Confused by nonlocal models and relativity
In summary: Nonlocality is an important feature of BM.3. Finally, does the conclusions in those papers prevent any attempts to make BM relativistic?No, the conclusions in those papers do not prevent any attempts to make BM relativistic.
  • #36
DrChinese said:
Instead, the 1 & 4 polarization matching will be about 50%, no correlation*. How is it that the same pairs arriving at 1 & 4 - which are spacelike separated - are suddenly giving Product state statistics rather than the Entangled state statistics? The only change was to the path length of photon 2, which is spacelike separated from photon 1 (and 4)? Because of the separation, there cannot be any causal connection between the decision to add the 100 picosecond delay and the matching between photons 1 and 4.
Because when you add the delay, you are post-selecting different pairs of photons 1+4. Before you decide to add the delay or not, you can have the results of all the 1+4 measurements on a sheet of paper by your side (with randomly chosen HH or VV results). If the selections would be equal, what you are suggesting is that either the contents of the paper change based on your choice to delay or that your choice to delay is already determined based on the contents.
Or maybe I'm missing something - can you show that the same pairs are chosen in either case?
  • #37
The pair selection is the same. When any photons at the BSA hit a detector, a time stamp is recorded. Normally you would pick pairs that arrived within a 10 ps time window (or whatever). There won't be much outside that window as suitable 2 & 3 pairs (actually 4 fold coincidences) only come along every few seconds (perhaps 1500 in a 9000 second run). That makes the average time distance between pairs on the magnitude of a billion times the size of the window. It's practically a desert for coincidences between suitable pairs.
Now, if I add 100 ps to the photon 2 path, everything will else remain the same in terms of the relative ordering except that 1 of the BSA clicks will be marked as being between 95 and 105 ps later than the other. We would label that one as photon 2 - now clearly distinguished from photon 3. They would still be recorded as both H or both V. But if the one labeled photon 2 arrives that much later, we know it arrived still entangled with photon 1. Accordingly, no swap occurred, and it was not entangled with photon 4. Therefore, 3 & 4 were still entangled. You can work out the stats yourself, but the upshot is that 1 & 4 arrive at their respective 45 degree detectors with the same polarization HH or VV. Since they are not entangled though, we see Product state statistics for their matching rather than entangled state.
Considering that the decision to delay any particular photon 2 can be made before, after, or (near) simultaneously to the detections of photons 1, 3 and 4, it would require you to accept my central premise in the first place to believe that different 1 & 4 pairs are now selected. My premise being exactly that the entire context - which is clearly NOT locally causal (as there is no way to trace and/or otherwise assign causes and effects ) - must be considered to make a correct statistical prediction. Which is exactly what QFT says.
  • #38
DrChinese said:
1. There cannot be both causality [deterministic effects flowing from past to future] and locality (per Bell). I am guessing that you are pushing some special meaning of "microcausality" that purports to avoid Bell, but I don't know what that would be. If that is the case, perhaps you can explain relative to the example below.
2. Sure, and the reference diagram is from here.
a) In the various swapping experiments cited, entanglement of photons 1 & 4 occurs when photons 2 & 3 are cast via a Bell State Analyzer (the BSA is to be set at 0 degrees). The BSA is in the upper middle balloon of the diagram. The 1 & 4 pairs are spacetime separated, post selected, and the setup calls for the 1 & 4 to arrive at their beamsplitters near simultaneously (within a suitable coincidence window - so note that this is NOT the variation where the photons never coexisted). For simplicity, let's say we post select only those pairs that are psi+ entangled (same polarization when both measured at 45 degrees or any angle). By selecting 0 degrees for the BSA, and 45 degrees for the 1 & 4 pair, you can't learn anything about polarization of 1 & 4 when you perform the BSA on 2 & 3. The BSA on 2 & 3 rings either HH or VV for psi+, and again, the coincidence window is suitably small so that 2 & 3 are indistinguishable.
The 1 & 4 pairs will be matched in polarization about 100% assuming an ideal setup for the group we post select.
b) Now, we insert a 100 picosecond delay into the path of photon 2 (but nothing done to any of the other paths). The 1 & 4 pairs we want will still arrive within the requisite time window (relative to each other). But the 2 & 3 pairs will be easily distinguished as photon 2 will arrive about 100 ps later than photon 3. Importantly, we can still identify the 2 & 3 pairs as being either HH or VV as before, so that we can still post-select the proper 1 & 4 pairs. If there is local microcausality, as you claim, this modification should NOT affect the results at 1 & 4. (There is no causal connection between events at the BSA and detections at 1 & 4.)
But that is not the case. Instead, the 1 & 4 polarization matching will be about 50%, no correlation*. How is it that the same pairs arriving at 1 & 4 - which are spacelike separated - are suddenly giving Product state statistics rather than the Entangled state statistics? The only change was to the path length of photon 2, which is spacelike separated from photon 1 (and 4)? Because of the separation, there cannot be any causal connection between the decision to add the 100 picosecond delay and the matching between photons 1 and 4.
