Electronics circuit design programs
For beginners in electronics circuit design seeking virtual programs, Spice-based simulation packages like LTspice are recommended for obtaining voltage inputs and outputs. Users can quickly learn to simulate simple circuits and utilize features like oscilloscopes and function generators. LTspice is noted for its power and free access, with ample online support available. While ISIS Design allows for sine wave generation, it lacks the capability to display Vin and Vout for varying frequencies. Exploring these simulation tools can enhance the learning experience without the need for physical equipment.
luigihs
Hello,
Im kinda of new beginner I am looking for virtual program to get Voltage in and Voltage in a design circit using the oscilloscope and function generator, I using ISIS Design and I can get the oscilloscope getting the sine wave, and the function generator that helps to change the frequency but it doesn't give me the Vin and Vout for that frequency. Does anyone know any helpful program? because I don't have at home function generator and oscilloscope I want to use something virtual. Thanks a lot!
luigihs said:
Hello,
Have you looked at some of the Spice based circuit simulation packages? There's a bit of a learning curve for more advanced uses, but you should be able to get going with simple circuits in a few minutes. Do a web search for LTspice. It's very powerful, free, and there's lots of support from other users to be found on the web.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
