angledimensions
Can Angles be Assigned a Dimension?
📖Read Time: 7 minutes
🔖Core Topics: dimension, angular, angles, vector, dimensions
1. Some Background on Dimensional Analysis
… if you are not already familiar with it.
1.1 Dimensions
Dimensional Analysis is a way of analyzing physics equations that consider only the qualitative dimensions – mass, length, time, charge .. – of the quantities involved, not the values that they take in the given problem.  This is not to be confused with Euclidean dimensions.
The fundamental rule is that you can only add, subtract or equate terms that have exactly the same constituent dimensions, and each to the same degree.  Acceleration cannot be a force or be added to a force because the latter includes a mass dimension while the former does not.  An area cannot be compared to a distance because it is length squared.
For a detailed discussion see e.g.  http://web.mit.edu/2.25/www/pdf/DA_unified.pdf, or any text on the Buckingham Pi theorem.   (There are also Wikipedia and Khan academy links, but these, unfortunately, confuse DA with managing units as variables, which is a separate topic.)
1.2 Notation
The standard notation in DA is that if x is a variable in an equation then [x] extracts its dimensionality.  The dimensions themselves are labeled M for mass, L for length, T for time, Q for a charge, θ for temperature …
Thus, if F is a force then ##[F]=MLT^{-2}##.  The well-known equation F=ma would be analyzed as ##MLT^{-2} = (M)(LT^{-2})##, which is clearly true.
1.3 Uses
1.3.1 Predicting the form of a relationship
DA can be a useful shortcut to establishing the general form of how one quantity depends on others.
Example: We presume that the pressure difference, ##\Delta P##, between the inside and outside of a bubble depends on the radius, ##r## and the surface tension ##S##.
## [ \Delta P]=ML^{-1}T^{-2}##
##[r]=L##
##[S]=MT^{-2}##
The only way to combine the pressure difference and surface tension to obtain a length is
## (MT^{-2})/(ML^{-1}T^{-2})=L##
Hence we can say
##r=kS/\Delta P##
for some constant k.
1.3.2 Error checking
Many algebraic errors can be caught by checking dimensional consistency.
2. Angles
Angles have never been considered to have dimension.  Consider, for example, the formula for arc length ##s##:
##s = r\theta##
Since ##s## and ##r## each have dimension ##L##, the angle cannot have a dimension, or so it seems.
2.1 Units Matter
Dimensionless combinations, like ##force/(mass \times acceleration)##, generally have the useful feature that they are invariant to the units used.  As long as the units used for the variables are consistent, the same number results whether you use SI or Imperial, or Babylonian.
This is not true of angles; many problems posted on the Homework forums are resolved when the student remembers to plug in the number of radians as argument to the sine function instead of degrees.
2.2 Distinct Entities with the Same Dimensionality
It is somewhat unsatisfactory that, when reduced to mere dimensions, some pairs of quite different entities appear to be the same.
Torque and energy are both force times distance.  In terms of vectors, the first is the vector product, the second the scalar.
Angular momentum and action are both ##ML^2T^{-1}##.  Again, a vector and a scalar.
3 Axioms for an “Imaginary” Dimension
Consider assigning angles the dimension ##\Theta##, with some unusual properties:
  • ##\Theta^2=1##
  • The cross product operator itself has dimension ##\Theta##
  • ##i##, the square root of -1, has dimension ##\Theta##
3.1 Vectors and Angles
The following table illustrates the use of the dimensionality of angles with cross and dot products.
EntitySample EquationDimension
 Arc length element ##\vec{ds}=\vec r\times\vec{d\theta}#### L=(L)(\Theta)(\Theta)##
 Torque ##\vec\tau=\vec r\times\vec F####ML^2T^{-2}\Theta=(L)(\Theta)(MLT^{-2})##
 Work  ##E=\vec r.\vec F## ##ML^2T^{-2}=(L)(MLT^{-2})##
 Angular momentum ##\vec L=\vec r\times\vec p## ##ML^2T^{-1}\Theta=(L)(\Theta)(MLT^{-1})##
 Gyroscopic precession ##\vec \tau=\vec \Omega_p\times\vec L## ##ML^2T^{-2}\Theta=(\Theta T^{-1})(\Theta)(ML^2T^{-1}\Theta)##
 Velocity ##\vec v=\vec r\times\vec{\omega}## ##LT^{-1}=(L)(\Theta)(\Theta T^{-1})##
E.g. to resolve the ##s=r\theta## case for arc length, we can argue that this should really be expressed as the integral of the magnitude of a vector:
##s=\int|\vec{dr}|=\int |\vec r\times\vec{d\theta}|##.  The ##\Theta## dimension of the angle is neutralized by that of the cross-product operator.
3.2 Functions of Angles
Raising a dimensioned entity to power is fine because we can still express the dimensions of the result.  For other functions, such as exp, log, and trig functions, it is more problematic.  If you ever find you have an equation of the form ##e^x##, where ##x## has dimension, you can be pretty sure you have erred.
For trig functions, it would be reasonable to require the argument to be an angle, but ##e^{i\theta}## would appear to create a difficulty for assigning angles a dimension.
This can be resolved by giving ##i## the ##\Theta## dimension also.  Based on the power series expansions, we see that the odd trig functions (those for which f(-x)=-f(x)) necessarily return the ##\Theta## dimension but the even functions, such as cosine, return a dimensionless value.
Thus, ##e^{i\theta}=\cos(\theta)+i\sin(\theta)## is entirely dimensionally consistent.
3.3 Areas and Volumes
Areas are naturally generated as cross products of vectors, imbuing them with the dimension ##L^2\Theta##.  Since the vector is normal to the surface, this is analogous to rotations as vectors.
Since volumes arise from the triple scalar product, it would seem that these should also have the ##\Theta## dimension.  This is more surprising.
The solid angle element subtended at the origin by a surface element ##\vec {dS}## at position ##\vec r## is given by ##d\Omega=\frac{\vec r.\vec{dS}}{|r|^3}##.  Or, if we wish to make this a vector in the direction ##\vec r##, ##\vec{d\Omega}=\vec r\frac{\vec r.\vec{dS}}{|r|^4}##.
Alternatively, in polar coordinates, ##d\Omega=\sin(\theta).d\theta d\phi##
Whichever way, the dimension is again ##\Theta##, which feels consistent with the result for volumes.
