How do changes in internal pressure affect airflow in a room?
  • Thread starter Thread starter Jimmy Boy
    Internal Pressure
Changes in internal pressure significantly affect airflow in a room, as demonstrated by a model using the vent opening equation. With a vent area of 2500 mm² and specific parameters, the calculated airflow rate is approximately 0.0043 m³/s. An increase in mass entering the room raises the internal pressure to 101715 Pa, leading to a pressure difference of -475 Pa, indicating a potential negative flow from inside to outside. The discussion highlights the importance of time intervals in pressure calculations, suggesting that pressure may equalize faster than initially estimated. Understanding these dynamics is crucial for effective airflow management in enclosed spaces.
Jimmy Boy
I am trying to develop a basic model for calculating internal room pressure. I am using the vent opening equation. q = Cd A ((2 *delta P )/p)^0.5
If I have a set the vent 2500 mm2; A = 2.5e-3 m^2
Cd = 0.61
Internal pressure to be 102,135 and the external pressure to be 102,140;
p = 1.21205 (at 20 C)
delta P = 5 Pa.
volume = 55 m^3q = Cd A ((2 *delta P )/p)^0.5
so q = 0.004308549 m^3/s or 0.258512945 m^3/ minIf I wanted to calculate the next internal pressure,
the mass entering the room is 0.313331 kg,
Converting this back into a pressure value,
P = m * R *T / V
P = 480 Pa. So the new internal pressure is 102135 + 480 = 101715 Pa
So the next pressure difference is 475, which causes a larger air flow and a larger difference pressure the next time. It starts to spiral out of control.
Any ideas?
Actually, the next pressure difference is -475, which would give a negative flow (from inside to outside).
The pressure will probably equalize before the 1 minute time difference you estimated. Reduce your time difference.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
