Current in a Complicated Circuit
  • Thread starter Thread starter Cefari
    Circuit Current
The discussion revolves around determining the current in a 2 ohm resistor within a complex circuit, given the current in an 8 ohm resistor and various resistor values. The problem involves applying Ohm's Law and understanding the relationships between resistors in series and parallel.
  • The original poster attempts to find the current through the 2 ohm resistor by analyzing the circuit configuration and applying Ohm's Law. Some participants question the assumptions regarding voltage across different resistors and the implications of parallel versus series connections.
Participants have engaged in a back-and-forth regarding the calculations and relationships between the currents and voltages in the circuit. Some guidance has been offered regarding the use of Ohm's Law and the interpretation of voltage drops across resistors. There is an ongoing exploration of the circuit's behavior without a clear consensus on the final current value in the 2 ohm resistor.
There is a noted uncertainty regarding the total voltage supplied by the battery, which affects the calculations. The original poster's approach relies on the current values provided and the assumption of how resistors interact in the circuit.
Cefari
In the figure, the current of the circuit in the 8 ohm resistor is 0.5 A. What is the current in the 2 ohm resistor?
Figure http://img181.imageshack.us/img181/5576/helpfk7.jpg
I'm trying to solve for the current in a complicated circuit. I'm given R1 = 16ohms, R2 = 8ohms, R3 = 20ohms, R4 = 6ohms, and R5 = 2ohms. Also, the question for the problem states that the current in R2 = 0.5 A
Ohms Law: Potential Difference = Current(Resistance)
Formula for Resistors in Series: Rt = R1 + R2 + R3...
Formula for Resistors in Paralell: 1/Rt = 1/R1 + 1/R2 + 1/R3
I'm not sure how to go about finding the current through R5 without knowing the voltage of the battery. But I think I may be able to figure this out by trying to compare R2's current with the entire circuit.
Idea 1:
R1 is twice R2, and being in parallel, R1 receives half R2's current.
So R1 has a current of .25 A.
Then from here somehow figure out how to find the current in R5.
Idea 2:
Using Ohm's law I can find the voltage in R2 V=0.5(8), V=4v.
Then applying it to R5, 4v=I(2), I=8 A.
You know the current through R2, it's given. You know the current through R1, as in your Idea 1. You thus know the total current through R3 (it's the sum of the currents through R1 and R2).
You can use Ohm's law to find the voltage across R2, and the voltage across R3. The sum of those two voltage drops is the voltage from the battery. From there, it's pretty straightforward.
Your idea 2 is incorrect, because the same voltage is not applied to R2 as to R5 -- these resistors have different nets at their right hand terminals! Instead, the voltage applied to the entire "subcircuit" of R1-3 is the same as that applied to the entire "subcircuit" of R4-5, because each of these "subcircuits" is wired in parallel to the battery.
- Warren
Alright so my reworked solution is as follows:
Current of R1 = 1/2 Current of R2 so, Current of R1 = .25 A
Current Through R3 = Current through R1 + R2 so, Current of R3 = .75 A
Voltage through R2 = .5(8) = 4v
Voltage through R3 = .75(20) = 15v
Battery Voltage = 4v+15v = 19v
V = IA
19v = I(2)
9.5 A = I
V = IA
19v = I(2)
9.5 A = I
That looks right. Good job.
Thank you both for the help. :approve:
