What is the lattice constant of a zincblende structure with two types of atoms?
  • Thread starter Thread starter orangeincup
    Constant Lattice
The discussion focuses on calculating the lattice constant, volume density of valence electrons, and surface density of B atoms in a zincblende structure with two types of atoms. The lattice constant is determined to be approximately 4.73 Å using the formula involving the radii of the atoms. The volume density of valence electrons is calculated as 7.56 x 10^22 cm^-3, while the surface density of B atoms on the (110) plane is found to be around 6.32 x 10^14 atoms/cm^2. Clarifications on the formulas used for these calculations are also discussed, emphasizing the correct units and relationships between the parameters. Accurate calculations are critical for understanding the properties of materials in this structure.
orangeincup
A material contains two types of atoms (A and B) in a zincblende structure. Atom A is group V with a hard sphere radius of 2.5 Å. Atom B is group III with a hard sphere radius of 1.6 Å.
(a) What is the lattice constant of this material assuming that nearest neighbour atoms touch? (working on this one right now)
(b) What is the volume density of valence electrons in this material?
(c) What is the surface density of B atoms on the (110) plane in this material?
a) [/B]Since it's a face centered structure it should have 8X 1/8 + 6* 1/2 atoms, so 4
Is it correct to say ( r1+r2 ) *4 = my lattice constant for A?
No it is not right. If there are 4 units in a cube, how can the side of the cube 4 times the interatomic distance?
this helps http://www.ehow.com/how_8721263_determine-lattice-parameter-zincblende.html
Likes orangeincup
a) (4/3)^1/2*(1.6+2.5) = 4.73 A
b) Volume density of valence electrons is 8/((4.73*10^-8)^3) = 7.56*10^22 cm^3
c) 4/(sqrt2(4.73*10^-8)^2) = 1.26*10^15 atoms/cm^3
How many valence electrons are there in one AB unit? How many units are there in the unit cell?
The surface density is asked, it has atoms/cm^2 unit.
How did you get that formula?
4 *(1/4) + 2*(1/2) + 2*1=4?
I confused it with a volume density formula.
4/(4.73*10^-8)^3) = 3.78*10^22 cm^3 = volume density
sqrt2/((4.73*10^-8)^2)=6.32*10^14 surface density
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
