Are there methods for inverting non-square matrices under constraints?
  • Thread starter Thread starter Nikratio
    Inversion Matrix
Nikratio
Hello,
I need to invert a non-square matrix A under the constraint that the absolute value of each component of the solution is less than some maximum. In other words, I want \vec{b} such that A . \vec b = \vec c and |b_i| < \alpha.
Are there any established methods for doing this?
My idea is to start with the pseudoinverse to compute the unconstrained solution, and to then add components \vec v_i from the null space of A to satisfy the constraint. If this doesn't help, I wanted to consecutively add more basis vectors from the singular value decomposition of A, starting with the basis corresponding to the smallest singular value.
However, I don't see how to pick the coefficients of the \vec v_i in such a way that the final solution is optimal in the sense that there is no other solution that satiesfies the constraints but has a smaller ||A.\vec b - \vec c||.
Anyone able to help? Pointers to appropriate literature would be appreciated as well, I am not quite sure what keywords I should be looking for.
I see some confusion in your question, or at least nomenclature. You write b as a vector, in which case it certainly is not the pseudoinverse of A. It seems that you are asking for a constrained solution to a system of linear equations?
Yeah, you're right.
What I want is a constrained solution to the system of linear equations.
At the beginning I was thinking that maybe I can construct a matrix A^+ such that \vec b = A^+ . \vec c and \vec b satisfies the constraint. Construction of A^+ would then be a "constrained matrix inversion". But I no longer think that such a matrix can exist, so my problem is indeed to find a constrained solution to a system of linear equations.
One possible approach is to couch it as a linear programming problem that can be solved by the simplex method. This method solves systems of linear equations subject to simple constraints.
In this case you would minimize Ix, where I is the identity matrix, subject to the constraint
Ax < b
where the vector b has components alpha. A web search should turn up dozens of sites on simplex method and linear programming, and it is also covered in texts on numerical analysis.
I expect there's also a variant available somewhere to deal with the absolute value I|x|, or some means to reset any value that goes negative.
Linear Programming was exactly the right keyword, thank you so much! I should be able to find my way from here on.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