And yet this is all standard QFT. Which of course follows Bell, which rejects local determinism (a/k/a local realism). In case anyone is wondering if my version of this setup has ever been tested: EVERY entanglement swapping experiment demonstrates this! They always start with the 2 & 3 photons being distinguishable and then attempt to tune it to the indistinguishable version. When the 1 & 4 stats move from being Product state stats to Entangled state stats, they know they have succeeded. :smile: QED.*The stats would be as follows: The matches between entangled photons 1 & 2 will be 50% (i.e. random) due to the 45 degree separation in polarization angles being measured (cos^2 theta). Ditto for entangled photons 3 & 4. 1 & 4 are not entangled, and so their match rate will likewise be random. Of course, we are still only post selecting the portion that are denoted by HH or VV at the BSA.
1. Relativistic QFT clearly shows that there are both locality of interactions and "non-locality" of correlations, and that's not a contradiction. To the contrary it is precisely what's needed to be (a) consistent with the relativistic space-time structure and the corresponding causality structure and (b) consistent with the observered violation of Bell's inequality as predicted by any QT in general and particularly by local, microcausal, relativistic QFT. There's no "special meaning" of microcausality but the usual one used in any QFT textbook: The Hamilton density commutes with local observables at space-like distances,
$$[\mathca{H}(x),\mathcal{O}(y)]=0 \; \quad \text{if} \quad (x-y)^2<0,$$
where I use the west-coast convention, ##\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,-1)##.
2. also in this experimental setup I see nothing which contradicts the standard interpretation I follow. The selection of the pairs 1&4 is based on a selection of 2&3 with measurements/manipulations all explainable by local interactions with the various apparati used in the experiment, including the coherence arguments you quote. Of course, if you make the photons in the pair 2&3 distinguishable you loose this coherence (that's what Bohr called "complementarity") you choose a different subensemble than before and you loose the 100% correlations. What's imho wrong with your argument thus simply is that you do NOT post-select the same ensemble with and without the delay you mention. To get 100% correlation for 1&4 you MUST not make 2&3 distinguishable. If you make the dinstinguishable you necessarily choose another sub-ensemble which necessarily doesn't show the correlations. In other words in this case you have not "swaped the entanglement".
Again there's nothing non-locally interacting here. It's just which subensemble you "post-select" to observe for the photons in the pair 1&4 based on what you observe (by local measurements) on the photons in the pair 2&3. Of course, the photons in 1&4 have never (or at least need not) locally interacted themselves at any point in the experiment. To describe the experimental outcomes it's sufficient to have the pairs 1&2 entangled and the pair 3^4 entangled as described. You thus have long-range correlations which can be "swapped" to the pair 1&4 by local manipulations on the pair 2&3 without necessarily enforcing ever a local interaction of pair 1&4. There's no contradiction between the locality/microcausality of interactions in relativistic QFT with the long-ranged correlations described by entanglement.
Then for clarification: Bell has shown that any local deterministic hidden-variable theory is INCOMPATIBLE with QT (and particularly thus also QFT), i.e., he derived his famous inequalities contradicting QT and thus made this type of theories testable against QT. The result is well-known today: The local deterministic HV theories are wrong but QT so far has been in accord with observations in all cases, sometimes with astonishing significance.
  • #39
vanhees71 said:
1. Relativistic QFT clearly shows that there are both locality of interactions and "non-locality" of correlations, and that's not a contradiction. ..
2. What's imho wrong with your argument thus simply is that you do NOT post-select the same ensemble with and without the delay you mention. To get 100% correlation for 1&4 you MUST not make 2&3 distinguishable. If you make the distinguishable you necessarily choose another sub-ensemble which necessarily doesn't show the correlations. In other words in this case you have not "swapped the entanglement".
1. It's a contradiction. Established science is: Local determinism is excluded. As Demystifier says: "What does it mean "to prepare correlations"? Correlations of what? One cannot prepare correlations themselves. " You are going to have to provide a reference if you think QFT is local.
The entire point of this discussion is to clarify that with entanglement swapping variations - experiments that have been executed over the past 20 years by top research teams - there is no way to get back to a local description of what occurs. From the Zeilinger et al reference: "This shows that the independent photons [particles that do not share any common past ] in modes 1 and 4 clearly are entangled and can asymptotically be distilled into the maximally entangled singlet state...". They are in the singlet state, not just "correlated".
2. If the decision to entangle photons 1 & 4 is made at the last minute: please explain how that causes different 1 & 4 pairs to be selected. According to you, nothing changes there. ("there's nothing non-locally interacting here.") And presumably, 2 photons from independent sources (2 & 3) don't interact in your view either (regardless of whether they arrive at a beamsplitter simultaneously or not) . How could they? So how would different ensembles be selected?
  • #40
I think first there needs to be a precise definition of what "local" means. Bell gave a definition of "locality" in his paper which any theory that matches the predictions of QM must violate; that's what his paper proved. But his definition is not the only possible one.
Likes DrChinese
  • #41
I quite agree. So why are you pushing QFT as locally causal? Your words below seem quite clear.
