What is the Specific Heat of the Substance in This Calorimetry Problem?
The discussion revolves around calculating the specific heat of a substance in a calorimetry problem involving a heated sample, aluminum calorimeter, water, and a glass thermometer. The initial temperature of the substance is 330°C, and the final equilibrium temperature is 35°C. Participants clarify that the change in temperature for the substance should be calculated as 330°C - 35°C. It is emphasized that the heat lost by the substance equals the heat gained by the water, aluminum, and glass, and the equation must reflect this conservation of energy principle. Properly applying the negative sign ensures the calculated specific heat capacity remains positive.
Jeylan
A 215-g sample of a substance is heated to 330°C and then plunged into a 105-g aluminum calorimeter cup containing 165 g of water and a 17-g glass thermometer at 12.5°C. The final temperature is 35.0°C. What is the specific heat of the substance? (Assume no water boils away.)
Please, can anybody tell me if I'm doing this right? I got to the certain moment and then I got stock. Heelp! c(glass)=0.84, c(aluminum)=0.900, c(water)=4.2 J/g*C
Tinitial (aluminum)=Tinitial (water)=Tinitial (glass thermometr)=12.5 C?
And Tfinal (al)=Tf(water)=Tf(glass)=35C?
Q(substance)=Q(aluminum)+Q(water)+Q(glass)
Q=mc*(Tf-Ti)
But what is the Tinitial for the substance? We know only 330C and this is final?
215*c*(330-Ti)=105*0.900*(35-12.5)+165*4.2*(35-12.5)*17*0.84*(35-12.5)
The 330 degrees is the initial temperature of the substance. When it is placed in the calorimeter its temperature will come to 35 degrees since the system is in equilibrium.
So, everything else is right? Then change of temperature is equal to 330-35? Or 35-330? And then I just calculate c from the equation?
thanks for help!
If you define the change in temperature as ∆T = Tf - Ti , which do you think it is?
I think your terms are OK, but just remember that the heat lost by the substance equals the heat gained by the water+aluminum+glass.
Thank you! That's why it's going to be minus! I just got it!
Well it shouldn't be minus, specific heat capacity can't be negative! What I meant was that
(heat lost by the substance) = - (heat gained by water+aluminum+glass).
This is the proper way to write your equation (conservation of energy applies). So if you put the minus in your answer will come out positive, as it should.
You're welcome, by the way. :smile:
