Heat rate flow through bar? and thermal conductivity
The problem involves heat transfer through a cylindrical bar made of two materials, with one end connected to a hot reservoir at 78 °C and the other to a cold reservoir at 5 °C. The bar's dimensions and thermal conductivity of one material are provided, while the thermal conductivity of the second material is unknown. Participants are tasked with finding the rate of heat flow and the thermal conductivity of the unknown material.
  • Participants discuss the appropriate use of the heat transfer equation and the significance of temperature differences in calculating heat flow. There is confusion regarding which temperatures to use for delta T and how to set up equations for the two materials in series.
Some participants have provided guidance on viewing the thermal conductivity as a form of resistance and suggested setting up equations for both sections of the bar. There is an ongoing exploration of the correct approach to find the unknown thermal conductivity, with some participants confirming their calculations while others express uncertainty about their methods.
Participants are navigating the complexities of thermal conductivity and heat flow in a system with two materials. There is a need for clarity on the temperatures at the ends of each section of the bar, as well as the implications of using different temperature values in calculations.
omc1
A hot reservoir is maintained at a temperature of 78 oC, and a cold reservoir is maintained at a temperature of 5oC. They are separated by 11.00 cm, and are connected by a cylindrical bar made of two materials. The radius of the bar is 0.83 cm. The upper part of the bar is made of yellow brass (k = 220 W/(moC)), and has a length of 1.10 cm. The lower part's material is unknown. The temperature where the two materials are in thermal contact is 77.4875 oC. What is the rate of heat flow through the bar?
then find the thermal conductivity?
q=KA(deltaT)/L
i tried to use this equation to find the heat flow, and then I tried to set this equation to find the K for the other substance but its not working...thanks for help!
q=KA(deltaT)/L
Not good enough. You need to show more of your work. I assume the hot reservoir is at the top, and the cold one is at the bottom. What are the temperatures at the two ends of the 1.1 cm yellow brass section? What is the rate of heat flow through this section?
yes the hot one is at the top, I tried it two different ways because I am confused about this problem but both ways i tried it got me similar answers, for the the heat flow I plugged in the numbers but for delta T I first used 77.4875, then I used 78-5, but both are wrong. for the second part I did KA(deltaT)/L= KA(deltaT)/L, but I sont understand this problem...
I asked you what the temperatures are at the two ends of the 1.1 cm yellow brass section, and you haven't answered me. You will never get delta T correct if you are unable to answer this question.
This conduction problem is analogous to the problem of two electrical resistors connected in series across a voltage drop.
Hi omc1,
Remember that you can view kA/L as a resistance, and the bar of differing materials would be "resistors" in series. So (k1A/L1) + (k2A/L2) = (kA/L)total
You will have to build three separate equations from this information, combine and solve for k2 first then solve for your total q
-Mark
edit: Chestermiller beat me to it!
mpreds said:
Hi omc1,
-Mark
Mark, you've kinda got it inverted. kA/L is a conductance, not a resistance. The equations you have written are for two bars in parallel, not series.
omc1:
To get the rate of heat flow through the bar (part A of your problem), you only need to focus on the 1.1 cm yellow brass portion. Can you solve the following problem:
I have a 1.1 cm long bar 0.83 cm in radius, made out of a material with a thermal conductivity of 220 W/(m C). The temperature at one end of the bar is held fixed at 78 C, and the temperature at the other end of the bar is held fixed at 77.4875 C. What is the rate of heat flow through the bar (in watts)?
sorry i did not see that question when you first posted it, the temperature at the top of the yellow brass is 78C and at the bottom of the yellow brass it is 77.4875C.
I used that for delta t and got the right answer...iam not sure why the cold temperature is not used because the bar is connected to the cold and the hot...
for the second part i set it up to solve for K2, i fount the Q for the yellow brass, but iam not sure about the total Q?
The exact same Q goes through the lower part of the bar. What are the temperatures at the two ends of the lower part of the bar? What is the Q through the lower part of the bar.
I hope you realize this problem is the same as taking two separate bars and gluing them together. You know what the temperatures are at the two ends of each of the two sections. Both sections have to have the same heat flow rate through them. After all, where else is the heat going to go?
ok, Q through the lower part of the bar is the same as through the top par...the temperature at the lower end is 77.4875 and 5C. so Q=K2*A*deltaT/L2
L2=9.90cm, Q=2.22W, deltaT=77.4875-5
Yes. Now solve your equation for K2.
ok, double check me on this because it is saying that it is wrong, (2.218)*(.099)/(pi*.0083^2)*(77.4875-5)=13.997 W/mC
I get the same answer as you. I'm pretty confident we did it correctly.
yup we did, computer wanted more sig figs! thanks for your help!
Thanks for the correction, my textbooks call it conduction resistance, which is why I called it resistance. I did have my resistance equations inverted for omc1 to integrate it into his/her equation more easily.
10K
