What Is the Acceleration of the Metal Bar After Closing the Switch?
The discussion revolves around calculating the acceleration of a metal bar in a magnetic field after closing a switch in a circuit. The bar has a weight of 2.60 N and a resistance of 10.0 ohms, and it is subjected to a 1.60-T magnetic field. The initial calculations included finding the equivalent resistance and current, leading to an incorrect acceleration value of 8.29 m/s². Key points of confusion included the treatment of gravitational force and the orientation of the magnetic field, which was vertical rather than horizontal. Ultimately, the correct approach involves using the weight to find mass and applying the appropriate forces in the F = ma equation.
kimberlyann9
A 2.60-N metal bar, 1.50 m long and having a resistance of 10.0 ohms, rests horizontally on conducting wires connecting it to the circuit shown in the figure . The bar is in a uniform, horizontal, 1.60-T magnetic field and is not attached to the wires in the circuit.
What is the acceleration of the bar just after the switch S is closed?
http://session.masteringphysics.com/problemAsset/1266176/3/27.74.jpg
V=IR
Fbar=ILB
Fgravity=mg
Rseries=sum of R
Rparallel=(1/R)^-1
I found the resistance of the parallel resistors(the bar and the 10ohm resistor) to be 5ohms
Then the Req=5ohms+25ohms=30ohms
Use that and the given voltage to find I.
I=4A
Use I to find Voltage of the bar.
V=20V
And then we can find I using the voltage(20V) and resistance of bar.
I=2A
F=Fbar-Fgravity
ma=ILB-mg
I get a=8.29 m*s^-2 but Mastering Physics says it's wrong. Where have I gone wrong?
Hi kimberlyann9, Welcome to Physics Forums.
V=IR
Fbar=ILB
Fgravity=mg
Rseries=sum of R
Rparallel=(1/R)^-1
I=4A
V=20V
I=2A
F=Fbar-Fgravity
Question: Why do you subtract the force due to gravity here? The bar is resting horizontally on the wire "rails", so it's supported. What is the direction of the force on the bar due to the magnetic field?
ma=ILB-mg
The diagram shows a VERTICAL magnetic field, not a horizontal field. This could be why you think you need to subtract mg.
Also did you notice the WEIGHT of the bar (2.60N) is given, you will need mass to use in the F =ma equation
Thanks guys I figured it out.
