Pulley with Kinematics in One Dimension Question
The discussion revolves around a physics problem involving two masses connected by a pulley, where the goal is to determine the maximum height reached by the lighter mass after the system is released. The acceleration of the system has been calculated to be 4.45 m/s², but the user is struggling to find the time, velocity, and final position of the lighter mass. Key questions include how the height of the pulley affects the calculations and the implications of the heavier mass hitting the ground on the lighter mass's motion. The conversation suggests using kinematic equations to find the velocity of the lighter mass at the pulley and discusses the relationship between tension and acceleration in the system. The user seeks clarity on how to proceed with these calculations without using energy conservation principles.
jakecar
Two masses hanging vertically from a pulley are each initially 1.6 m above the ground and the massless frictionless pulley is 4.8 m above the ground. What maximum height does the lighter object reach after the system is released?
\vec{F}_{net} = \Sigma \vec{F} = m \vec{a}
v = v_0 + a t
x = x_0 + v_0 t + (1/2) a t^2
v^2 = v_0^2 + 2 a \Delta x
I already found the acceleration to be 4.45\frac{m}{s^2}. Now I know that I have to figure out how high the lighter mass goes when the heavier mass is on the ground. The problem for me is that I can't find time t, velocity v, or final position x. Also, where does the given height of the pulley (4.8 m) come into play? Thanks for any help.
I presume you are given the two masses? In any case, what happens after the lower mass hits the ground?
One mass is 1.2 kg and the other is 3.2 kg. After the heavier mass hits the ground, the lighter mass stops at some unknown height. The lower mass never hits the ground. I can't seem to figure out how much time it takes for the heavier mass to hit the ground or with what velocity it hits the ground either.
When the heavier mass hits the ground, what happens to the force (and acceleration) of the lighter mass? (What happens to the tension in the string?)
I meant lower in height, not mass. :wink:
Why not? You have the acceleration and the distance traveled. You can also use energy conservation to find the final speed. (No need to find the time.)
I don't think I'm supposed to use energy conservation because we haven't learned that yet and it's not in the chapter that we're currently on. Using the kinematics equations, I can figure out the velocity of the lighter mass when it reaches the pulley if there was no ground. How can I use that information to figure out the maximum height of the lighter mass? How is the tension of the string related? Thanks for the help :)
Find the speed of the masses when the heavy one hits the ground.
If the string stopped pulling on the lighter mass, what would its acceleration be?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
