How Does Water Flow Rate Change Over Time in a Draining Cylinder?
The discussion revolves around calculating how the flow rate of water changes over time as it drains from a cylinder. The cylinder has a height of 5.5 meters and a radius of 1 meter, with a hole located 0.5 meters from the bottom. The user seeks to determine the flow rate and its rate of change concerning time, specifically as the water height decreases. The equations mentioned involve the relationship between the volume of water, flow rate, and the height of the fluid. The user requests assistance in solving these equations to find the derivatives of flow rate and height over time.
unsung-hero
Ok, so the height of the cylinder is 5.5 meters. The radius is 1 meters.
There is a hole, .5 meters from the bottom(5 meters from the top), its radius is .02 meters.
The question is how fast does water flow out, relative to time(this because the height of the water keeps dropping, so the flow rate decreases). [/B]
Thank You :)
Am i doing it right?
If i am, can you please solve it(i can't quiet figure it out)?
Please give the rate of change of the flowrate(dflowrate/dt).
Also, rate of change of height(dh/dt).
[/B]
Height = total volume - (integral sign) flowrate dt
flowrate = (cross sectional area * Velocity(
) * density
dflowrate/dt = (deritive of the expression above)[/B]
Suppose that h(t) is the height of the fluid level in the cylinder at time t, and R is the radius of the cylinder. What is the volume of fluid in the cylinder V(t) at time t?
Chet
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
