Solving for Friction Force on a Ramp
  • Thread starter Thread starter chem_is_lovex
    Physics Ramp
To solve for the frictional force acting on a 2.0kg block sliding down a 37-degree incline, first calculate the net acceleration using the distance covered in 1.0 second. The net force can be determined by applying Newton's second law, where the net force equals mass times acceleration. Subtract the gravitational component acting down the ramp from the net force to find the kinetic friction. A free body diagram and equations of motion will aid in visualizing the forces and deriving the necessary equations. This approach will lead to the calculation of the friction force acting on the block.
chem_is_lovex
A 2.0kg block of wood accelerates from rest down a smooth incline at 37o to the horizontal. It covers 1.26m in 1.0sec. Determine the frictional force acting.
uhhh... this is the problem, I don't know what equation to use...
can someone please help me?
Calculate the net accleration to get the net force, then subtract off the component of gravity that is pointing down the ramp. The remaining force is kinetic friction.
If I were doing this problem, I'd:
1. Draw a free body diagram showing the ramp and forces acting on the block
2. Write the equations of motion of the block (i.e. sum F = ma)
3. Integrate twice to get an expression for x = x(t) where x is the distance the block travels down the ramp keeping in mind the initial conditions (hint: accelerates from rest)
4. Since you are given the distance traveled in a specific time, equation (3) can be solved for the friction force
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