"The interactions are, according to the very fundamental construction of relativistic QFTs of which QED is the paradigmatic example, local and also only those QFTs are successful which obey the microcausality principle..."
"My conviction is so strong, because I think that locality of interaction/micro-causality is [one of] the very fundamental assumptions put into the construction of relativistic QFTs and particularly the Standard Model/QED. "
  • #42
Ad 1) How then can relativistic QFT be the best model of relativistic QT on the market, and it's not contradicting also the quoted Bell experiments, including entanglement swaping, teleportation, quantum erasures etc.
It's very clear what's correlated given the states your photons are prepared in. The photons from parametric down conversion are both correlated in momenta and in polarization. That's the very basis of all these experiments.
As I tried to explain for several times. The very quote by Zeilinger is fully consistent with standard QED. The partial ensemble of 1&4 pairs selected (or post-selected!) depending on local measurements on pairs 2&3 must be entangled, though the 1&4 never interacted. To be sure that they have never interacted you even need the microcausality argument since you can be sure about this only within the standard relativistic microcausal QFT according to which there are no actions a distance (i.e., causal connections between space-like separated events). Indeed they are not "just correlated" but even entangled, leading to stronger correlations than possible in deterministic local hidden-variable theories.
All your arguments thus rather confirm my arguments than disprove them!
Ad 2) It's said in the paper you quoted in the posting I was answering to: You must be sure to measure photons 2&3 within the coherence times/lengths of the photons to get the entanglement. If you make a time delay such that the "photons are getting dinstinguishable", then you don't exploit the correlations due to the initial entanglement of the pairs 1&2 and 3&4 anymore, because you are beyond the coherence "space-time inverval", and then the chosen subensemble of 2&3 doesn't select the same subensemble of 1&4 as before. As you say yourself, in this case one expects simply uncorrelated photons in 1&4 in this subsensemble. This is what I said in my previous answer too. Why you are claiming the opposite, I don't know ;-).
Likes akvadrako
  • #43
You gave a precise mathematical definition for what "microcausal" means here (basically that operators at spacelike separated events commute). What is the precise mathematical definition for what "local" means here?
  • #44
What do you mean by "locally causal"? By construction we build QFTs fulfilling the microcausality condition, because that's sufficient to define unitary S-matrix elements fulfilling the linked-cluster theorem. It's of course NOT a local deterministic theory, but a quantum theory implementing the locality of interactions. This, of course does NOT imply something deterministic in the sense of HV theories.
E.g., if you prepare two photons in a singlet-polarization state the single-photon polarization states are "really" completely undetermined but still the outcomes of measurements in the same polarization direction are 100% correlated. Since in the described experiments the photons are also 100% correlated in their momenta (in Quantum Optics slang called the "phase-matching condition" in parametric downconversion) the 100% polarization correlation can be measured by making coincidence measurements at far-distant places such that you still can be sure to really measure the very two photons that are entangled. The measurements are localized at the places where the measurement apparatus (here in the simplest case simply consisting of a polarization filter and a subsequent photodetectro) is located. This locality of the measurement is of course assumed due to the underlying microcausality of QED. From reading many papers about such experiments, it seems to be usually accepted in the quantum-optics community that, space-like separated measurements cannot mutually cause each other in any way.
  • #45
I think "local" (applied to intereactions) is synonimous with "microcausal". It's a pity that many notions are so unsharp in these discussions that you have to use much more precise formulations, making the entire writing even more complicated than the whole issue really is. The only clear language at the end are mathematical fromulae ;-))).
  • #46
You keep saying correlated as if they are not entangled, when they are. Entanglement is a quantum state. Particles can be correlated without being entangled, but not vice versa.
1 & 4 are not entangled into the singlet state UNTIL and UNLESS a swap occurs between system A (photons 1 & 2) and system B (photons 3 & 4). The swap affects both systems (A and B), each which has both temporal and spatial extent. The order of the detection and swap events is not relevant, and the swap itself affects the entirety of each system - violating local causality.
I keep calling for references, and you keep quoting yourself.
  • #47
vanhees71 said:
1. E.g., if you prepare two photons in a singlet-polarization state the single-photon polarization states are "really" completely undetermined but still the outcomes of measurements in the same polarization direction are 100% correlated.
2. Since in the described experiments the photons are also 100% correlated in their momenta (in Quantum Optics slang called the "phase-matching condition" in parametric downconversion) the 100% polarization correlation can be measured by making coincidence measurements at far-distant places such that you still can be sure to really measure the very two photons that are entangled.
3. The measurements are localized at the places where the measurement apparatus (here in the simplest case simply consisting of a polarization filter and a subsequent photodetectro) is located.
4, This locality of the measurement is of course assumed due to the underlying microcausality of QED.
5. From reading many papers about such experiments, it seems to be usually accepted in the quantum-optics community that, space-like separated measurements cannot mutually cause each other in any way.
1. Agree.
2. Agree.
3. This might be true when you are referring to an entangled system PRIOR to the swap. But after the 2 entangled systems (1 & 2, and 3 & 4) interact, both change to a different overall context. Now 1 & 4 are the entangled system.