3.4 Complex Arithmetic
If ##i## is to be given dimension, what are we to make of ##1+i##?
Despite appearances, there is no difficulty.  ##1+i## is a convenient notation, but it is not added in the same sense as in ##1+1##.  The 1 and the ##i## retain their separate existences.  We might just as easily if less conveniently, have chosen to write complex numbers as an ordered pair, like <x, y>.  The real and imaginary parts never get crunched together in the same way as in normal addition, so they can have different dimensions without creating any inconsistencies.
3.5 Frequency and Angular Frequency
In wave expressions, frequency, ##f##, is the number of cycles per unit time, while angular frequency, ##\omega##, is radians per unit time.  ##\omega=2\pi f##.
Clearly ##\omega## should have dimension ##\Theta T^{-1}##.  The dimension for ##f## depends on whether the factor ##\pi## is to be taken as an angle or as a dimensionless number performing a conversion of units.  Taking ##f## as having dimension ##T^{-1}## appears to be best.
3.6 Planck’s Constants
Consider the equations
##E=hf##
##E=\hbar \omega##
Since ##h## has dimension of action, ##ML^2T^{-1}##, it has no angular dimension.  That is fine for the first equation since frequency is just ##T^{-1}##.
In the second equation, ##[\omega]=\Theta T^{-1}##.  ##\hbar## is defined as ##\frac h{2\pi}##.  Since ##\pi## is an angle here, that has dimension ##ML^2T^{-1}\Theta##, cancelling the ##\Theta## from ##\omega## and achieving dimensional consistency.
But note that this gives ##\hbar## the units of angular momentum, not action. An implication is that ##\hbar## should perhaps be considered a vector, and we should write the photon energy as
##E=\vec{\hbar}.\vec{ \omega}##
though how one is to justify that ##\vec {\hbar}## is necessarily in the direction of the velocity is unclear.
Likewise for momentum
##\vec p = k\vec{\hbar}##
where k is the wavenumber.  Note that this provides momentum as the vector it should be, rather than just defining its magnitude.
The Heisenberg Uncertainty relations, such as
##\frac 12\hbar\leqslant \Delta \vec p.\Delta \vec x##
would appear to violate both the dimensionality and the notion of making ##\hbar## a vector.  But if we follow the steps in the proof of the uncertainty relation we come to this penultimate statement:
##\frac 14\hbar^2\leqslant (\Delta \vec p.\Delta \vec x)^2##
At this point, giving ##\hbar## an angular component of dimensionality creates no problem.   Neither is there an issue with thinking of it as a vector.  These problems only appear when we overlook the ambiguities that so commonly arise when taking square roots.
4. Postscript
Subsequent to penning the original article, I have become aware of numerous prior attempts, dating back as far as 1936.  An excellent summary is by Quincey and Brown at https://arxiv.org/ftp/arxiv/papers/1604/1604.02373.pdf.
But their list misses a key one:
C. H . Page, J. Research National Bureau of Standards 65 B (Math. and Math. Phys.) No. 4, 227-235; (1961). http://nvlpubs.nist.gov/nistpubs/jres/65B/jresv65Bn4p227_A1b.pdf
It appears that most of my work above is a rediscovery of Page’s:
ResultPage in “Page”
Cross product has angular dimension, dot product does not 231
##\Theta^2=1##Appendix 2
sine has angular dimension, cosine does notAppendix 2
solid angles have angular dimension (i.e. not squared)Appendix 2
whole cycles, as a unit, are dimensionlessAppendix 3
Curiously, Page drew attention to the difficulty posed by ##e^{i\theta}=\cos(\theta)+i\sin(\theta)##, but overlooked the remedy of assigning angular dimension to ##i##.
He did not consider Planck’s constants.
Newer Comments »
  1. Stephen Tashi says:
    [QUOTE="DaTario, post: 5649554, member: 33942"]Sorry, I was referring to the presumed fact that if we allow in physical equations the sum, for instance, of entities having different dimensions (as for example, summing meters to seconds) the equations would not be invariant through the change in units.”Equations are not "invariant" under a change of units.  For example F = MA is correct if F is in newtons, A is in m/sec^2 and M is in kilograms.   However if we measure M in grams, F = MA isn't correct.In general, changing units changes equations by multiplying one or both sides of the equation by constant factors.So the prohibition against adding unlike units can't be explained by the invariance of equations.  We have to explain why a particular type of variation is the only permissible kind.
  2. haruspex says:
    [QUOTE="DaTario, post: 5649580, member: 33942"]But in the case of solid angles (stereoradians – sr) the operation is:$$ frac{s}{r} frac{s}{r}. $$So it is area divided by the square of the radius.”That's only after reducing it all to scalars.  To see how angular dimension fits in, in my scheme, it seems to be necessary to work with vectors wherever appropriate.
  3. DaTario says:
    [QUOTE="haruspex, post: 5649579, member: 334404"]Good question.  I found a reason for saying they also have the angle dimension.  E.g. if we consider two angle vectors ##vec {dtheta}## and ##vec{d phi}##, and a vector radius ##vec r##, the two arc elements are ##vec rtimesvec{dtheta}## and ##vec rtimesvec{dphi}##.  The vector area element they form is ##(vec rtimesvec{dtheta})times (vec rtimesvec{dphi})##.  Counting the angle elements and cross products that has angular dimension.”But in the case of solid angles (stereoradians – sr) the operation is:$$ frac{s}{r} frac{s}{r}. $$So it is area divided by the square of the radius.
  4. haruspex says:
    [QUOTE="DaTario, post: 5649560, member: 33942"]Following your axioms, would it be correct to say that solid angles are truly adimensional?”Good question.  I found a reason for saying they also have the angle dimension.  E.g. if we consider two angle vectors ##vec {dtheta}## and ##vec{d phi}##, and a vector radius ##vec r##, the two arc elements are ##vec rtimesvec{dtheta}## and ##vec rtimesvec{dphi}##.  The vector area element they form is ##(vec rtimesvec{dtheta})times (vec rtimesvec{dphi})##.  Counting the angle elements and cross products that has angular dimension.[QUOTE="DaTario, post: 5649560, member: 33942"]the square root of an adimensional quantity has the angle dimension?”No, that would be ambiguous.  Not unusual for square roots.
