Vector Cross Product Homework: Solving AxB with B values of 8i+16j and -8i-16j
The cross product of vectors A = 2i + 4j and B = 8i + 16j results in zero, as both vectors are parallel, indicating they are scalar multiples of the same unit vector. Similarly, the cross product of A and B = -8i - 16j also yields zero for the same reason. The discussion emphasizes that the relationship between A and B allows for this conclusion without detailed computation. The key takeaway is that parallel vectors produce a cross product of zero. Understanding vector directionality is crucial in determining the outcome of the cross product.
noeinstein
Given that A = 2i + 4j, evaluate each of the following. (Hint: This question can be answered without computation.)
(a) What is AxB when B = 8i + 16j?
(b) What is AxB when B = -8i - 16j?
AxB=(Axi + Ayj) x (Bxi +Byj)
=(AxBx)(i x i) + (AxBy)(i x j) + (AyBx)(j x i) + (AyBy)(j x j)
AxB=(AxBy - AyBx)k
AxB= (2 x 16)k - (4 x 8)k= 0k
Indeed.
Can you see the relation between A and B that makes the zero result trivial, i.e you can solve it "without" computation?
They have the same/opposite direction?
Geeze no kidding! dahh. Thanks
Indeed.
The vectors involved are parallell. Therefore, their cross product must be 0.
Try parallel or colinear. They are scalar multiples of the same unit vector.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
