Electrostatic Force of a hydrogen atom
The discussion focuses on calculating the electrostatic force between an electron and a proton in a hydrogen atom model, where the electron orbits the proton at a radius of 5.3x10^-11m. The relevant formula for this calculation is F=kq1q2/r^2, where k is the electrostatic constant. Participants clarify that the charges of the electron and proton are both ±1.6x10^-19C, which are standard constants. One user expresses confusion about the origin of these charge values, highlighting a lack of information in their textbook. The conversation emphasizes the importance of understanding fundamental constants in physics calculations.
MemoIhad
[SOLVED] Electrostatic Force
One model of the structure of the hydrogen atom consists of a stationary proton with an electron moving in a circular path around it.The orbital path has a radius of 5.3x10^-11m. The masses of a proton and an electron are 1.67x10^-27kg and 9.1x10^-31kg, respectively. Calculate the electrostatic force between the electron and the proton.
F=kq1q2/r^2
I looked at the question but I really didn't know where to start since none of the qs (charges) where given. I looked at the solution and I found that they used 1.6x10^-19C as the charges, so the equation subbed in looked like this: k(1.6x10^-19C)^2/r^2.
I don't understand where or how they got 1.6x10^-19C. Any help will be appreciated! :smile:
-1.6x10^-19 C is the charge of one electron and is a constant. The charge on a proton is +1.6x10^-19 C.
O, Ok, I understand. I was looking around the book for something like that but couldn't find it. Teacher didn't even bother to mention it.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