  5. DaTario says:
    [QUOTE="haruspex, post: 5649557, member: 334404"]That is one very good reason for not allowing such.If the concept of attributing a dimension to angles has any validity, it must be possible to write any correct equation such that it is dimensionally consistent in that regard.”Two other questions: 1) Following your axioms, would it be correct to say that solid angles are truly adimensional?2) the square root of an adimensional quantity has the angle dimension?Best wishes,DaTario
  6. haruspex says:
    [QUOTE="DaTario, post: 5649554, member: 33942"]I was referring to the presumed fact that if we allow in physical equations the sum, for instance, of entities having different dimensions (as for example, summing meters to seconds) the equations would not be invariant through the change in units.”That is one very good reason for not allowing such.  If the concept of attributing a dimension to angles has any validity, it must be possible to write any correct equation such that it is dimensionally consistent in that regard.
  7. DaTario says:
    [QUOTE="haruspex, post: 5648617, member: 334404"]Yes, I was not sure what DaTario meant by a different "form".  From the reference to units, I presumed DaTario would regard the appearance of a factor of 2π as being a different form, but, like you, I would consider that the same in form, just different in detail.”Sorry, I was referring to the presumed fact that if we allow in physical equations the sum, for instance, of entities having different dimensions (as for example, summing meters to seconds) the equations would not be invariant through the change in units.I have just found a site with a modest exposition of this idea:http://www.johndcook.com/blog/2013/11/15/dimensional-analysis/It seems to be in accordance to the " cloudy" reference I have claimed to have read a long time ago.Best wishes,DaTario
  8. haruspex says:
    [QUOTE="Baluncore, post: 5648613, member: 447632"]I believe the form of the equations would be the same, but the π related coefficients would have a different value since angle dimension is then being measured in different units. Is that not why 2π often appears in physics formulas, because of the mathematically convenient radian unit we have chosen to use for the angle dimension.”Yes, I was not sure what DaTario meant by a different "form".  From the reference to units, I presumed DaTario would regard the appearance of a factor of 2π as being a different form, but, like you, I would consider that the same in form, just different in detail.
  9. Baluncore says:
    [QUOTE="haruspex, post: 5648604, member: 334404"]It is already the case that the form of many equations would be different if we were to use a complete circle as the unit of angle instead of using radians.”I believe the form of the equations would be the same, but the π related coefficients would have a different value since angle dimension is then being measured in different units. Is that not why 2π often appears in physics formulas, because of the mathematically convenient radian unit we have chosen to use for the angle dimension.
  10. haruspex says:
    [QUOTE="DaTario, post: 5648520, member: 33942"]consider the application of these notions to quaternion formalism”No, but modelling it on 3 vectors, one could make the product of any two of i, j, k like a cross product, so the operator has dimension Θ, but the product of i with i etc. like a dot product.[QUOTE="DaTario, post: 5648520, member: 33942"]it seems that an argument exists saying that we should avoid adding entities of different dimensions for the following reason. If one does so, the matematical shape of the formula would depend on the choice of units.”Not sure what you mean.  It is already the case that the form of many equations would be different if we were to use a complete circle as the unit of angle instead of using radians.
  11. DaTario says:
    Have you tried to consider the application of these notions to quaternion formalism. Historically, after the work of Hamilton, the dot and cross products are originated from this entity, which introduces for different unities : 1, i, j and k.Another comment. it seems that an argument exists saying that we should avoid adding entities of different dimensions for the following reason. If one does so, the matematical shape of the formula would depend on the choice of units. I have never gone into the details of this analysis but it seems reasonable. Perhaps you should mention this.Best wishes, Congratulations for the initiative.DaTario
  12. RockyMarciano says:
    [QUOTE="Demystifier, post: 5621249, member: 61953"]I have a related question for everybody. Does the dimensional analysis belongs to mathematics? Or should it be considered as a part of physics? “Dimensional analysis is usually referred to physical magnitudes, and following this definition of dimension as a physical magnitude with units and measurable it belong to physics. Then again everything physical is usually analyzed mathematically.”Can the notion of dimension (like meter or second) make sense without referring to a physical measurement?”Actually meter or second are physical units, and there's a distinction between units like meter and second and there corresponding physical magnitudes like length and time referred to standards that are subject to physical conditions like a platinum bar or an atomic frequency.I think in this thread it is not so clear what the OP refers to as dimension, I think he means a measurable unit that adds more information to physical quantities with angular components when it is not simply treated as dimensionless real number since it seems odd to think that radians or degrees depend on physical conditions like for instance  temperature in the length case.In this last understanding certainly treating angle as a "dimension" adds information, it basically turns scalars into oriented pseudovectorsAlso the comments in the article and thread about the relation with i and complex notions when giving dimension to angles comes naturally as related when thinking that the idea of a conformal structure in the complex line(or complex manifolds in general) leads to thinking of angles as being more than dimensionless numbers, the complex structure(biholomorphic mappings) also introduces the orientation-preservation referred to above in the complex manifold. Also as referenced in the first posts this has been thought of before to different degrees on different contexts, for instance in the WP page on dimensional analysis under "siano's extension orientational analysis", the idea is there also.
  13. Baluncore says:
    [QUOTE="Stephen Tashi, post: 5630236, member: 186655"]The assumption that the left and right hand sides of an equation describing a physical law must have the same dimension is essentially an empirical finding.”The term equation implies mathematical equality. Equality of numbers, units and dimension.1.LHS = RHS. Divide both sides by LHS and you get 1 = RHS / LHS. The 1 on the left must now be a dimensionless ratio. Are you saying that the ratio RHS / LHS might have somehow suffered from a “little big bang” and grown some dimension ?2.LHS = RHS. Divide both sides by RHS and you get LHS / RHS = 1. The 1 on the right must now be a dimensionless ratio. Are you saying that the ratio LHS / RHS might have somehow suffered from a “little big bang” and grown some dimension ?3.Does RHS / LHS have the same dimension as LHS / RHS, or the reciprocal dimension of LHS / RHS.[QUOTE="Stephen Tashi, post: 5630236, member: 186655"]So dimensional analysis can detect an "error" in an equation the sense of detecting that the equation isn't provable from the fundamental laws. But such an "error" doesn't imply that the equation describes an impossible experimental result.”You could not publish such a discordant result because it would not survive the dimensional analysis of peer review. The result would undermine the physics we describe with mathematics.If that experiment could be done once, the result would instantly propagate throughout our universe, at the speed of mathematics, annihilating all dimensional analysis and physics as we thought we knew it.With some minor mathematical manipulation, such an experiment could create free energy from a dimensionless angle.
