What is the speed of the spaceship as measured by Joe?
The problem involves a spaceship's speed as measured by two observers, Moe and Joe, with differing measurements of length and time due to relativistic effects. The context is rooted in the principles of special relativity, particularly concerning length contraction and time dilation.
  • Mixed
  • Participants discuss the application of relativistic equations, questioning the validity of combining measurements from different reference frames. Some suggest using Lorentz contraction to find the length as perceived by Joe, while others explore the implications of the speed of light limit.
There is ongoing exploration of the correct approach to relate the measurements of length and time from different observers. Some participants have provided guidance on how to properly apply the principles of relativity, while others have attempted calculations that raise further questions about their validity.
Participants note the constraints of using measurements from different reference frames and the necessity of adhering to the principles of special relativity. There is also mention of the expected outcome being close to the speed of light, which influences the discussion.
SuperNova1
Moe measure the length of his spaceship as 350 m. Joe observes this spaceship as it flies by his position and measures that it took 0.700 s to pass through. What is the speed of the spaceship?
l': the length of the spaceship as measured by MOE = 350m
t: the time as measured by JOE = .7 x10^-6
i'm not positive on the equations obviously speed = distance/time won't work as joe will not measure the length of the spaceship the same as moe will
i found an equation on the relativity of length and how it changes in relation to the observer outside the moving object which was ... change in t1 = L'/(c-u)
but I'm not too sure whether it's anywhere close to the correct equation
i tried distance/time 350/.7*10^-6 = 5*10^8 which can't be right for obvious reasons as the spaceship cannot travel faster than the speed of light
then i tried 0.7*10^-6 = 350/3*10^8 - u
350 = 0.7*10^-6(3*10^8 - u)
350/.7*10-6= 3*10^8 - u
5*10^8 - 3*10^8 = -u
u = -2*10^8
and this answer doesn't look good either
thank you to anyone who can help
You appear to be using length as measured in one reference frame (Moe's) and time as measured in another (Joes's). You can't use those together.
What you can do, I think, is this- let v be Moe's speed relative to Joe. Then the length as measured in Joe's reference frame is [itex]350/\sqrt{1- v^2/c^2}[/itex]. Now, you can say that "speed" is "distance divided y time"- [itex]v= 350/.7\sqrt{1- v^2/c^2}= 500/\sqrt{1- v^2}[/itex] so that [itex]v\sqrt{1- v^/c^2}= 350[/itex]. Solve that for v.
The spaceship from Joe's view contracts. You have it expanding. (Lorentz contraction).
Just multiply 350m by √(1 - v2/c2) instead of dividing.
So the idea is: compute the length of the spaceship as measured by Joe, divide by Joe's time, and that will give the (contracted) length as seen by Joe.
Thank you for all your help guys i did it again and got a value of 0.988c or 2.994*10^8 which sounds right to me as the lecturer told us it was close to the speed of light, thank you again
  • · Replies 16 ·
