Hello, can somebody check my transistor amplifier schematic?
80 replies · 8K views
Can you post your Multisim circuit with the DC operating points labeled? If the simulator can analyze circuits, it can show the DC operating points that it calculates at the start of a simulation...
Good. Simulating circuits is much more commonly done in some variety of SPICE. It looks like Multisim is targeted at simulating larger systems (including circuits -- I wonder if they use some standard Berkeley SPICE engine to do that part of their simulations)...
Goodmorning, i do it, everytime he simulated, now is not working
Sorry i fall again in sleep, what is Berkeley SPICE, do you know any good spice software which are able to do this? so maybe i can download, i make dc point agan but is blocked now
here is dc points current and voltages
It seems incongruous to have a 220uF cap in the middle of a HF oscillator (C1).
C2 = 220uF is clearly a mistake. 220pF maybe, but an electrolytic would have a higher inductance than the tuning inductor.
I began to model the circuit with LTspice but have not made it oscillate yet.
Hello, realy, why in ads 2012 he worked, i also download simetrix simulation i built and i get error dcop(error)
i am try to download ads 2012 and to build and to see….
I rey also 220p but is not working
michael1978 said:
I did not do it in ltspice because i start with varicap, and i did not find the model and i stop
You do not need a varicap to check this circuit. Just use a fixed capacitor, then you can step that parameter value.
Some oscillators won't, because of the numerical stability and the perfection of the SPICE model, so it takes a kick to get them going. Sometimes a big kick will give some idea of where the losses are and why it is so dead.
At other times only the smallest tickle is needed which is the case with this Clapp oscillator SPICE model. One solution is to set a starting current of say 1 uA in the first tuned circuit by using an initial conditions statement, for example;
.IC I(L1)=1u0
This circuit may start without a tickle, it depends on your partricular simulation parameters. Frequency is about 100 MHz.
The pattern is a beat between the pixel pitch and the 100 MHz sinewave.
Two LTspice files attached, remove the .txt extension to run.
Thank you lottttt sirr
Hello sir, how you did please, how you find the corrected transistor and varicap, i am jeloze:biggrin: than i don't know,
I did NOT find the right components, I just made it work well enough to test. I could make the components if I needed them.
I selected the transistors because they will work in that application at 100MHz, they are not optimum.
I did not try to model the varicap as it is not needed to test the design.There are only two varactors in the Ltspice standard library. It is there on the diagram as a "place-holder".
There are many sources of extra models for LTspice. You can edit components from other versions of spice.
You could join the Ltspice group. https://groups.yahoo.com/neo/groups/LTspice/files
then watch https://groups.yahoo.com/neo/groups/LTspice/conversations/messages
See also; http://ltwiki.org/?title=Main_Page
http://www.analog.com/en/design-center/design-tools-and-calculators.html
Ohh Man is difficult for me, i don't have experience, but i working cool a,
may i ask you someing did you here about simetrix spic i did the same like you did
and i get strange waveform
This looks like spurious oscillation at a much higher frequency. This is why RF engineers are special people.
You want to say is correct waveform?
michael1978 said:
may i ask you someing did you here about simetrix spic i did the same like you did and i get strange waveform
It looks to me like the circuit simulation is switching and ringing. Maybe SIMetrix is trying to make it switch like the switching-power circuit SIMetrix is designed to simulate. Apparently SIMetrix runs much faster than Spice, which might explain why it gets it so wrong.
I have not used SIMetrix, nor do I know the circuit or simulation parameters that you have used.
Hello sir, i find good software, and i have gratis version 7.2 intro,, if you want i can send you...
sorry i make you tired, i make the same like your circuits i just change the transistor bfg520/PS
I configure SEE THE PICTURE
I change the resistor to bf199 and i get this(the same configuration)
It is hard to read your diagrams, but your C10 looks like 6.8pF. Increase that to 47pF, connected to ground. Open circuit the V3 source and run the simulation for 100usec. If it does not then start and run, you must experiment with a V3 pulse of 100mV or an initial current of maybe 100uA in L1=100nF.
Find the initial current or pulse needed to make it ring then die. That tells you the phase and gain are insufficient to sustain oscillation. Find out how sensitive it is to small changes in component values. Adjust one component at the time to make it ring at about the right frequency for a longer time. When you have sustained oscillation, reduce or remove the initial current used to initiate the oscillation during testing.
do you have simetrix, i can gi
To which circuit with bc199 or bfg250?because i have 2 one with bc199 and the other with bfg250? i change c10 to 47p is more better waveform, do you have any software i can send you my file, and to run not 5u but 100usec, and to change only the voltage of v3 righ?
I do not need SIMetrix and I do not have time to learn to use it.
I have Ltspice, which works for me and is free. It has a big user group, forum and library.
If SIMetrix works for you, keep using it. If it does not work, switch to LTspice.
Transistor selection is not critical in that circuit. The transistor simulation model may be important.
But i try to bc199, in begin let say 4sec and is about 1.4VPP is good sinus waveform, after in the middle he change the waveform in bigger plus not normal waveform like i told you, NO SIR please don't misundersand me i thougt you know because they are spice, ok sorry what i said, you said to connect to ground C10 47P, and to change L1 to 100uA and V3 where to leave it?
I suspect that the spurious oscillation comes from the emitter follower. Try it without.
I also notice that the 220pF capacitors are unusually large for 100MHz. In practice, this might cause trouble due to unwanted resonances involving the self inductance of the component.
Also, I cannot see any purpose in C3.
I have usually found that the fewer components in the oscillator circuit the better, and I especially do not like the use of a resistor in the emitter of Q1 as it is shunting the tuned circuit. I have found the Hartley circuit to require fewest components and be the most reliable.
michael1978 said:
... and V3 where to leave it?
Keep V3 on the diagram, but make it open circuit. Keep one side grounded, the other side is no connection.
Apologies, I realize it is a DC block.
Ah ok i do it now
I will like to do what Balunce say
No Sir, is not sinewave, is the same like i told you before, why he don't work in Gods Name:headbang:
but this circuit was working in ltspice, the transistor is now bf199 or bfg520/P nothing changes, only transistor
michael1978 said:
Ah ok i do it now
I change capacitor from 47P, 4.7p, and i chan 5u the transisent is sinewave good, but if i make 10u he destroyd after 5u in bad wafeform