  14. Stephen Tashi says:
    [QUOTE="Baluncore, post: 5630195, member: 447632"]In The Physical Basis of DIMENSIONAL ANALYSIS, on page 10;”OK, but that passage is a statement of assumptions.  By the same conventional wisdom (i.e the usual assumptions of dimensional analysis)  angles are dimensionless.   The Insight under discussion challenges conventional assumptions.    So I'm questioning the basis for the conventional assumptions.Nobody as risen to the challenge of justifying the conventional assumptions,  so I'll try answering my own question.  The assumption that the left and right hand sides of an equation describing a physical law must have the same dimension is essentially an empirical finding.   If we look a given field of physics organized as mathematics, there are "fundamental laws" (equations that correspond to mathematical assumptions) and there are equations derived from them.  The pattern in physics is that the fundamental laws (which are only "laws" because they are confirmed empirically) obey the assumptions of conventional dimensional analysis.  In particular the dimensions on the left and right hand sides of the fundamental equations match.   The mathematical consequence of this appears to be:Any equation derived from the fundamental laws also obeys the assumptions of conventional dimensional analysis. It would interesting to know if anyone has formulated a mathematical proof of that assertion.  If we assume that assertion then an  equation that violates the assumptions of conventional dimensional analysis is  definitely not derivable from the fundamental laws.   However, the fact that the equation isn't derivable from the fundamental laws doesn't imply that the equation is an inaccurate description of a physical situation.    So dimensional analysis can detect an "error" in an equation the sense of detecting that the equation isn't provable from the fundamental laws.   But such an "error" doesn't imply that the equation describes an impossible experimental result.
  15. Baluncore says:
    [QUOTE="Baluncore, post: 5630095, member: 447632"]I refer to simple numerical addition.”[QUOTE="Stephen Tashi, post: 5630129, member: 186655"]So do I. Why is it necessarily an error?”In The Physical Basis of DIMENSIONAL ANALYSIS, on page 10;[quote="Ain A. Sonin"]A base quantity is defined by specifying two physical operations:a comparison operation for determining whether two samples Aand B of the property are equal (A=B) or unequal (A≠B), andan addition operation that defines what is meant by the sum C=A+B of two samples of the property.Base quantities with the same comparison and addition operations are ofthe same kind (that is, different examples of the same quantity). Theaddition operation A+B defines a physical quantity C of the same kind asthe quantities being added. Quantities with different comparison andaddition operations cannot be compared or added; no procedures exist for executing such operations.[/quote]
  16. Stephen Tashi says:
    [QUOTE="Baluncore, post: 5630095, member: 447632"]I refer to simple numerical addition. “So do I.   Why is it necessarily an error?  “Dimensional analysis is used as one check on the integrity of physical equations. It does not however detect all errors.”Dimensional analysis detects what dimensional analysis defines to be errors.  However, as mentioned in previous posts, it is possible to report the results of an experiment precisely using equations that don't conform to the requirements of dimensional analysis.
  17. Baluncore says:
    [QUOTE="Stephen Tashi, post: 5629855, member: 186655"]You are saying that "dimensions" are identified by the SI "units of measure" – i.e. that the "unit of measure" is more fundamental than the concept of "dimension".”No, you are saying that.I am saying that dimension is fundamental to physics, but that in the everyday human world, dimension is implicit, and is hidden behind the units. I say that knowing the dimension of a numerical result should identify the appropriate SI unit for that result.A force of 9.8 newton has implicit dimension identified by both the term “force” = M⋅L⋅T[SUP]–2[/SUP], and the unit “newton” = kg⋅m⋅s[SUP]–2[/SUP]. That duplication can be used as a check on data inputs, and then on the integrity of the numerical computation system. To maximise the application of that integrity check requires that dimensions such as length, angle or temperature be somehow attached like a tag to the numerical data as it flows through the computational system.[QUOTE="Stephen Tashi, post: 5629855, member: 186655"]Why make the assumption that adding different dimensions is an error”I refer to simple numerical addition. In a complex number, the operator i serves to keep two numbers apart and so precludes their immediate numerical addition, even though they have the same fundamental physical dimension. They remain independent members in a set, or a data structure.Dimensional analysis is used as one check on the integrity of physical equations. It does not however detect all errors. My aim is NOT to reduce a dimension system to a divine physical fundamental minimum. It is to identify what dimensions are needed to maximise the possibility of integrity checks in computational systems.Alexander Pope wrote in his Essay on Criticism, “To err is human, to forgive divine”. I argue here that; if the angle dimension did not need to exist in divine physics, humans would need to invent an angle dimension to detect human error.
  18. Stephen Tashi says:
    [QUOTE="Baluncore, post: 5629648, member: 447632"]A measurement without units is meaningless. Consider a measured value, complete with units as an input to a process. The units identify the dimension of the value. Convert that value to SI using known conversion factors. The dimension will not change. “That's backwards to the usual approach because the outlook of conventional dimensional analysis is that dimensions (e.g. time, mass) are the fundamental properties of nature and various units of measure   (e.g. kilograms, seconds) are invented to quantify a dimension.      You are saying that "dimensions" are identified by the SI "units of measure" – i.e. that the "unit of measure" is more fundamental than the concept of "dimension".”Proceed with the computations while tracking any and all the combinatorial changes of dimensions. Adding or comparing apples and oranges will raise an immediate runtime error.”Why make the assumption that adding different dimensions is an error?  As pointed out by others in the thread, there are two possible interpretations of "addition".   One type of addition is "appending to a set" – for example, put 2 apples in a bag and then put 3 oranges in the bag.  Another type of addition is "summation of numerical coefficients of units and creation of a new type of unit that does not distinguish the summands".  An example of that would be:  2 apples + 3 oranges = 5 apples+oranges.It's easy to say that "5 apples+oranges" makes no sense, but why do we say that?   After all we don't object to products of units with different dimensions like 5 (ft)( lbs).    What makes a unit representing a sum of dimensions taboo, but allows a unit representing a product of dimensions to be "the usual type of thing" ?The answer might be that Nature prefers the ambiguity in products.  For example, in many situations, the "final effect" on a process of  a measurement 5 (ft)(lbs) is the same , no matter whether it came from a situation implemented as  (1 ft) (5 lbs) or (2.5 ft) ( 2 lbs), etc.   So the ambiguity introduced in recording data in the unit (ft)(lbs) is often harmless.    However, it is not harmless is all physical situations.  If a complicated experiment involves a measurement of 2 ft on something at one end of the laboratory and  2.5 lbs on something at the other end of the laboratory,  summarizing the situation as  5 (ft)(lbs) may lose vital information.  Is it a "natural law" that products are the only permitted ambiguities?    Allowing the ambiguity implied by a sum-of-units fails to distinguish situations that are (intuitively) vastly different.  For example  a measurement of 5 apples+oranges could have resulted from inputs of  3 apples and 2 oranges, or 0 apples and 5 oranges, or 15 applies and -10 oranges.    However (taking the world view of a logician) it is possible to conceive of situations where this type of ambiguity has the same "net effect".   We can resort to thinking of a machine with a slot for inputting apples and another slot for inputting oranges.    The machine counts the total number of things entered and moves itself along the table for a distance of X feet where X is the total.   Is the argument in favor of products-of-units and against sums-of-units to be based only on statistics? – i.e that one type of ambiguity is often (but not always) adequate for predicting outcomes in nature, but the other type of ambiguity is rarely adequate ?I suspect we can make a better argument in favor of products-of-units if we make some assumptions about the mathematical form of natural laws.  For example,  do natural laws stated as differential equations impose constraints on the type of ambiguity we permit in the measurements of the quantities that are involved ?
