Electrical Fixing a 1965 GM Car Radio AM | Troubleshooting Tips
  • Thread starter Thread starter John1397
    Car gm Radio
The discussion focuses on troubleshooting a 1965 GM car radio that has stopped working after intermittent issues for decades. Participants suggest that the problem may stem from oxidized contacts or cracked solder joints, emphasizing the importance of inspecting the circuit board closely. They discuss the expected resistance readings for the radio's components and the potential failure of electrolytic capacitors and carbon resistors. The conversation also highlights the need for a schematic to understand the circuit better and troubleshoot effectively. Overall, the consensus is to methodically check connections and components to identify the fault causing excessive current draw.
John1397
The radio would work sometimes if it didn't pushing on the tuning buttons hard or hitting the dash underneath would make it work if it didn't work, this has been that way for 30 years, now it does not come on at all. I always thought it must be broken connection some where. I had applied voltage from a battery and sure run down voltage on battery in a short time. I tested with ohm meter between ground and positive had real low reading so I took out circuit board. With board laying on bench it tests 206 and 215 ohms when reversing leads between ground and the point where 12 volts goes to circuit board. I never worked on these type of radios does this not seem kind of low for ohms between positive and negative? It seems to only have three transistors and the big audio output transistor.
I would flip it over and inspect all the solder joints carefully with a magnifying glass.
Likes jim hardy, davenn and Tom.G
As @CWatters said. Also power it on and flex the circuit board and other components a little. If you get a response, try to narrow down to the area or component that require the least movement for a result. Then a close visual inspection.
The 200 ohm readings you got are reasonable for the low voltage that the meter uses to make the measurement.
There seems to be manuals and schematics available online for these older car radios. There is probably a sticker or marking on it somewhere that states the brand, it could be either Delco or Motorola.
That is about right for a single transistor, class A audio output stage, that runs on 12Vdc.
The problem is oxidation of a contact, or the fracture of a solder joint. Find it by gentle mechanical provocation.
Time will take it's toll on the electrolytic capacitors and on the leakage of germanium transistors and diodes.
Carbon resistors fail open circuit but can become microphonic or temperature sensitive.
Find the solid fault first, then check and replace the components that are showing their age.
@CWatters is right on.
What I've seen is the joints crack around their bottom right where they join the board.
Like the ones on right, here
Left one looks like a botched repair ? Two distinct layers of solder...
you'll need to use a good magnifying glass and take it out in the bright sunlight. I prefer a jeweler's loupe, myself .
'65 GM you say ?Small world - my daughter has her Great Aunt's 1965 Buick and i expect to be working on that radio soon enough. It stopped working about twenty years ago, before she inherited it
old jim
Likes TechTree and davenn
Tom.G said:
Delco or Motorola.
Philco-Ford equals Motorola (think "Edsel" McNamara); i.e., not a GM product.
Remember how expensive transistors were back then. So many passive R & C components, yet only three transistors, with a couple of diodes for the AM detector. That suggests a reflex receiver circuit with variable inductance tuning.
If those are IF transformers, then it is a superhet and there needs to be a local oscillator, an IF/audio reflex amplifier, and an audio output stage. That will be an interesting circuit when we find out what it is.
I never heard that term before. What does it mean? Does the resistance vary with sound?
Yes. Just like a carbon microphone, only not such a good quality sound, more like clipping.
The same happens with some coaxial cables where the braid or conductor wires can rub together when moved.
what ? microphonic ? … a VERY old term in electronics :wink:
it means they generate noise due to touching / vibration etc
this can be a major problems particularly in RF oscillators where microphonics cause FM'ing of the osc. signal
That is why you often see oscillator circuits with wax all around them even in older transistor radios.
I think I will soon find it as it was drawing to much current must be short in tuning coil or audio output transistor I applied power to board only, draws only small amount of current all transistor caps diodes test good. Tuning coil has 8 ohms do not know without diagram if this is right, but will put every thing together and unhook one item at a time until I find short. If it still draws excessive current should be able to feel a warm component some where. I do not think a broken connection can cause excessive current draw can it?
If it's the "Sonomatic", ie no 'Wonderbar' motor driven tuning, it's probably a Delco 728934
and from a search, an antique radio forum said Sam's Photofacts AR30 repair manual covers it. Ebay has a few listed. But you have to be careful for misinformation abounds.
