Fluid Mechanics: Choosing a fuel line diameter for a required pressure drop
The discussion focuses on selecting the appropriate fuel line diameter to achieve a specific pressure drop in fluid mechanics. Participants emphasize the importance of using the correct pressure drop equations and understanding the flow conditions, particularly distinguishing between laminar and turbulent flow. A significant point raised is the need to calculate the Reynolds number to determine flow characteristics accurately. There is confusion regarding the realistic values for flow velocity and diameter, indicating a lack of familiarity with the equations related to pressure drop and friction factors. Overall, a deeper understanding of fluid mechanics principles is necessary to solve the problem effectively.
NickH21
[/B]
- The pressure drop equation. [/B]
Hi NickH21,
Your thread title is too general. Please make sure that your thread title is descriptive of the actual problem so that the Homeowrk Helpers with the correct skill set can quickly spot your thread. This time I will change your title to read: 'Fluid Mechanics: Choosing a fuel line diameter for a required pressure drop'.
Can you type out your Relevant equation(s) and define the variables? There are several possible pressure drop equations.
Can you explain where the numbers come from in your attempt? There isn't an obvious correlation between them and the given values in the problem statement; is there more work you haven't shown?
Also, Please take a moment to read the thread, Guidelines for students and helpers, which you can find pinned at the top of each of the homework forums. It gives an overview of how to create an effective homework help request following the posting rules.
P=32 x w x Vavg x L / D^2
You seem to be assuming you have laminar flow, when the problem statement strongly hints that the flow is turbulent. Have you calculated a Reynolds number?
Yes. I’ve got my Reynolds number, but that’s where I’m confused at. I just don’t know where to go from there.
Are you familiar with how to get the pressure drop in pipe flow using friction factor and Reynolds number?
Where did you get that value for the diameter from?
Do you really think that a flow velocity of 524 m/s is realistic?
I’m not to sure how to find the pressure drop with the friction factor. I’m not familiar with that equation.
Then you need to find out about it in your fluid mechanics book, or wherever this problem came from.