4. Circular reasoning, my friend.
5. The rest of the community does not share your personal interpretation. I have provided plenty of quotes expressing the opposite view. Post Bell: No local realism, no local hidden variables, no local determinism, no local causality, no local micro-causality (whatever that is) etc. Every generally accepted interpretation denies some/all of these.
I get (and agree) that you deny that a particle in a superposition does not have an objective well-defined value independent of observation. And I get that your "causal" idea works fine for a typical PDC pair. But the whole point of swap experiments is to show that is an incorrect picture in and of itself. It simply doesn't work with swaps because it is not 2 particles interacting locally (2 & 3) as you suppose; it is the 1 & 2 system interacting with the 3 & 4 system, and those systems have spatio-temporal* extent.
*I.e. lacking a spatial point, and lacking a point in time.
  • #48
If there's anything correlated than it's if it's entangled. Entanglement is the strongest correlation you can have. It's even stronger than any correlation possible for a local deterministic HV theory. I think we simply do not use the same language, and I was sloppy here. So let me try again.
(a) The experiment considered here can be described as follows. There are two pairs of polarization-momentum entangled photons prepared, namely 1&2 and 3&4. The four-photon state at the beginning is thus given by the state ket
$$|\psi_{12} \rangle \otimes |\psi_{34} \rangle.$$
In full glory it's pretty lengthy to write. It's usually simplified as in the paper by only writing down the polarization part the experimenters are dealing with. However the full pair states also include the momentum part. If the polarization part is antisymmetric this must also be the case for the momentum part since photons are bosons. To fully discuss the experiment it may be important to once sit down and write this out completely, but it's understood implicitly also in the notation of the paper (which becomes clear by the figure discribing the experiment).
Anyway, due to the direct product, of course the photon pair 1&3, 1&4, 2&3, 2&4 are all NOT entangled.
However, when you make a selection by make a Bell measurement on photons 2&3 in the described way, particularly in a space-time region that is close enough together to be in the coherence lengths of all the photons, you can project (even long after the experiment is done as long as you have a complete measurement protocol with all the time stamps at place) to one of the possible Bell states for the pair 2&3. Here only local interactions of photons 2 and 3 are used, while 1&4 never have interacted in such a close region. Nevertheless due to the selection ensuring the entanglement of 2&3 due to being measured as being in one of the Bell states (the authors choose the polarization singlet state, but you can as well use any other of the four possible Bell states) for this subensemble 1&4 are now entangled.
Note that it's just the selection that leads to the entanglement. There's no non-local action at a distance at place since the meaurement on photons 2&3 (which must be close enough together in spacetime due to the coherence constraint) can well be space-like separated from the measurments on photons 1&4. You can post-select one of the Bellstates of 2&3 long after the entire experiment ist done and still find that the subensemble of photons 1&4 are correlated as described by their entanglement.
You are right in saying that the two entangled systems interact by just doing a local measurement on 2&3, because indeed 1&2 as well as 3&4 are entangled, i.e., they are "inseparable". That's the clue of the entire experiment! I however don't see why you say that there's anything non-local going on here. The interaction of the photons 2&3 with the measurment devices that enables you to select the wanted Bell state is local (in the sense of microcausality of QED).
I still don't understand your statement ad 5). Since that's precisely what I emphasize the whole time: All the models you quote are contradicting relativistic local (i.a., microcausal) QFT, but all experiments are in accord with QFT rather than any of these models which are constructed such as to contradict QFT.
I don't see anything in Zeilinger's et al's papers contradicting the minimal interpretation. It think it's precisely the interpretation Zeilinger always emphasizes. He's calling it "Copenhagen", but one should be careful to clearly state that it's the flavor of Copenhagen which doesn't assume non-local actions at adistance which is a clear contradiction to the microcausality postulate which you put into the contsruction of relativistic QFTs from the very beginning. I think it's the view widely accepted in the quantum-optics community. So I think I am rather in the main stream here ;-)).
Likes akvadrako
  • #49
Then why put in the extra word "local"? Particularly when it causes interminable arguments in threads like this, because the word "nonlocal" is commonly used to describe correlations that violate the Bell inequalities?
Likes zonde
  • #50
vanhees71 said:
1. If there's anything correlated then it's if it's entangled.
2. Anyway, due to the direct product, of course the photon pair 1&3, 1&4, 2&3, 2&4 are all NOT entangled.
4. I don't see anything in Zeilinger's et al's papers contradicting the minimal interpretation. ... So I think I am rather in the main stream here ;-)).
1. Finally! :smile:
2. Agreed. :smile:
3. No, and once again, please give a reference other than yourself. I have never seen such a [*] description in any entanglement swapping paper [**]. If the entanglement swap is not executed at 2 & 3, as I indicated above, the far separated 1 & 4 will not be entangled - contradicting your purely local [***] characterization.