Probably there's a Delco manual out there someplace.
Blogs like this one are sometimes helpful - let Google or Bing work for you.
http://antiqueradios.com/forums/viewtopic.php?f=6&t=308550
In my days i'd have expected five transistors
an RF amplifier near the tuning coil
a local oscillator near the other tuning coil
an IF amplifier , doubtless that metal one between the IF cans
an audio amplifier probably that black one just left of IF cans
and the output power transistor probably mounted to the sheet metal with an insulator .
If you can inject signal from an audio source like a cassette or cd player headphone jack (through about a microfarad to block DC) to wiper of volume control you'll maybe get a clue which direction to chase your trouble.
Good Luck - if you find a schematic, post it ? I'll do likewise.
old jim
PS might this be a candidate for our DIY thread?
Likes DrClaude
It is a 7291063 AR 23 they had many different numbers but I think they are mostly the same board. More than likely it's one of those non electrolytic capacitors is shorting out those are the one's I figure can never fail.
Big output transistor isn't on the board, is it ? Likely suspect..
If it is in the base biasing circuit of a big transistor with transformer for collector load(hint hint- output transistor) it sure can. It could turn the transistor full 'on'.
Check the dial lamp and its socket too.
What do you mean by 'excessive current' ?
Have you measured it ?
What kind of battery did you use to test the radio ?
do you have a voltmeter ? Ammeter ?
Yes. I moved the thread.
Likes jim hardy
There seems to be a short some where and checking all the capacitors on that board might find problem anything that has winding's I will not be able to find. When apply 12 volts from power supply the initial amp draw is 1.6 amps in about one second it drops to .33 amp remains there and when measuring voltage at to3 audio output at both base and emitter voltage starts out at 4 volts and one second later goes to ten volts. Out of curiosity I removed wire to base of audio output then amp draw is less than tenth of an amp. I did change audio output transistor but it made no difference.
Not unreasonable if it includes the dial light.
That sounds curious.
Is there a resistor from emitter to chassis?
if so check it.
Is there an audio output transfomer ?
Place one voltmeter lead on output transistor base, other on output transistor emitter.
That way you measure its base-emitter drive.
Is it silicon or germanium ? Silicon should be close to 0.6 volts, germanium 0.3.
So it draws maybe ¼ amp ? Doesn't sound bad for a several watt class A amp.
Do you understand transistor biasing ?
see https://www.electronics-tutorials.ws/amplifier/amp_5.html
ten volts across RE is too much for a 12 volt supply..
C1 who blocks DC from previous stage might be leaky,
Biasing resistors R2 or RE which establish quiescent operating current might have drifted high.
R1 who with R2 makes a voltage divider to set base voltage could be low, but carbon resistors usually fail high.
You need your schematic.
Or you'll have to trace out your circuit board and draw a schematic of the part under study
so as to find physically where to measure
Draw one and write on it voltages at E B and C .
old jim
Of course if that output transistor is a PNP
the circuit will be upside down from what i pasted above,
with base and emitter near 12 volts and collector near ground.
You already measured base and emitter near 12 volts - what does collector show ?
Troubleshooting is like working a jigsaw puzzle .
You establish known facts one by one , building a mental picture from them.
Once you've established what is that output transistor, NPN or PNP, germanium or silicon,
you can judge whether your voltages make sense.
So that ought to be your first "fact" to establish.
Voltages at E B and C will be a clue.
Values of the resistors will tell you what the designer had in mind.
Go man, Go !
I was checking to see if speaker wire is connected to any thing I took picture and drew every thing paper but I don't see no connection from collector of output transistor to speaker wire. I was always looking at the transformer and I drew it in diagram as it is hooked up with one wire going to chassis ground and another wire going to electrolyte capacitor ground and the the other two wires are going thru a sleeve and get connect to speaker wire/ Maybe I am not understanding the electorate capacitor right I thought the four pins coming out one is 800 mfd another 400 mfd and another 100 mfd and I thought the fourth pin is ground where the transformer get hooked. I took my speaker wire and connected it to collector of output transistor and I got it to play for a little while then it cut out again
Shouldn't be one. Collector drive primary as in that tutorial.
Both wires to ground can't work. Might one of those wires go to the collector(case) of the TO3 transistor instead ?