  19. Baluncore says:
    A measurement without units is meaningless. Consider a measured value, complete with units as an input to a process. The units identify the dimension of the value. Convert that value to SI using known conversion factors. The dimension will not change. Proceed with the computations while tracking any and all the combinatorial changes of dimensions. Adding or comparing apples and oranges will raise an immediate runtime error.The final result will have dimensions that identifies the appropriate SI units of the result. If the resulting SI unit is silly, then dimensional analysis has identified an error is present. Either the wrong data has been input or the computational algorithm is wrong.That is why for example, angle and temperature dimensions must exist in the system. Because they will pass through the dimension analysis system to verify integrity and identify the final SI unit, in this example as angle or as temperature. For a calculator, the dimensional analysis module should follow all the data. If you press the wrong key it will detect your failure to use the correct algorithm. To be most efficient in a computer, the dimensional analysis module might best be part of the compiler rather than a runtime module that tracks every repeated computation.
  20. Stephen Tashi says:
    [QUOTE="Baluncore, post: 5629543, member: 447632"]like how do you represent a fractional dimension such as when you take a square root. Or how do you represent a dimensioned variable that is raised to a non-integer power.” To answer how to represent something, we must say what we are trying to accomplish with the representation.  What we are trying to accomplish with a given theory of dimensions? I see the the most basic requirement as: If an experimenter states his results as an equation in one system of units, then a second experimenter who uses a different system of units must be able to interpret the results of the first experimenter in that different system of units. This is a very relaxed requirement.  For example, suppose there is a specific machine M.   To operate it, an experimenter turns a crack through a given angle ##theta## and holds it at that position for time ##t##.  The crank is released and the machine moves along the table for a distance ##x##.    The first experimenter states his results as ##x = 3sqrt{t} sin(theta) ## where ##x## is in meters , ##t## is in seconds, and ##theta## is in degrees.   I think a second experimenter who wishes to use a system of units consisting of centimeters, minutes, and radians can figure out how to state the results of the first experimenter in that system of units.    So what is our theory of dimensions trying to accomplish in this situation?  Are we seeking a theory where changing the units in an equation is always done by a particular procedure ?   – conversion factors, for example.    If expressing a result in different units cannot be done by using conversion factors, are we prepared to say  the result is "not physically meaningful"?
  21. Baluncore says:
    I like the way this thread is going as it is covering some of those questions I have previously encountered. A few years ago, I overloaded a computation language with dimensional analysis and unit conversions based on SI, just for the fun of it. I had problems with the dimension of angles, and with polynomial approximations which became too difficult at the time, so remained dimensionless. It is only when implementing a complete general dimension system that you encounter the deepest problems, like how do you represent a fractional dimension such as when you take a square root. Or how do you represent a dimensioned variable that is raised to a non-integer power. I ended up needing dimensions of: length, mass, time, current, temperature, light, substance, angle, information and currency.The advantage of including dimensions of temperature, angle and currency was that conversion between different inputs to output units could be more easily implemented. (e.g. celsius, kelvin, fahrenheit; degree, radian, grad; dollar, euro or yen.) Unlike the the physical SI units, currency has a dynamic exchange rate, with inefficient conversions. There is no way that I can see to have a standard currency unit. Gold mining generates currency, but the demand for gold, and the cost of mining gold is variable. The closest physical unit to money is actually energy. My solar PV array could pay for itself. It is difficult to see immediately how inflation would be possible if our bank accounts held credit in joules. But then unregulated interest and taxation rates would be introduced by the bank and tax office.
  22. haruspex says:
    [QUOTE="Torbjorn_L, post: 5629389, member: 488061"]It looks to be analogous to the use of the mathematical dimension i and so doesn't add to the algorithms for solving physical problems”In most of my examples there are no complex numbers, yet it adds a dimension.  Checking that dimension would sometimes indicate algebraic errors, as with the other dimensions.  E.g. I might wish to obtain an expression for the angular momentum of something.  If the expression I get has dimension ML[SUP]2[/SUP]T[SUP]-1[/SUP] instead of ML[SUP]2[/SUP]T[SUP]-1[/SUP]Θ then I know I have gone wrong.[QUOTE="Torbjorn_L, post: 5629389, member: 488061"]It is perhaps best seen in the analysis of the Planck constant, which gives nonsensical results.”I've been working on that, and I believe I can make that work now.[QUOTE="Torbjorn_L, post: 5629389, member: 488061"]Treat angles (phases, …) as fractions of a circle.”As I pointed out, that solves nothing.  You could equally make mass dimensionless by thinking of all masses as fractions of some standard mass.  You may counter that the standard mass has dimension, so any fraction of it has dimension, but that is different.  Saying A is some fraction of B means it is a fraction multiplied by B; it does not mean that A is that fraction as a mere number.  Likewise,  I would argue that a whole circle has dimension Θ, so any fraction of it has dimension Θ.Also, I fail to see how that approach could be used in spotting algebraic errors.  Seems more like it would hide them.  Can you explain with an example?
