Shear stress, what is a flat tie bar ?
The discussion revolves around understanding flat tie bars and their application in a homework problem involving shear stress. A flat tie bar is described as a flat strip of metal with a rectangular cross-section, connected by a lap riveted joint using three 10 mm diameter rivets. The main concern is calculating the maximum pull that can be applied without exceeding a shear stress of 60 MN/m² in the rivets. Participants emphasize the importance of using the cross-sectional area of the rivets to determine the load, clarifying that stress is calculated as force divided by area. The conversation highlights the need for clear assumptions regarding load distribution and the role of rivets in bearing the stress.
scotthands
shear stress, what is a flat tie bar...?
two lengths of flat tie bar are connected together by a lap riveted joint with three rivets each 10mm in diameter. Calculate the maximum pull that can be applied to the tie-bars if the shear stress in the rivets is not to exceed 60MN/m^2
i can't attempt this because i don't know that a flat tie bar is or what it would look like if they were connected together by a lap riveted joint with three rivets...
does anyone know what it is?
This is a tie bar. http://en.wikipedia.org/wiki/Image:Tieslide.jpg
Well a flat tie bar is flat strip of metal, usually uniform thickness with a rectangular cross-section - basically looks like a ruler, but thicker. The two bars are overlapped and held together by 3 rivets. However that is irrelevant to this problem.
What is relevant is the fact that there are three rivets, each of 10 mm dia, which will bear the load P to be determined such that the shear force does not exceed 60 MN/m2.
State assumptions, e.g. not credit given to the friction in the lap joint of the lapped tie bars, i.e. one assumes the rivets bear the full load. What else?
so have i just to work out P? as in: P=T(tau) * Area
if so then I'm not really sure about the area, do i take the 10mm diameter and work out the area that the rivets go through?(or is it the perimeter of the 10mm diameter the hole that the rivets go through?)
thanks for the help.
The cross-sectional area of the three rivets will bear the shear stress.
The stress is just the load divided by the area bearing that load (force).
Remember stress, which has the units of pressure (lbf/in2, or MPa), is simply force divided by area, whether it's a tensile, compressive or shear force.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
11K
