Finding the Mass of a Suspended Necklace Using the Center of Mass Method
The discussion revolves around calculating the mass of a necklace suspended from a meter stick using the center of mass method. The problem states that a 0.19 kg meter stick balances at its center, but the balance point shifts 16.3 cm towards the necklace. Participants clarify that calculus is not necessary for this problem, emphasizing the center of mass of the rod is at its midpoint. The correct approach involves setting up torque equations around the new balance point to find the mass of the necklace. Ultimately, the mass is determined to be approximately 0.09 kg.
vworange
Been trying this one using:
x1m1 = x2m2
I guess I just maybe am not using the right mass or length for center of mass..
Here's the question:
A 0.19 kg meter stick balances at its center. If a necklace is suspended from one end of the stick, the balance point moves 16.3 cm toward that end. What is the mass of the necklace?
You need to use calculus, not physics. Look up center of mass of a rod on google.
I don't remember the formulas, that was like two months ago.
don't mislead him, no calculas is needed in this problem, the center of mass of a rod is at its mid-point...
here is some hint:
draw the graph first, and find the torque for LHS and RHS... the torque of the necklace is straight forward, but the torque for the rod is a bit tricky...
x1m1 = x2m2
The stick has a mass/length of .19 kg/m or 1.9 g/cm.=\rho The torque when the necklace is added and the balance point is moved is 0:
M_nd_1 + \rho d_1^2/2 - \rho d_2^2/2 = 0
d_1 = 33.7 and d_2 = 66.3 cm
(you can think of the torque from one side of the stick as a point mass sitting half way between the end and the balance point on a massless stick).
AM
There's no need to divide the rod into 2 pieces and to calculate the torque of each of them.
This problem is as simple as 1,2,3. :zzz:
Look:
Write the equation of the torques around the new ballance point:
15*0.2=35*m
m~0.09kg
That's it!
Enjoy physics!