That probably should have wrecked the output transistor and the speaker.
Take some pictures and post them ?
What is part# of output transistor?
What are voltages at emitter base and collector of output transistor? Measure to 1/10 volt, include polarity with black voltmeter lead to chassis gnd. .
your photo doesn't show, try pasting it into Paint and see if anther format will show up.
Your schematic doesn't show a transformer with four wires but only an inductor with two and it's in parallel with speaker
One speaker wire goes to ground
other one goes to junction of collector , inductor and a capacitor.
EDIT (late entry) That the speaker is connected to output transistor collector makes my remark yesterday about wrecking parts , well, just plain WRONG.
It's a PNP so
Collector should be at quite low voltage
emitter and base near ten volts sounds okay.
I drew out all wires I disconnected on paper and even took picture when I am all done pin on board where speaker and inductor wire is soldier on goes no where could have been wire underneath that fell off but haven't found any yet. I would think only logical place to connect speaker is to E of Ds-503. I drew up a partial diagram how it is wired the 12 volts goes around capacitor not thru it..
You're making progress.
Focusing on just the output stage
E ? perhaps C ?
I drew it right c is the case and case is bolted to aluminum heat sink and this is mounted to chassis no plastic spacers around bolts just seems like you need to connect speaker wire to emitter. I have picture before I unsoldiered any thing and picture of board. And after first soldering every thing back the first time I did pickup sound after connecting 8 ohm speaker to emitter or yellow wire.
Your friend's picture shows plastic spacers
yours doesn't look like the same heatsink
and i think you have already noticed that.
If your "inductor " has four wires it is almost certainly a transformer.
Is there a part number on that output transistor?
Is there a mica washer underneath , between it and the heatsink?
  • #31
I finally figured it out washer in wrong spot then every thing is correct still doesn't help my initial problem.I might some time find the problem have more things to check yet.
  • #32
Which initial problem ?
or
  • #33
One mistake leads to another first didn't install output transistor correctly then drew out diagram thinking c is ground then tested fourth pin in capacitor thinking it is just ground pin (4 capacitors in the can not three) it had 2 meg resistance to ground did not spark after applying voltage and shorting with screw driver.Now I am thinking this capacitor which is the finale capacitor from speaker and transformer output to ground if has no capacitance left might be kind of important.
Likes jim hardy
  • #34
I connected 8 ohm speaker where it normally would connect I get .12 base 0 collector .13 emitter of finale output transistor. When I disconnect speaker and reconnect to emitter of final output transistor I get 1.3 emitter 0 collector 1.43 base. If I move speaker connection to base of finale output transistor I get .88 emitter .85 collector .51 base. If you connect speaker to emitter terminal of finale output transistor you get a lot of readings further up front in the 1.3 to 1.5 volt range. If there is a short it could be any where on that board? There are seven electrolytic capacitors I changed four of them because of failure.
  • #35
Your output circuit has to resemble this to make a significant amount of sound.
I just redrew the one from that tutorial and added a capacitor CE in parallel with RE.
With volmteter's black wire on GND
Volts at the collector should be a couple volts or less but not zero
Volts at the emitter should be probably a couple volts less than battery , like ten or so
volts at the base should be close to 1/3 volt less than emitter.
That's because your speaker is only about five or six ohms so it short circuits current around the output transistor.dropping almost all your 12 volts across RE and leaving no current through the inductor.
That's because grounding the base through your five or six ohm speaker turns the transistor fully on, again dropping almost all your 12 volts across RE
From this sketch of yours, which i think has some errors,
I'm guessing that in the redrawn tutorial sketch above
RE is 47 ohms
and there's an electrolytic capacitor in parallel with it
Get your drawings straightened out, find R1 and R2,
then write down volts a E B and C
  • #36
Where is that ?
  • #37
I was just moving speaker connection around so I drew up three different speaker hookups and voltages around output transistor. 0 volts at collector will never work. I have been thinking I do not know if anybody does this but it seems if unit is drawing to much current start opening up circuit starting at power supply then moving to output transistor and so on to see where those amps are going if power supply heads in two direction you can't till which way short is by measuring volts but with amp meter you could. I am going to change output transistor to a different good one sure transistor tester says it is good but that could be wrong. And transformer is wound that way as two wires coming out of transformer to speaker are soldier together almost way down to the point where they come out of transformer.
