What is the Path of a Cricket Ball During a Bowler's Run Up?
  • Thread starter Thread starter eejpama
    Ball Path
The discussion focuses on modeling the path of a cricket ball during a bowler's run-up and the physics involved in its trajectory. Participants emphasize the importance of understanding that a bowler does not "throw" the ball but bowls it with a straight arm, which is crucial for accurately modeling its motion. The conversation explores the effects of bouncing on the ground, noting that the ball's velocity just after the bounce is not zero but changes direction. Suggestions include modeling the impact as either an elastic or inelastic collision to better understand the ball's behavior upon bouncing. Overall, the thread provides insights into the physics of cricket ball dynamics during a bowler's delivery.
eejpama
model the run up a bowler takes before he throws the cricket ball
model the path of the cricket ball
we can make any assumption. if anyone good in physics please helo me model it.
If this is homework you should have a go yourself first.
PS: He doesn't just "throw" the cricket ball (that would be an illegal delivery) he bowls it with a straight arm. I'm not just being picky. This might help you answer the question.
i have done some work and equations. but when balls hits the ground i don't understand how to work it out because bounce on ground before it rise again to touch the bat. at that moment i want to know the initial velcity whether it is zero or not? just confused
No not zero velocity. If it bounces the [STRIKE]velocity[/STRIKE] speed just after the bounce won't be very different to that just before the bounce. Just the direction changes.
You could model the impact with the ground as an elastic collision or an inelastic collision or perhaps just assume the speed doesn't change. Although obviously the direction does (up rather than down).
http://en.wikipedia.org/wiki/Elastic_collision
"An elastic collision is an encounter between two bodies in which the total kinetic energy of the two bodies after the encounter is equal to their total kinetic energy before the encounter" (eg none lost to heat, sound etc)
http://en.wikipedia.org/wiki/Inelastic_collision
"Inelastic collisions may not conserve kinetic energy, but they do obey conservation of momentum"
thank u that is really helpfull.