Once 1 & 4 are entangled, they are mirrors of each other and have quantum properties that far exceed what 2 otherwise independently created particles could ever have. Of course, they are now part of a quantum system and are no longer separable. You could never construct such a system of 2 particles otherwise as you could never know that many non-commuting observables. Zeilinger says, of the 2 entangled particles that never interact:
"The aim is that the distant experimenter Bob [looking at photon 4] obtains an exact replica of that particle. It is evident that no measurement whatsoever Alice [looking at photon 1] might perform on the particle could reveal all necessary information to enable Bob to reconstruct its state."
That doesn't happen because of post-selection! That should be obvious. There are NO such 2 particles that can be independently created and later post selected (they must be entangled, and cannot be entangled with any other particle). That is strictly forbidden by the HUP. The mirror particles (the ones projected into the singlet state) have the mirroring values for non-commuting p and q, for example. They must be physically connected as part of a single, non-separable, quantum system. It's non-local in spatial extent.
4. The humorous element is that you completely ignore everything Zeilinger actually says, and then recast his viewpoint to match yours. Zeilinger does not claim to have an understanding of the mechanism by which quantum nonlocality operates (and I don't either). But he would never refer to QM as being local causal, and I certainly can't recall a respected paper of the last 20 years using any terminology similar to yours.
And please, despite our going back and forth on the subject, I hope you would not take our discussion as anything other than friendly. :smile: :smile:*Let's just say "contrived".
**And I've read a few.
*** Seriously, it's 2019 my friend. Quantum non-locality was generally accepted some time ago.
  • #51
The problem is that this terminology is used all the time. It's hopeless to change terminology which is established for nearly 100 years. That makes the debates about the foundations so difficult.
  • #52
DrChinese said:
1. Finally! :smile:
2. Agreed. :smile:
For sure, I think this is a completely friendly discussion, and I think all there is is a misunderstanding between our points of view due to different understanding of unsharply defined words.
The most puzzling thing for me is our disagreement about 3. I also don't see that my viewpoint is any different from what's written in the paper by Zeilinger et al which we discuss here.
Again ad 3). In the paper they emphasize themselves that in order to get a preparation of a subensemble, where the pair 1&4 is entangled is the sufficient locality of the manipulations/measurements on the pair 2&3. The Bell measurement of 2&3 must be made such that it's happening in a sufficiently small space-time region to be within the temporal and spatial coherence lengths of the photons. Thus I agree with both you and the authors of the paper that the entanglement swapping won't work if you don't match this constraint.
The photons 1&4 have never causally interacting and are nevertheless entangled after the entanglement-swapping procedure. We also agree on this, and I never denied that quantum states can describe "non-local correlations through entanglement". I emphasize however, that it describes "correlations" not "causal connections". As I said, I think our mutual misunderstanding is due to the unsharply defined meaning of these words.
Finally, I don't believe that physics is about understanding some "mechanism". Whatever that might be. Quantum theory as any physical theory describes (admittedly in a quite formal way) phenomena, and all there is to understand is this formalism and how it's applied to phenomena. The very fact that Zeilinger et al can invent all their beautiful experiments which finally all confirm QT shows that they have very well understood QT. There's nothing more to understand! Just take the formalism seriously, and this formalism is in some sense a miracle, making the long-range correlations described by entanglement and the implied "inseparability" on the one hand consistent with Einstein causality through the microcausality constraint of relativistic QFT on the other hand!
  • #53
Why's it obvious that entanglement can't be created via a quantum post-selection procedure?
Imagine that you've already performed some Bell tests on 1&4 and you have the results in front of you. With those results you should be able to classically select pairs so that those results seem to violate a Bell inequality. However, because you've measured them, at this point the entanglement correlations are broken.
I think what's happening in this experiment is almost the same thing but unlike with the classical example, it doesn't reveal the measurement results for 1&4, so they can maintain their entanglement. Initially, even without any interaction, there is a sub-ensemble of 1&4 which is entangled along a chosen direction. Maybe it's correct to say every pair of identical particles is entangled along a random direction. Then you use the quantum post-selection procedure on pairs 2&3 to identify an appropriate sub-ensemble of 1&4.
Likes vanhees71
  • #54
Exactly!
In other words: You can post-select the subensemble 100 years after the experiment was done provided you have a sufficiently complete measurement protocol. There's nothing mysterious in this as long as you don't insist on the collapse interpretation in the sense of a causal action at a distance as some Copenhagen flavored interpretations insist upon but interpret entanglement as a description of very strong correlations between parts of a quantum system.
  • #55
DrChinese said:
*For example: The entanglement swap can occur such that the entangled photons never co-exist. So obviously the entanglement did not occur at their creation - they were not created together (as you proposed). Variations on entanglement swapping wreck attempts to describe in terms of locality and/or (micro)causality.
Entanglement Between Photons That Have Never Co-existed
When photon 1 is measured in a certain basis the correlation with photon 2 is break.
Photon 2 is delayed until a second pair (3–4) is created and photons 2 and 3 are projected onto the Bell basis.
