What Is the Maximum Speed to Keep the Flywheel's Wheels on Track?
The discussion centers on calculating the maximum speed at which a flywheel system can navigate a curve without lifting off the track. Key parameters include a flywheel mass of 42.7 kg, an axle length of 1.65 m, and a curve radius of 15.9 m. Participants emphasize the need to apply relevant equations of motion, including those for linear, rotational, and circular dynamics, while also considering the relationship between angular momentum and torque. A hint suggests that the change in angular momentum while navigating the curve must equal the maximum torque provided by the flywheel's weight. Ultimately, the problem was resolved with the assistance of a teacher who derived the necessary equations.
Kmaster
A flywheel of mass 42.7 kg is supported by an axle 1.65 m long, with two small wheels. The axle's wheels roll on an elevated track, part of which has a curve of radius, R = 15.9 m. If the flywheel has angular momentum 75.50 kg·m2/s, what is the maximum speed at which the system can take the curve without a wheel lifting from the track?
Any help with solving this problem would be greatly appreciated. thanks.
You need to show us your work in order for us to help you (PF rules). That's why there is a Homework Posting Template for all new threads here in the homework forums. Please show us your work on #2 and #3, and we'll try to help guide you to figuring out the solution.
I think we are supposed to assume that the radius of the wheels is negligible compared to the radius of the flywheel, but it does not give us either.
If you do as Berkeman suggests and state your approach to this, we will have a better idea of how to help you.
AM
Thank you for the directions. Sorry I didn't read the posting rules.
Equations:
Linear: F=ma p=mv
Rotational τ=I*α L= I*ω
cicrular: a=v^2/R
The way the drawing is set up, the wheels are much smaller than the fly wheel. also, the outer radius (where one of the wheels is)= R+1/2axle= 1.9+1.65/2=2.725m and the inner radius =R-1/2axle=1.075m
I tried to combine the equations using force=torque. mv^2/R=Iα And solved I=mv^2/R/α =L/ω After that I said the distance traveled around the curve/v=time=ω/α. The I got stuck and I'm fairly certain the process doesn't really go anywhere.
The hint provided is:The rate at which the angular momentum must change going around the curve equals the maximum net torque which the weight of the flywheel can provide.
Thank you for any help.
Equations:
Linear: F=ma p=mv
cicrular: a=v^2/R
Another useful equation is:
\vec{\tau} = \frac{d\vec{L}}{dt}
You have two mutually perpendicular angular momenta - one provided by the flywheel and the other provided by the flywheel/cart going around the track. The angular momentum of the flywheel is pointing in the radial direction so it keeps changing. What is the direction of the change of the angular momentum of the flywheel in a small time interval dt? (what is the direction of the angular momentum at time t and the direction at the time t+dt? what is the difference?) That is the direction of the torque vector. What is the magnitude of that torque vector? What torque is opposing it? When are the two torques equal?
AM
Thank you very much. My teacher derived some equation and the problem was solved.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