  23. Torbjorn_L says:
    It is a suggestion to look at. But my reaction is perhaps best summed up in short points:
    1. The suggestion feels like an artificial attempt to fix something that isn't broken.
    2. It looks to be analogous to the use of the mathematical dimension i and so doesn't add to the algorithms for solving physical problems
    3. As seen from 2. it confuses mathematical dimensions (of angles, phases, non-euclidean spaces and functional spaces) with physical dimensions. It is perhaps best seen in the analysis of the Planck constant, which gives nonsensical results.
    If the suggestion is spurred by students making unit mistakes that are invisible to the physics of dimensional analysis the solution should lie along Yggdrasil's observation. Treat angles (phases, …) as fractions of a circle.
  24. Stephen Tashi says:
    Let's  look at how much physics we must specify in order for the dimensions in a McLaurin series to work out.Suppose I specify that  ##y## has dimension length in units of meters and ##t## has dimension of time in units of seconds and ##y = f(t)##  ( i.e. ##f(t)## has dimension length in units of meters.)Then the Mclaurin series for ##f(t)## is  ## f(0) +f'(0) t + f''(0) t^2/2 + …####f(0)## has units of length in meters##f'(0)## means "take the derivative of ##f## and evaluate it at ##t = 0##, so ##f'(t)## has units of meters per second By a similar argument, ##f''(0)## has units of meters per second squared.Each term in the McLaurin expansion that comes from a derivative of ##f## has the appropriate units in  meter/ sec^k to produce the unit "meters" after it is multiplied by the power  ##t^k## in seconds that is paired with it.  In the particular case of ##y = e^t##, if we look at the mathematical derivation of the power series for ##e^t##,  the mathematics tells us that the constant terms have the appropriate units once we specify the units of ##e^t## and the units of ##t##.
  25. robphy says:
    [QUOTE="Stephen Tashi, post: 5624234, member: 186655"]If an experimenter fits an equation of the form  ## y = e^t ## to his data where ##y## is in meters and ##t## is in seconds, he has described a physical relation unambiguously and a different experimenter who wishes to measure distance in centimeters and time in minutes can figure out how to create an equivalent equation using those units of measurement.It may be true that it would more convenient for the second experimenter if the first experimenter had written his results in a different form.”I agree it is unambiguous as long as all of those specifications of units are included with the equation in the sentence.And, so, if someone uses t in units of hours, then they would expect to get the wrong answer.Your equation would look different of course if someone wanted to use t in hours.However, if you wrotey=(1 meter)e^(t/(1 second))then your equation would hold for a time t expressed in any units of time… and in fact would encode the requirements of your preferred choice of units, without forcing the person to use those units [as long as they performed the appropriate unit conversion].This is an issue with curve-fitting software that I tell my students about. The software giving fit coefficients doesn't know how you are using them in an equation… that is, the physical interpretation of the data…. it just sees a curve. So, the end user has to manually attach units to the fit coefficients.
  26. Stephen Tashi says:
    [QUOTE="robphy, post: 5624227, member: 9587"]In the series expansion for exp(x/a), all of those numbers are pure [dimensionless] numbers… they are part of the definition of exp(z), where z is dimensionless.”The mathematical definition of the function ##f(x) = x^2## likewise assigns no dimension to ##x##.  So the lack of dimension in the mathematical definition of a function don't prevent us from giving the argument of the function a dimension when we employ it in physics.”Thus, the only thing that carries units is "x"”I'm not making that assumption.”No, ## y = e^x## cannot be a position equation…You could have, say, ##y=Ae^{(-t/tau)}##, where ##A## has units of length, and ##t## and ##tau## have units of time.”I disagree.  If an experimenter fits an equation of the form  ## y = e^t ## to his data where ##y## is in meters and ##t## is in seconds, he has described a physical relation unambiguously and a different experimenter who wishes to measure distance in centimeters and time in minutes can figure out how to create an equivalent equation using those units of measurement.It may be true that it would more convenient for the second experimenter if the first experimenter had written his results in a different form.
  27. robphy says:
    [QUOTE="Stephen Tashi, post: 5624223, member: 186655"]That depends on the units of the constants 1,2,6,24,120…For example,  the equation   ## y = 1 + 5x + 2x^2##  can describe a physical situation where ##y## is in units of newtons, x is in units of meters, 1 is in units of newtons, 5 is in units of newtons per meter and 2 is units of newtons per meter squared.Can an object have a position given by  ## y = e^x## ?”In the series expansion for exp(x/a), all of those numbers are pure [dimensionless] numbers… they are part of the definition of exp(z), where z is dimensionless.Thus, the only thing that carries units is "x".So, what are the units of the right-hand side?No, ## y = e^x## cannot be a position equation…You could have, say, ##y=Ae^{(-t/tau)}##, where ##A## has units of length, and ##t## and ##tau## have units of time.edit:Your proposed equation: ## y = 1 + 5x + 2x^2##  with units as you specifiedpossibly should be written as## y = (1 rm{Newton})( 1 + 5 (frac{x}{m}) + 2(frac{x}{m})^2)##[trying to conform to the exponential series expansion].The point is… if there are units, they should be shown.
  28. Stephen Tashi says:
    [QUOTE="robphy, post: 5624218, member: 9587"]What are the units on the right-hand side?”That depends on the units of the constants 1,2,6,24,120…   For example,  the equation   ## y = 1 + 5x + 2x^2##  can describe a physical situation where ##y## is in units of newtons, x is in units of meters, 1 is in units of newtons, 5 is in units of newtons per meter and 2 is units of newtons per meter squared.Can an object have a position given by  ## y = e^x## ?
  29. Stephen Tashi says:
    We haven't managed to state precise mathematical properties for a "dimension".   If we can't define what a "dimension" is, perhaps we can make definite statements about what it can't be.For example, traditional dimensional analysis insists that the arguments to transcendental functions must be dimensionless.   As a consequence, the transcendental functions  themselves are dimensionless.   Why is this assumed to be the case?    If we let an argument to a transcendental function have a dimension, what is supposed to go wrong ?
