Three light waves combine at a point find resultant amplitude and phase angle
The problem involves the combination of three light waves at a point, represented by their electric field components. The objective is to find the resultant amplitude and phase angle of the combined electric field.
  • Participants discuss different methods for combining the electric field components, including adding them sequentially or all at once. There is a question about the validity of using double angle formulas and whether the initial assumptions about the approach are correct.
Some participants have provided guidance on the methods to use, and there is a recognition of the results obtained from different approaches. The discussion reflects a mix of interpretations and methods without a clear consensus on the correctness of the results.
There is an emphasis on careful examination of phase shifts and their effects on the resultant amplitude, with some participants noting the cancellation of terms due to opposing phase shifts.
CianM
Three light waves combine at a point where their electric field components are
E1 = Eo[tex]sin \omega[/tex]t
E2 = Eo[tex]sin (\omega[/tex]t - 2[tex]\pi[/tex]/3)
E3 = Eo[tex]sin (\omega[/tex]t + [tex]\pi[/tex]/3)
Find the resultant amplitude of the electric field ER at that point and it's phase angle[tex]\beta[/tex]
Write the resultant wav int the form E = ER[tex]sin(\omega[/tex]t + [tex]\beta[/tex])
Am I right in assuming that first you add E1+E2 then add E12 + E3 using double angle formulas? Or am I going about this completely the wrong way?
What about adding all three at once, using dbl angle formula to break out the phase shifts and collecting like terms. The results should be the same.
Well I already did the way I suggested and the answer I got was :
ER = 2Eo sin ([tex]\omega[/tex]t)cos([tex]\pi[/tex]/3)
taking cos([tex]\pi[/tex]/3) = 1/2
then equals ER = Eosin( [tex]\omega[/tex]t) .
Is this right?
yep, some careful examination of the problem shows that the -phase shift term is equal and opposite to the positive shift term, cancelling out, leaving your result. (in other words the two phase angles sum to pi)
Ok. Thanks for your help!
  • · Replies 29 ·
