F=ma calculation in vector format
The discussion centers on calculating acceleration using the formula F=ma with a given force vector F=(3i + 2j + 4k) N and mass of 2 kg. The user correctly derives the acceleration vector by rearranging the equation to a = F/m, resulting in a = (3i + 2j + 4k)/2. This simplifies to a = 1.5i + 1j + 2k. Participants confirm the calculations and acknowledge that i, j, and k represent unit vectors in three perpendicular directions. The calculations and understanding of vector components are validated.
rugapark
I am given F=(3i + 2j + 4k) N and mass = 2kg
I need to calculate acceleration, so I plugged it into F=ma,
am I right in saying
(3i + 2j + 4k) = 2 a
\frac{(3i + 2j + 4k)}{2} = a
therefore a = 1.5i + 1j + 2k ?
cheers.
Looks good to me. I assume i, j and k are unit vectors in 3 perpendicular directions.
yep, that's fine
brilliant, thanks for that guys.