  30. haruspex says:
    [QUOTE="robphy, post: 5623336, member: 9587"]this abstract discussion might be useful about what may be going on with regard to units (and dimensional analysis) in general:https://golem.ph.utexas.edu/category/2006/09/dimensional_analysis_and_coord.html“That's a fascinating thread.  The comments most relevant to my article concern cycles.I feel those parts get confused because we use the term both in a generic sense of repeating events and in the more physical sense of rotation. This is similar to the way distance was originally used in a Euclidean sense, but now is generalised to such as graphical distance, emotional distance, …  We are comfortable using the dimension L in the former but not the latter, so there is precedent for saying cycles as rotation can have dimension but not in the other uses.  Admittedly, this could lead to some tangled terminology.  That could be avoided by agreeing that "cycle" always has the generic sense, and if we want to refer to a cycle in the rotational sense we should write "revolution".  Thus, a rotating body rotates at one revolution per cycle, or 2π radians per cycle.  Each of those would have dimension ϑ.  This angular sense would also apply to phase angles in trig functions.
  31. haruspex says:
    [QUOTE="robphy, post: 5623336, member: 9587"]There may be other not-so-slight modifications.”I'm not suggesting any modification to the way we represent or perform complex addition.  The consideration of alternative representations was to illustrate that, unlike regular addition, adding a real to an imaginary can cope with their having different dimensions.
  32. robphy says:
    [QUOTE="haruspex, post: 5623208, member: 334404"]The ability to represent angles as a dimension slightly increases the power of DA.”So, it may be worthwhile exploring this, as you have done in your Insight.However, it seems that to do so following your definitionsleads to not-so-slight modifications of how to do addition (in response to my question about 1+i in relation to your definitions).[quote]This kind of addition can cope with adding items of different dimension. That is, to fit with the ϑ Dimension concept, I could define a complex number as an ordered pair, one of 0 dimension and one of dimension ϑ.[/quote]There may be other not-so-slight modifications.So, maybe this isn't the way to do it [if it is at all possible to do it "slightly"].As a possible guide to a better approach,this abstract discussion might be useful about what may be going on with regard to units (and dimensional analysis) in general:https://golem.ph.utexas.edu/category/2006/09/dimensional_analysis_and_coord.htmlIn an abstract sense, it seems that our physically-dimensionful formulasare mapping values from different spaces (somehow each associated with a "unit")into another space of values (with a unit consistent with the algebraic operations).
  33. haruspex says:
    [QUOTE="anorlunda, post: 5622971, member: 455902"]I normally associate dimensions with degrees of freedom, as in 3D space or 4D spacetime.A point-like particle can be described in 3D space with three coordinates.   An asymmetric object needs 3 coordinates, plus 3 angular rotations to describe it's position-orientation.  Aren't those rotations on an equal footing with translations as being dimensions?p.s. I normally eschew semantic discussions, but this one caught my fancy.  Nice thought provoking Insights article [USER=334404]@haruspex[/USER]”Thanks for the appreciation.That's really a different usage of the term dimension.  Dimensional analysis concerns what might be termed qualitative dimensions.  All lengths are qualitatively the same, so just L.  Area is different from length, but in a quantifiable way, as L[SUP]2[/SUP], etc.It is not just a semantic issue.  The ability to represent angles as a dimension slightly increases the power of DA.
  34. anorlunda says:
  35. haruspex says:
    [QUOTE="Stephen Tashi, post: 5622078, member: 186655"]I don't see arguments of the form "You can rewrite …" as having any bearing on question.”Then let me put it a different way.  In the post in which you brought up this issue, λ was the average number of events in a specific, fixed time interval, and the algebraic expression featured e[SUP]λ[/SUP].  It seems to me that this way of defining λ makes it a pure number, so dimensionless, so no problem.  It only becomes a problem if you then say, oh, but clearly it is really a rate, i.e. λ per that interval.  But if it is to be thought of as a rate then that is how it should appear in the equation, e[SUP]λt[/SUP].Otherwise, you could apply the same thinking to e.g. KE: 1/2 ms[SUP]2[/SUP], where s is the distance travelled per second.  Dimension=ML[SUP]2[/SUP].
  36. Stephen Tashi says:
    [QUOTE="haruspex, post: 5621999, member: 334404"]You don't need to assign units to either side of the f(x)= equation, they're dimensionless.  But you can rewrite the ##e^x## as ##e^{lambda x}## where ##lambda=1m^{-1}##.”In relation to issue of whether ##e^x## is an "error" in an equation describing a physical process when ##x## has a dimension:In the first place,   I don't see arguments of the form "You can rewrite …"  as having any bearing on question.   Yes, an equation representing a physical process can be transformed to an equation in dimensionless form, but that doesn't show the original form of the equation is invalid.Perhaps your complete thought is "Your original equation is wrong or meaningless and you should rewrite it as ….##. ##  In the example, I don't see that the original equation is wrong or meaningless in the sense of being uninterpretable or so ambiguous that a person doing in measurements in cm instead of meters couldn't figure out how to rewrite it as different equation ##g(y)## where ##y## has units of cm.    My equation may be wrong in the sense that the task of defining ##g(y)## can't be accomplished by the straightforward use of conversion factors.  That's a topic we should investigate!  Let's pursue your suggestion of stating the equation as  ##p = f(x) = C( 2 – e^{lambda x} ) ## where ##lambda## has units of ##m^{-1}##   and ##x## has units of ##m##.    Can we convert that equation to a formula ##p = g(y) ## where ##y## has units of cm by using conversion factors?To convert to cm, we must convert both ##lambda## and ##x## using the conversion factor (m/100 cm).  We have ##100 y   (cm) = x  (m) ## and ##lambda  (m^{-1}) = lambda  (100  cm)^{-1})##   So the equation converts to  ##p = g(y) = C(2 – e^{ frac{lambda}{100}100 y}) = C(2 – e^y)##   But the correct equation (for ##y## in cm) should be something like ##p = g(y) = C(2 – e^{frac{y}{100}}) ##.  I said "something like" that because we must change the value of ##C## from ##int_{0}^{ln(2)} {(2 – e^x)} dx ## to ##C_2 = int_0^{ln(200)} { ( 2 – e^{frac{y}{100}} ) } dy ## in order to normalize the probability distribution.   We also must convert the interval on which the equation applies from ##[0, ln(2)]## to ##[0, ln(200)]##.   Are we opposed to letting the function ##ln(.)## have an argument with a dimension?  If so, how can we justify converting ##ln(2)## to ##ln(200)## ?   A dimensionless constant like "C" or "2" can be converted to a different numerical value if it depends on several different dimensions.  For example  the "1" in F = (1)MA   can convert to a different constant if we don't use MKS units.  However, the only dimension that has been mentioned in this problem is length [L].   I don't see any way that a dimensionless constant that is define only in terms of lengths can be converted to a different numerical value by changing the unit of measure for length.In contrast to the above difficulties if we take the viewpoint that the ##x## in ##e^x## and the "2" in ##ln(2)## have dimension [L] length given in meters then the conversion from  meters to cm gives results we need, namely ##e^{frac{y}{100}}## and ##ln(200)##.From my point of view the probability density  function ##f(x)## is not dimensionless.   Like a linear density function for the density of physical mass, it represents "per unit length", so in my equation ##f(x)## has units of  (1/meter).    However, that consideration still leaves length as the only dimension represented in the equation.