When photon 2 is projected, with photon 3, onto bell basis (Bell measurement), will the entanglement swapping still be realized ? Since photon 2 has lost its correlation with photon 1.
/Patrick
  • #56
Then it won't be realized. That's the whole point of the discussion! To get entanglement swapping it is necessary to measure "locally (in space and time!) enough" to be within the coherence lengths of the photons. If you perform the measurments on 2&3 at a time where 2 is no longer entangled with 1 and/or 3 no longer entangled with 4, all you get are uncorrelated photons 1&4, no matter what you meaure on photons 2&3.
  • #57
Ha, perhaps not obvious because of my poor description. :smile:
They can't be created by post-selection! Post-selection (as an explanation for what is occurring) implies that these 2 photons - 1 & 4 - are occasionally and randomly entangled (with each other); and then post-selection simply reveals that entanglement. That's a reasonable hypothesis, but here's why that is absolutely impossible.
A. You can create 2 photons that have the same polarization (at a specific angle), for example light from a laser, but a test for entanglement will fail on those. There are a number of mechanisms for creating entangled pairs; here, pair 1 & 2 are entangled via PDC and 3 & 4 are as well. In fact they are maximally entangled. You may recall there is something called "monogamy of entanglement". That says that if photon 1 is maximally entangled with photon 2, then it CANNOT be entangled with photon 4 or with any other particle in the universe.
B. Now you run into our problem: what happened to cause 1 & 4 to become entangled - meaning that ANY observation on one tells you the matching value of an observable on the other? That state for 1 & 4 only occurs IF they were entangled, there is no other quantum state that yields the same results. So what could possibly have occurred to cause this state? "Something" must have happened to change all that!
C. I say (and this simply follows the rules of entanglement swapping, see the cited paper for more detail):
- Photons 1 & 4 were entangled as a result of a decision to cast them into a Bell State (by action on photons 2 & 3), else they weren't entangled at all.
- The mechanism for entangling 1 & 4 is to bring 2 & 3 together in the Bell State Analyzer (BSA) and perform a Bell State Measurement (BSM) on them. Some of the 2 & 3 pairs will randomly be cast into a Bell State which indicates that 1 & 4 are now entangled.
- Such only happens if 2 & 3 are completely indistinguishable. In the experiment, that occurs when they arrive at the BSA within a very small time window, perhaps within 5-10 picoseconds. They must also show up in different arms (different PBS) of the BSA, after passing through a common Beam Splitter (BS), as that indicates a Bell State.
D. If the vanhees hypothesis were correct (local causality, no physical collapse, his minimal interpretation where observations reveal pre-existing attributes):
- Photons 2 & 3 are speeding towards the BSA and whatever happens (or doesn't happen) at the BSA cannot change photons 1 & 4 because they are spacelike separated from the BSA.
- Photons 1 & 4 are NOT yet entangled with each other, because they are entangled with 2 & 3 respectively.
- The 2 & 3 photons enter the BSA around the same time (within a very small window), but they generally cannot interfere or otherwise interact with each other. So presumably, whether they are going to register as meeting the conditions for a Bell State (psi+ or psi-) has already been determined and the BSA reveals the appropriate detector clicks to so indicate.
E. And now we have big problems with no good answers (although you can try):
i) How (and when) did photon 1 lose its entangled connection to photon 2? Presumably that occurs when photon 2 is measured, correct? But then it no longer exists!
ii) How (and when) did photon 1 gain an entangled connection to photon 4? After all, we have postulated it was previously entangled with photon 2 and photon 2 alone (due to monogamy). And nothing is changing for its state, as it is too far away.
iii) More importantly, why would photon 4 - out of all the particles in the universe - suddenly have this unique and monogamous connection to photon 1? (Remember: attributes such as momentum (frequency), polarization, etc. are all part of the entanglement.)
I would hope these problems would convince you of the futility of the hypothesis. There is no narrative described in any paper I have read that remotely matches the vanhees hypothesis (I've asked and asked without any success for a reference). But if E. didn't convince you...
F. Furthermore: If you accept the vanhees hypothesis, then the detector clicks at the BSA are revealing pre-existing attributes of the 2 & 3 pair which is to be used to identify Bell States. And critically, photons 2 & 3 do not interact in any way, as mentioned above. So if we were to delay photon 2 from arriving at the BSA by (say) 100 ps, that should not in any way affect the detector click outcomes at the BSA other than to have one of the clicks occur about 100 ps later than the other. Here's how it might look for the relative detection time stamps, and I am making up simple time stamps for purposes of illustration:
No delay:
Detector 1V: 1000000ps (photon 1)
Detector 2H: 1000003ps (either photon 2 or 3, not sure which)
Detector 3H: 1000004ps (either photon 2 or 3, not sure which)
Detector 4V: 1000002ps (photon 4)
Add in a 100ps delay to the photon 2 path to make it distinguishable from photon 3:
Detector 3H: 1000104ps (this must be photon 2, which now makes the 2H detector click due to photon 3)
You can see that this should NOT identify different 2 & 3 pairs if the BSA is revealing pre-existing properties of those photons. The only difference is that 2 is easily identified. To put this in perspective: 4-fold coincidences similar to the above only occur every few seconds on the average. That would place the next occurrence perhaps 1000000000000+ ps later than my example. Not much chance to get confused about which clicks belong together.
