What Is the Speed of the Block at the Bottom of the Ramp?
  • Thread starter Thread starter pugola12
    Ramp Velocity
The discussion focuses on calculating the speed of an 11kg block at the bottom of a frictionless ramp inclined at 30°. The user attempted two methods: kinematics and conservation of energy, both yielding the same incorrect speed of 21.598 m/s. Feedback from other participants pointed out errors in the calculations, specifically that the acceleration should be calculated using 9.8*sin(30°) instead of 9.8/sin(30°). Additionally, there was confusion regarding the height calculation, which should involve multiplying by sin(30°) rather than dividing. Clarifications emphasized the importance of understanding the relationship between forces on an incline and the correct application of trigonometric functions.
pugola12
Starting from rest an 11kg block slides 11.9m down a frictionless ramp (inclined at 30° from the floor) to the bottom. The block then slides an additional 26.3m along the floor before coming to a stop. The acceleration of gravity is 9.8 m/s^2. Find the speed of the block at the bottom of the ramp.
Vf^2=vi^2+2a(d-do)
Conservation of energy: Ebefore=Eafter
KE=.5mv^2
PE=mgh
I tried solving this two different ways, and both gave me the same answer, which was wrong. First I tried kinematics.
Vf^2=vi^2+2a(d-do)
Vf=sqrt(2*9.8/sin30*11.9)
(I used 9.8/sin30 because 9.8 is the vertical component, so 9.8/sin30 is the acceleration down the ramp)
Vf=21.598
The other way I tried used conservation of energy.
h=11.9/sin30=23.8
PE=KE
mgh=.5mv^2
gh=.5v^2
v=sqrt(9.8*23.8/.5)
v=21.598
I don't see where I went wrong in my logic, so I would greatly appreciate some guidance. Thank you!
Vf^2=vi^2+2a(d-do)
KE=.5mv^2
PE=mgh
Vf^2=vi^2+2a(d-do)
Vf=21.598
h=11.9/sin30=23.8
PE=KE
mgh=.5mv^2
gh=.5v^2
v=sqrt(9.8*23.8/.5)
v=21.598
In the first case you have used 9.8/sin30. It should be 9.8*sin30
In the second case you used h/sin30. That should have been h*sin30.
Why is that? I used 9.8/sin30 because sin30=9.8/a, so a=9.8/sin30
I see what I did wrong when I found h, but not when I found a.
*sorry I couldn't get the quote to work right
Apply logic:
The acceleration down a slope is going to be less than the acceleration in free fall. [Indeed, if the slope is very slight, the acceleration is almost zero]
All sine values are fractions [except for 90 degrees when it is 1.
Do you multiply by a fraction or divide by a fraction if you want a smaller answer?
Hopefully you will agree that you multiply to get a smaller answer.
EDIT: when you got sine 30 = 9.8/ a I think you mistakenly assumed 9.8 and a were sides of the triangle that is the ramp The force vector triangle shows sin30 = a/9.8
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
