What is the magnitude of the electric field
The discussion revolves around calculating the magnitude of the electric field generated by a cat with a charge of -54.1 µC at a distance of 4.01 m. The correct formula to use is E = kQ/r², where k is the Coulomb's constant. Initial calculations led to confusion, with incorrect values being entered, resulting in an erroneous electric field strength of 2.86E4 N/C. After correcting the input errors, the participant successfully recalculated the electric field. The conversation highlights the importance of careful data entry in physics calculations.
shimizua
A cat rubs her back on the carpet, and acquires a net charge of -54.1 uC. What is the magnitude of the electric field at a distance 4.01 m from the cat?
and
What would the magnitude of the electric field in the previous problem be,
if the distance from the cat were now tripled?
F=kq/r^2
F=8.9E9(54.1E-6)/4.01^2
my answer came to 2.86E4 N/C which is wrong.
obviously i should be able to get the second part once i understand what i am doing wrong in the first part
You have calculated the force due to the electric field, not the field itself.
I believe the eq you are looking for is:
<br /> E=\frac{Q}{4\pi\epsilon_0r^{2}}<br />
it shouldn't :redface: … did you enter 8.5 instead of 8.9?
(and isn't it 8.988, or just 9.0, anyway?)
k so i did
E=54.1E-6/4*3.14*8.85E-12*4.01^2 and got 2.7E4 N/C which still was wrong. what else did i do wrong?
Never mind I got it. i was using the right equation, lol i guess i did just enter a number in wrong. funny cause i did it like 10 times. thanks though tiny-tim
