Troubleshooting a FBD of a Pulley
The discussion focuses on troubleshooting the free body diagram (FBD) of a pulley system to determine the tension in segment DEC. The user understands the reaction components at point A and the tension in segment BE but is confused about the force equation involving the term 2(4/√96)T. This term arises from the symmetry of the system, indicating that twice the tension is needed, but the origin of the 4/√96 ratio is unclear. It is suggested that this ratio relates to a triangle formed by points C, D, and E, with the coordinates of these points being crucial for further calculations. By projecting the plane CDE onto the y-z coordinate plane, the user can determine the position of point E and subsequently calculate the length of line DE.
STEMucator
I'm having a bit of trouble understanding something from this:
http://gyazo.com/88a466b57d8516d2df1b12008947be43
I understand how to get the components of reaction at ##A## as well as the tension in segment ##BE##.
What I'm having trouble with is the FBD of the pulley used to determine the tension in ##DEC##. I'm not quite sure how they have come up with a part of the force equation, namely:
##\sum F_z = 0 \Rightarrow 2(\frac{4}{\sqrt{96}})T - \frac{1}{\sqrt{5}}(1677.05) = 0##
The term ##2(\frac{4}{\sqrt{96}})T## is what is confusing. I understand you need twice the tension since it's symmetric, but how on Earth are they getting ##\frac{4}{\sqrt{96}}##?
I figure they are applying ##\frac{T_z}{T} = \frac{4}{\sqrt{96}}## to a triangle, but I'm not seeing the triangle.
If you look at the diagram, write the coordinates of points C, D, and B.
When the pulleys are under tension, one can see that CDE make a triangle and a plane. You can also assume that the line BE will also lie in that same plane. You can determine the position of the point E by drawing a projection of the plane CDE in the y-z coordinate plane, and extending it to the line AB on the y-axis. Once the coordinates of point E are known, you can calculate the length of line DE, which is Sqrt (96) feet.
