th3plan
- 93
An infinite, nonconducting sheet has a surface charge density σ = +8.77 pC/m2. (a) How much work is done by the electric field due to the sheet if a particle of charge q0 = 9.61 x 10-19 C is moved from the sheet to a point P at distance d = 2.45 cm from the sheet? (b) If the electric potential V is defined to be zero on the sheet, what is V at P?
Shouldnt the answer for part a be negative, because the solution manual says its positive,. I know V=-W_{}infty/q . Can someone explain me why this is so ?
