The Electric Field Strength of a Proton Accelerated at 1 Million g
The discussion centers on calculating the electric field strength experienced by a proton undergoing an acceleration of 1 million g, equating to 9.8x10^6 m/s^2. Participants clarify that the relationship between force, mass, charge, and electric field strength is essential for this calculation. The formula used is F = ma = qE, leading to the conclusion that the electric field strength can be derived from the mass of the proton, its acceleration, and its charge. The final calculation suggests that the electric field strength is approximately 0.1 N/C. This highlights the importance of correctly applying physical principles to determine electric field strength in high-acceleration scenarios.
joej
What is the electric field strength at a point in space where a proton experiences an acceleration of 1 million "g"?
I'm completely lost on this one I know it's bound to be something simple but I just can't figure out where to start with it, well other than that 1 million "g" should be 9.8x10^6 m/s^2
I'm also not quite sure, but I'm guessing this will have something to do with gravitational fields.
The question seems to infer that the proton is accelerated by the electric field.
Think about the relationship of Force to the electric field strength and as a function of mass and acceleration.
\vec{F} = m\vec{a} = q\vec{E}
okay, so I get...
ma = (1.64x10^-21)/(1.6x10^-19) = 0.01N/C
would that be right?
joej said:
okay, so I get...
U missed one order of size:
|\vec{E}|=\frac{m_{proton}|\vec{a}|}{q_{proton}}
|\vec{E}|=\frac{1.67\cdot 10^{-27}Kg\cdot 9.8\cdot 10^{6} ms^{-2}}{1.6\cdot 10^{-19}C}\sim 0,1N/C
Daniel.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
