamda)
which does not resemble the final answer, E = 2k*lamda / y
Any guidance at all would be most appreciated. Thanks!
