Radius of curvature of 1 MeV electron in 1 Tesla B field
To calculate the radius of curvature of a 1 MeV electron in a 1 Tesla magnetic field, the formula r = mv / eB is used. The relativistic speed of the electron is approximately 0.941 times the speed of light (c). The momentum (p) is calculated using p = m0v / sqrt(1 - v^2/c^2), resulting in a value of 7.59E-22 kg m/s. Given the charge of the electron (e = 1.6E-19 C) and the magnetic field strength (B = 1 T), the expected radius of curvature is approximately 4.74E-03 m. The calculations confirm that the expected value aligns with the derived results.
tuathan
i need to calculate radius of curvature of 1 MeV KE electron in 1 Tesla magnetic field.
r = mv / eB
what is the (relativistic) speed, v, of the electron? (ans: 0.941 c ??)
then i think you use p(rho) = mo. V / sqrt (1 - v^2 /c^2) = mv (ans: 7.59E-22 kg m/s)
e = 1.6E-19 C
B = 1
please show calculation of radius of curvature..
(expected value for r: 4.74E-03 m ??)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
