What Are the Solutions to This Two-Block System Problem?
  • Thread starter Thread starter mayeh
    Law Motion
The discussion focuses on a physics problem involving two blocks connected by a cord over frictionless planes. Participants suggest analyzing the forces acting on the blocks, particularly the tension and gravitational forces, to determine the system's movement direction. It is recommended to make an initial guess about the acceleration's direction and solve for it, as a positive result confirms the guess. Additionally, comparing the forces acting on each mass can help clarify the direction of movement. The conversation emphasizes problem-solving strategies for understanding the dynamics of the two-block system.
mayeh
two blocks CONNECTED by a cord over a frictionless planes, (for illus. see the fig. below) (a) which way will the system move when the blocks are released from rest?
(b)what is the acceleration of the blocks
(c)what is the tension in the cords?
<a href="http://www.imagevimage.com/gallery.php?entry=images/sa.JPG"><img src="http://www.imagevimage.com/thumbs/sa.JPG" border="0" alt="" /></a>
http://www.imagevimage.com/images/sa.JPG
I still don't have any attempted solutions since i can't figure out which direction will the system go.. pls help..
Well, you can try finding the force applied by tension along the slope of the wedge, and then comparing with the force of gravity on the blocks along the slope. Since the string is the same, the tension along the string will be uniform.
You don't need to know the direction of the acceleration ahead of time. Just guess a direction, call the acceleration "a", and then solve for it. If it comes out positive, you guessed correctly; if negative, it's opposite to what you assumed.
(You can also figure out the direction by comparing the force pulling each mass down the plane.)
thanks! i'll try that..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