  • #38
Okay when troubleshooting you must resolve things that defy logic one by one until the mysteries are all gone.
You say you've heard sound out of this radio so it must be almost working.
Now what doesn't make sense ?
First thing that jumps out at me is..
Curiously
all three of your recent sketches show emitter hooked straight to +12volts by a wire
yet a much lower voltage reading there of between 0.13 and 1.3 volts.
Is your 12 volt supply really collapsing that severely ?
Or is that wire to emitter broken in the middle ?
Not much chance of anything working with supply less than a volt.
Figure that one out first.
  • #39
Is there something missing from your three sketches ?
does that say ".47 fuse" ?
Where'd you get that drawing ?
  • #40
I found this online a genuine delco book that drawing is right . I measured 0.8 ohms across this . On one side of this device on the circuit board it says fuse and the other side it says res. It is kindy 3/35" diameter 3/8" long looks like in metal can has cotton sleeve over the outside. I thought it was a thermal type fuse to protect the output transistor.
I never measured voltage just amp draw of unit was .56 amps I just seen this now on the manual diagram says normal amp draw is 1.3 Amp that is more than likely what is happening the fuse is opening up after you apply power. Know I see why in the three drawings in drawing three where speaker is connected to base the voltages go up, applying load increases resistance then voltage drops. You need 12 volts on emitter. This is probably why the output transistor is still good I have heard using radios and amps without speaker connected can burn out transistor I do not know if this radio is one of those.
  • #41
Now you're seeing the approach - understand what voltages to expect then check for them with a meter.
To that end
it is vital to have an accurate schematic drawing
and know physically on the board where are key points to measure.
Can you read voltage on both sides of that fuse ?
That'll work better than an Easter egg hunt for a short that might not even be there.
Unless you're extremely lucky.
  • #42
Two diagrams a year apart both circuit a little different problem is burned out predriver to the finale output transistor. In my drawing I have NPN driving the DS-503 and one year earlier they used an PNP to drive the PNP DS-503 output tansistor. They used what appears to be two of the same transistors but no number I think an ECG103 would work or how hard would it be to make a Silicon say ECG158 work?
  • #43
What are ECG103 and 158 ? You've already looked them up so save us a search.
What's in the radio ?
I cannot read the numbers on your drawings. Can you clean them up a little and repost?
2N3903, 2N3904, 2N3905 and 2N3906 will replace 90% of all general purpose small signal transistors.
A good circuit is tolerant of variations in transistor specs.
Just make sure your Vce and Ic ratings are adequate
and hfe is same order of magnitude.
  • #44
I seen online some one wrote when changing geranium to silicon double resistor value from base to collector. Mine is 22k so if I change to 44k should work?
  • #45
sounds like gibberish to me. And since i can't make out numbers on the schematic i don't know what the 22k does.
You SHOULD adjust the two resistors that set base voltage to account for higher Emitter- Base voltage of 0.6 instead of 0.3.
I can't read the values of those two resistors on your drawings.
And i don't believe your hand drawn schematic because it shows two bases tied together and there's noplace for collector current to go..
You haven't yet tried to understand transistor biasing.
Try first just swapping in a silicon. If base is biased for mid-supply it'll most likely work.
If not try decreasing your 22K (base pulldown resistor?) by 10% and see what happens.
Easiest way is by tacking a 220K or 240K in parallel with it.
  • #46
The drawing is still right just need to reverse b and c on both preamps . When installing new transistor it was ecb I thought ebc when making drawing so not drawn right. I changed 22k to 44k I see some recommend as much as 1 meg, I do not know if there is a formula to figure that out. I don't know if that exactly right. I made a new drawing where every thing is right and have the correct voltages. I finally decided to inject audio signal at volume control to see if amp part works rather than fixing every thing and it did so I then connect signal from radio and it worked.
  • #47
Can't argue with success, can you ? Must feel great to hear it playing .
Got a '60's radio station in town ? I think "Wooly Bullly" was #1 that year...
old jim
  • #48
Found the on off problem anyone fixing these watch for tab punched out of top cover so it doesn't touch circuit board and short out signal. The tab bent down on cover about 1/4" should go on part of circuit board with no foil.
Likes dlgoff and Tom.G
  • #49
Got a Picture ?
  • #50
