Induced Emf in Rectangular Loop Problem
To find the current flowing in a rectangular loop being pushed into a magnetic field, the induced electromotive force (emf) can be calculated using the formula emf = vBl, where v is the speed, B is the magnetic field strength, and l is the length of the loop in the direction of motion. The resistance of the loop is given as R = 200Ω. The emf calculated was 0.0064 V, leading to a current of 3.2 x 10^-5 A using Ohm's Law. The discussion highlights the application of Faraday's law to determine the rate of change of area (dA/dt) as wv, where w is the width of the loop. Understanding these principles is crucial for solving similar problems involving induced emf in different loop shapes.
ethanabaker1
"You push a rectangular loop of width .2m, length .8 m, and resistance R=200\Omega into a magnetic field (out of page) Bout=.4 T and a speed v=.2 m/s. The long side of the rectangle is parallel to the x axis. What is the current flowing in the loop?"
I think I should use:
Emf=vBl
Ohm's Law - \DeltaV=IR
Using the equation emf=vBl, I did emf=(.02)(.8)(.4)=.0064.
Then I said that emf=\DeltaV, so using Ohm's Law I did \frac{.0064}{200\Omega} and got 3.2 x 10-5 A as my answer.
My problem is that the only problems we've worked are for circular loops and I'm not sure what length to use for l.
Emf=vBl
Your equation is derived from Faraday's law. So apply Faraday's law explicitly:
emf = \oint \vec{E}\cdot d\vec{s} = \frac{d\phi}{dt} = B\frac{dA}{dt}
All you have to do is work out dA/dt, the rate of change of the area enclosed by the loop. If l is the distance along the x-axis through which you have pushed the loop and w is the width of the loop what is dA/dt?
AM
How would I do this algebraically?
Since dA = wdx and w is constant, then dA/dt = w(dx/dt) = wv
So emf = Bwv
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
