Calculating Coefficients of Friction with an Inclined Eraser
  • Thread starter Thread starter piercegirl
    Friction
The problem involves determining the coefficients of static and kinetic friction between a rubber eraser and various surfaces using an inclined plane. The student observes the angles at which the eraser begins to slip and moves with constant speed.
  • Participants discuss the definitions and applications of static and kinetic friction, questioning the relationship between the angles and the types of friction. There is a suggestion to draw a force diagram to visualize the forces at play.
The discussion is ongoing, with participants exploring the concepts of static and kinetic friction and their application to the problem. Some guidance has been offered regarding the need for a force diagram and clarification on when each type of friction applies.
Participants are navigating assumptions about the definitions of static and kinetic friction and the conditions under which they apply. There is a noted confusion regarding the relationship between the angles and the types of friction involved.
piercegirl
In order to determine the coefficients of friction between rubber and various surfaces, a student uses a rubber eraser and an incline. In one experiment, the eraser begins to slip down the incline when the angle of inclination is 35.2° and then moves down the incline with constant speed when the angle is reduced to 30.8°. From these data, determine the coefficients of static and kinetic friction for this experiment.
FIND: Static and Friction
f=mu(N)
N=mgcos(theta)
What seems to be the problem? You haven't really shown any attempt at solving the problem.
Well i guess I am just confused on the following: I know that static friction is bigger and requires more force than that of friction force. The angles seem to indicate that the Static is 30.8 and friction is 35.2 is that right?
When does static friction apply? When does kinetic friction apply?
Draw a force diagram. Is the motion in equilibrium?
  • · Replies 21 ·
