Finding Force to Accelerate a Wheel Cart for Bending Moment Calculation
To calculate the force required to accelerate an 80,000 kg wheeled cart and subsequently determine the bending moment in a stopping bracket, the key is understanding the relationship between acceleration and deceleration. The cart, which travels 7.8 meters and reaches a velocity of 0.1 m/s, requires the application of the formula F = ma, where 'a' represents the deceleration upon impact. It's important to note that the deceleration experienced during stopping is distinct from the acceleration that initially moved the cart. The stopping force can be derived using momentum principles, specifically FT = MV, where 'T' is the time duration of the stop. Accurate calculations for impact stress should consider both the theoretical static stress and the effects of deformation upon impact.
1988ajk
I am having trouble trying to find the force required to accelerate a wheeled cart. so that i can calculate the bending moment in a stopping bracket,
the bit I am stuck on is The Acceleration of the cart, the situation is;
An 80,000Kg Wheeled cart runs on rails from rest and hits a stop after 7.8m at a velocity of 0.1m/s
what is the acceleration of the cart at 7.8m?,
this would allow me to find the force F=MA
I would be very grateful for your input,
*Note, this is not a homework question
Adam.
d = 1/2at.t is one relationship to get a.
But you do NOT need that to determine the stopping force. All that matters at the moment of impact is the velocity (momentum) of the cart.
F =ma is NOT the relationship you think on the stopping side ...The "a" there would be the deceleration experienced and has nothing to do with the "a" that caused the cart to accelerate in the first place...
Try an approach like FT= MV for stopping force...you'll have to decide how long that fixed constant force "F" acts..pick a "T" during which time the cart stops...say 0.1 or 0.01 seconds or whatever you like. And recognize that because the cart may crumple..deform...upon impact, the force is not really constant...
formula above is supposed to be d = 1/2at2
thanks for that,
however I think I haven't put enough detail into my problem. to find the impact stress I am using an expression from the Roark book on stress and strain where the impact stress can be calculated from a theoretical static stress.
this is the reason I was interested in the acceleration. If I use the expression for acceleration you gave, putting in time taken for the bogie to reach the stop from rest, will this value be able to be used to find the force to push the cart. F=ma
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
