What am I doing wrong in calculating the charge on each capacitor in a circuit?
The discussion focuses on calculating the charge on capacitors in a circuit with each capacitor rated at 5 μF and a voltage of Vab = 30 V. The user initially calculated the equivalent capacitance to be 3 μF and the total charge to be 9 × 10-5 C. The error arose from misunderstanding charge distribution in series connections; specifically, the total charge remains constant across capacitors in series, rather than being divided. The correct approach emphasizes that charge does not cross the capacitor break, and all charge from the battery is effectively stored on the first capacitor in the series.
  • Understanding of capacitor basics, including capacitance and charge relationships.
  • Familiarity with series and parallel capacitor configurations.
  • Knowledge of the formula C = Q/V for calculating charge.
  • Basic circuit theory, particularly the behavior of current in capacitors.
  • Study the principles of charge distribution in series and parallel capacitor circuits.
  • Learn about the effects of voltage and capacitance on charge storage in capacitors.
  • Explore practical applications of capacitors in electronic circuits.
  • Investigate advanced topics such as transient response in RC circuits.
Students studying electrical engineering, electronics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
Baou
Each capacitor is [tex]5 \mu F[/tex] and [tex]V_{ab} = 30 V[/tex]. I'm trying to find out the charge on each capacitor.
[tex]C = \frac QV[/tex]
[tex]C_{eq} = C_1 + C_2 +...[/tex] for capacitors in parallel.
[tex]C_{eq} = \frac{1}{\frac{1}{C_1}+\frac{1}{C_2}+...}[/tex] for capacitors in series.
The first thing I did was calculate the equivalent capacitance for the entire circuit to be 3 microfarads. From here I calculate the total amount of charge to be 9*10^-5 C. Then I consider the circuit with just [tex]C_4[/tex] and the equivalent capacitance of capacitors 1-3. It's just two capacitors in series, and charge should be equally distributed between capacitors in series, right? So I get [tex]C_4 = 4.5 * 10^{-5} C[/tex], but this is incorrect. What am I doing wrong?
Both capacitors in series would have the 9 and not the 4.5. To understand this realize that a capacitor is a break in the circuit. Current (and therefore charge) do not cross over that break. Instead, one plate has charge moving onto it while the other plate has charge moving off of it. The result is each plate gains a charge equal in magnitude and opposite in sign while current flows in the circuit. It is easy to forget after seeing current that no current actually flows through the capacitor.
In the series connection, the total charge drawn from the battery to the capacitor c(1234) must therefore rest on the first plate it comes in contact with. We have C(123) and C(4). Using this logic -- since again there is a break in the circuit -- all of the charge stores from the applied voltage must be on C(123). Where then, you may ask, does C(4) get its charge? I point finger to the C(123)'s bottom plate whose charge leaves it and therefore heads toward C(4)'s top plate. Then, C(4)'s top plate accepts that charge -- which is equal to the charge on C(123)'s top & bottom plate(read: that is, the total charge of 9). Then, C(4)'s bottom plate has charge leave it, creating current until eventually it too has 9.
Remember, for plates that are parallel, charge is shared by them.
Okay, that makes sense. Thanks for the explanation; I managed to figure out the rest with your help.
  • · Replies 16 ·
