Water pressure and gravity in a storage cylinder
The discussion focuses on calculating the pressure exerted on the floor of a storage cylinder filled with water. The cylinder dimensions are specified as 6 inches in diameter and 10 feet high. The pressure is determined by dividing the weight of the water by the cross-sectional area of the cylinder. This method provides a clear and accurate calculation of the pressure at the base of the cylinder.
  • Understanding of basic physics principles, specifically fluid mechanics.
  • Knowledge of pressure calculation formulas, including the relationship between weight and area.
  • Familiarity with units of measurement, particularly converting between inches and feet.
  • Ability to perform basic arithmetic operations involving weight and area.
  • Research the formula for calculating pressure in fluids, specifically using the equation P = F/A.
  • Learn about the properties of water, including density and weight per volume.
  • Explore the concept of hydrostatic pressure and its applications in engineering.
  • Investigate the effects of varying cylinder dimensions on pressure calculations.
This discussion is beneficial for physics students, engineers, and anyone interested in fluid dynamics and pressure calculations in cylindrical containers.
el-chupacabra
Say you have a cylinder.
The cylinder is 6 inches in diameter and 10 feet high.
The cylinder has a floor at the bottom and is open at the top.
The cylinder is full of water. How much pressure is exerted on the floor of the cylinder?
Is it simply the weight of the water in the cylinder? How would you calculate?
Welcome to PF!
It is the weight of the water divided by the cross sectional area.
excellent thank you
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 32 ·
14K
  • · Replies 16 ·