Of course: if 2 & 3 are distinguishable, the rule is that there is no entanglement swap. So 1 & 4 are not entangled, and now demostrate Product State statistics which are clearly different than Entangled State statistics. But we postulated their polarizations were simply being revealed, and nothing occurring at the BSA changed anything. But actually: choosing to add a delay to the photon 2 path does change the 1 & 4 statistics, and that occurs both non-locally and without any causal direction in time. QED.
Likes Auto-Didact and akvadrako
  • #58
Really? Everybody uses "local" to mean "microcausal"?
That certainly isn't true of Bell's original paper or the copious literature it has spawned; in that literature, "local" means what Bell defined in his original paper (that the joint probability function factorizes). That definition has nothing whatever to do with causality, or with QFT.
Likes Auto-Didact, zonde and DrChinese
  • #59
So you say the cited paper by Zeilinger et al is fake? I don't believe that!
Again: Before the described selection by the (local) manipulations of photons 2&3 the photons 1&4 were not entangled because the initial state the four photons are prepared in are factorizing in the following way
$$|\Psi_{1234} \rangle = |\Psi_{12} \rangle \otimes |\Psi_{34} \rangle.$$
The two-photon states ##|\Psi_{12} \rangle## and ##|\Psi_{34} \rangle## are maximally entangled (Bell states) but the pair 1&4 are not. This state now describes and ensemble of equally prepared four photons, and this preparation is described by this state and nothing else.
Now if you do the described manipulations on photons 2&3, however, and select (or post-select, which doesn't matter at all) an subensemble, i.e., after choosing only those photon pairs 1&4, for which the pair 2&3 was found in one of the maximally entangled Bell states, then this subensemble of photon pairs 1&4 is described by a maximally entangled Bell state ##|\Psi_{14} \rangle##.
The subensemble can be chosen whenever you like after the experiment is done and an appropriate measurement protocol is taken. The possibility of postselection due to entanglement is more explicit in the famous quantum-erasure experiments a la Wheeler, now realized several times with photons (e.g., Kim et al or Walborn et al).
  • #60
That's precisely what I mean. Bell talks about correlations and (in)separability, while in QFT locality has a different meaning, namely locality of interactions and thus microcausality. That's what's confusing, and that's why one has to read each paper in context. This confusion is why some people think Bell's non-locality would contradict the QFT-meaning of locality, but that's NOT the case!
The most accurate experiments are done with entangled-photon state, and if anything gets relativistic it's photons. The experiments are analyzed with standard QED, which is a microcausal QFT, and as long as there's no contradiction between experiment and QED I believe that relativistic QFT is consistent with both locality of interactions (microcausality and thus Einstein causality) and the fact that there are non-local correlations described by entanglement and inseparability.
What's not so clear to me is whether Bell was convinced that QT (no matter whether relativistic QFT or non-relativistic QM) is wrong and there's some local hidden-variable theory being right and QT being wrong or not. Before Aspect that could well have been possible, but after his experiments and the much more accurate ones possible since then, I think that's out of the question.
  • #61
"Microcausality" in QFT means operators at spacelike separated events commute. That in itself does not mean the same thing as "locality of interactions". You could have as many nonlocal interactions as you like, as long as the outcomes of spacelike separated measurements do not depend on the order in which they are performed.
Likes Auto-Didact
  • #62
Then define what you mean by "locality of interactions". The very reason to use the constraint of microcausality in fact is to have local interactions only, i.e., you build the interaction Lagrangians as integrals over local operators obeying the microcausality contraint. This is at least sufficient for locality. I'm not sure whether it's also necessary, but the Standard model, including QED, is using the microcausality constraint anyway.
  • #63
I didn't introduce the term so I feel no need to define it.
I already gave my definition of "locality": it's the one Bell used in his paper.
But those operators also have to obey a nonlocal constraint: they have to commute with other operators at spacelike separated events.
Likes Auto-Didact
  • #64
This is of course fulfilled either, because you build the local observables from quantum fields obeying bosonic or fermionic commutation or anticommutation relations, respectively. Then the observables built up from them are all obeying the microcausality constraints.
Again, the only point I want to make is that you have to clearly specify whether you mean locality in the sense of interactions/microcausality or in Bell's sense, where it means separability.
I really don't understand what you are after.
  • #65
I don't get this, where do I say the paper I cited is fake? I realize that English may not be your first language, but this is a bit extreme.
Post selection identifies the 4-fold events to be analyzed. What I said is that the post selection process itself does NOT create the entanglement. Zeilinger says nothing different, and if he does, feel free to point that out.
And I again call for a narrative from ANY entanglement swapping experiment that describes the swapping action as you do. Specifically: your opinion that it is local and causal, nothing happening at the BSA that causes the swap.
