What Is the Angle of Refraction for a Light Ray Incident on Glass at 30 Degrees?
The discussion centers on calculating the angle of refraction for a light ray incident on glass at 30 degrees. The index of refraction for glass is given as 1.47, and it is assumed that the light is transitioning from air, which has an index of refraction of approximately 1.00. The relevant equation used is n1 sin θ1 = n2 sin θ2, where θ1 is the incident angle and θ2 is the angle of refraction. There is some uncertainty regarding whether the angle is measured with respect to the perpendicular, which could affect the calculation. Clarification on the reference point for the angle would enhance understanding of the problem.
o0sunny0o
Refraction -- A light ray is incedent on a block of glass at an angle of 30 degrees
A light ray is incedent on a block of glass at an angle of 30 degrees,what is the angle of refraction.
Given: glass: 1.47
incident angle:30°
π1 sin θ1 = π2 sin θ2
I did: (1.47) sin (30)= π2 sin θ2
But I don't think this is the answer. I'm helping a friend but the problem don't say what the other medium is...
Hello o0sunny0o,
Welcome to Physics Forums!
Given: glass: 1.47
incident angle:30°
I'm guessing that the original medium is air. The second medium is glass.
I'll also assume that the 30o angle is measured with respect to the perpendicular*, and measured outside the glass (i.e. in the air). If so, treat your
n1 sinθ1 = n2 sinθ2
formula as
(Index of refraction of air)(sine of angle in air) = (index of refraction of glass)(sine of angle in glass)​
*The problem statement is is vague about what the angle is in reference to; perpendicular or parallel. I'm assuming it's in reference to the perpendicular, but that's just my assumption. I don't know for sure. A figure would certainly clear things up.
thank you for the answer^^
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