Entanglement swapping IS due to the Bell state cast which non-locally affects photons 1 & 4 (changing Product state stats to Entangled state stats), and the entire process lacks any semblance of a causal direction. Ordering has no bearing on the outcomes.
  • #66
You were arguing with @DrChinese about whether QFT is "local". You were actually in violent agreement with him, because he was using "local" the way I am using it (Bell's definition), but you were using "local" to mean "microcausal", and both are true; QFT is microcausal, but it violates the Bell inequalities. If you had just left out the word "local", there would have been no argument.
  • #67
vanhees71 said:
1. Now if you do the described manipulations on photons 2&3, however, and select (or post-select, which doesn't matter at all) an subensemble, i.e., after choosing only those photon pairs 1&4, for which the pair 2&3 was found in one of the maximally entangled Bell states, then this subensemble of photon pairs 1&4 is described by a maximally entangled Bell state ##|\Psi_{14} \rangle##.
2. The possibility of postselection due to entanglement is more explicit in the famous quantum-erasure experiments a la Wheeler, now realized several times with photons (e.g., Kim et al or Walborn et al).
1. There are no papers that say that 4-fold coincidences simply "reveal" entanglement properties of 1 & 4 that were pre-existing. They all say that decision to project them into a Bell state - or not - is what is responsible for 1 & 4 entanglement. The below quote from the cited paper is a good example that confirms my description and rejects yours:
"We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4."
That is diametrically the opposite of what you describe, which is that 1 & 4 are correlated if 2 & 3 click a certain way. They aren't, the swap must occur for that to happen. Please note that the action is called "entanglement swapping" because photon 1's entangled partner changes from photon 2 to photon 4. Nowhere is the process of projection, casting, swapping referred to in terms that imply pre-existing relationships are being "revealed".
And if you can address my example F. in my post #57, that would be on target. Ditto for explaining why entanglement monogamy doesn't prevent 1 & 4 from being entangled while 1 & 2 are. I look forward to that.
2. Try referencing something a little more modern... and relevant. We are not discussing quantum erasers in this thread. We are discussing entanglement swapping using independent PDC sources.Again, please QUOTE a suitable citation for your position - or retract it. If you are correct, and this is standard QFT, such quotes must be everywhere. I would let this drop (since I know I won't change your opinion regardless of what I cite) but there are plenty of others who are following who are drawing a completely wrong picture of things because of what you are saying. People are drawn to local causality, but the whole point of entanglement swapping experiments is to show in the strongest of terms that position is not tenable in any form.
  • #68
This is also something I would like to know. At the very least, it should be possible for 1 to be entangled with 2, while (1&2) is entangled with (3&4), but that doesn't seem like this case. Maybe monogamy of entanglement is only about "known" entanglement; after all, having two qubits entangled along random directions isn't a useful resource.
Regardless of the outcome of this discussion, this really hasn't been shown in a convincing manner. Some MWI and anti-realist proponents say QM has been shown to be locally causal. Not everyone agrees those proofs are convincing, but the opposite also hasn't been generally accepted either. If entanglement swapping provides a clear argument against local causality, it should be better explained.
  • #69
akvadrako said:
1. This is also something I would like to know. At the very least, it should be possible for 1 to be entangled with 2, while (1&2) is entangled with (3&4), but that doesn't seem like this case. Maybe monogamy of entanglement is only about "known" entanglement; after all, having two qubits entangled along random directions isn't a useful resource.
2. Regardless of the outcome of this discussion, this really hasn't been shown in a convincing manner. Some MWI and anti-realist proponents say QM has been shown to be locally causal. Not everyone agrees those proofs are convincing, but the opposite also hasn't been generally accepted either.
1. No, absolutely not possible if 1 & 2 are maximally entangled (which they are when exiting the PDC crystal). You can entangle N number of quantum particles (no specific limit), but they will not be maximally entangled in that case. In fact, PDC occasionally produces 4 entangled photons - but again, no 2 are maximally entangled.
2. Post Bell, local realism has been roundly excluded along with most variations of same (depending on your particular exact definition, of course: local causality, local determinism). And yet many physicists are completely unaware of swapping, and how far the swapping experiments have come. There's no one that "needs" to be convinced, but what I am saying is a direct reflection of the mainstream. As a note: Because I am a Science Advisor, I try to label any non-standard opinion I hold as such. Of course, like vanhees71, I still think my personal opinions are correct too. :smile:
Likes vanhees71
  • #70
The document has been published at PHYSICAL REVIEW LETTERS
Here it is write :
To prove it, the researchers first used a laser to cause entanglement between a pair of photons, P1, P2. They then measured the polarization of P1, which was immediately followed by the entangling of another pair of photons, P3, P4. This was followed by measuring P2 and P3 simultaneously and causing them to become entangled with one another—a process known as projective measurement. Then, P4 was measured. Measuring P1 caused its demise of course—before P4 was born—but the measurement of P4 showed that it had become entangled with P1 nevertheless, if only for a very short period of time.
No one said anything?
/Patrick
  • Quantum Interpretations and Foundations
10K
9K
18K
27K