  37. Demystifier says:
    [QUOTE="Krylov, post: 5621293, member: 571630"]Otherwise, I am afraid that your next question will be: "To which category of mathematics does it belong?" :wink:”It would be definitely algebra. :smile:
  38. Krylov says:
    [QUOTE="Demystifier, post: 5621249, member: 61953"]I have a related question for everybody. Does the dimensional analysis belongs to mathematics? Or should it be considered as a part of physics? Can the notion of dimension (like meter or second) make sense without referring to a physical measurement?”Preferably it belongs to physics. Otherwise, I am afraid that your next question will be: "To which category of mathematics does it belong?" :wink:
  39. Demystifier says:
  40. Stephen Tashi says:
    [QUOTE="haruspex, post: 5620803, member: 334404"]I'm sorry, I am not grasping your point.”Lets try this:  Suppose there is a random variable X , measured in meters, that has its density defined on interval ## [0,  ln (2) ] ## by  ##f(x) = C( 2 – e^{x}) ## where ##C## is the normalizing constant ##int_{ 0}^{ln (2)} {(2 – e^ {x})} dx##.   A experimenter who measures ##X## in centimeters can convert the above density function to the appropriate density for##X## when ##X## is measured in centimeters.     I agree that assigning units to the left and right hand sides of ##f(x) = C( 2 – e^{x})## is a confusing or impossible task.   But I don't agree that the ##e^x## in the equation implies that the equation describes a physically impossible situation or that it makes it impossible for a experimenter measuring X in different units to convert the above density to his system of measurement.
    • Derek Bolton says:
      You don't need to assign units to either side of the f(x)= equation, they're dimensionless.  But you can rewrite the ##e^x## as ##e^{\lambda x}## where ##\lambda=1m^{-1}##.
  41. haruspex says:
    [QUOTE="Stephen Tashi, post: 5620643, member: 186655"]But if I am stating an equation that describes a physical situation, I can't get away with giving an equation that applies to an unstated interval. Suppose the equation that fits my experimental data is  ##f(k) = frac{ (2.3)^k e^{-2.3}}{k!} ## and an experimenter attempts to duplicate my results.  He uses an interval of 10 seconds to define ##lambda##.  In order to compare his results to mine, he needs to know what interval I used.    He asks me and I tell him "My interval was 5 seconds long".   The version of my equation that he can check against his data is ##f(k) = frac{(4.6)^k e^{-4.6}}{k!} ##.  Are we to say that this conversion of equations takes place by some method other than by converting units using conversion factors ?One may object: "You should have reported your equation in dimensionless form".   That would side-step the need to convert units.  However,  reporting results in dimensionless form isn't a requirement in science.”I'm sorry, I am not grasping your point.If the two experiments concern the same underlying process, presumably the rates should be the same.  Therefore the "correct" version of the equation would make λ that rate and have λt everywhere that your equation has just λ.  λt is dimensionless, as required.The version of the equation in your post #25 can be likened to rating the top speed of a car as the number of kilometres it can go in a standard interval of one hour.  That does not mean its speed has only a length dimension.
  42. Stephen Tashi says:
    [QUOTE="haruspex, post: 5620464, member: 334404"]In your Poisson example, yes.  λ was specified as the average number of events in some unstated but fixed interval. “But if I am stating an equation that describes a physical situation, I can't get away with giving an equation that applies to an unstated interval.  Suppose the equation that fits my experimental data is  ##f(k) = frac{ (2.3)^k e^{-2.3}}{k!} ## and an experimenter attempts to duplicate my results.  He uses an interval of 10 seconds to define ##lambda##.  In order to compare his results to mine, he needs to know what interval I used.    He asks me and I tell him "My interval was 5 seconds long".   The version of my equation that he can check against his data is ##f(k) = frac{(4.6)^k e^{-4.6}}{k!} ##.   Are we to say that this conversion of equations takes place by some method other than by converting units using conversion factors ? One may object: "You should have reported your equation in dimensionless form".   That would side-step the need to convert units.  However,  reporting results in dimensionless form isn't a requirement in science.
  43. haruspex says:
    [QUOTE="Stephen Tashi, post: 5620434, member: 186655"]does "fixing upon" an interval of 1 meter give different numerical results than fixing upon an interval of 1 kilometer ?”In your Poisson example, yes.  λ was specified as the average number of events in some unstated but fixed interval.  It was not the rate of events, so was indeed dimensionless.  If you change the interval (but keep the same process) then λ will change.[QUOTE="Stephen Tashi, post: 5620434, member: 186655"]Doesn't "varying" the interval require having some reference length stated in particular units to vary it from? If λ is dimensionless, then λt presumably has a dimension of time [T]”If you allow for different intervals then, as I posted, you must change the definition of λ to be a rate.  So λt is dimensionless.
  44. Stephen Tashi says:
    [QUOTE="atyy, post: 5620414, member: 123698"]I agree with Baluncore – angles are ratios, so they do not have a dimension.” If we consider an angle as some sort of physical object, it is more than a ratio.  For example, it has a vertex and sides.   According the book by A. Sonin,  a dimension is a property of an object.  There can be properties of an object that have "dimension 1", meaning that in manipulations with the dimension of that property we use "1" rather than [M],[L],[T] etc.   (So far, although thread participants are willing to take definite sides on the question of whether the particular property of angles that we measure in degrees has (or does not have) a dimension of 1 ,  nobody has ventured to state what the criteria are for something to be "a dimension" or what criteria determine whether a dimension must be "1".  So I'm still going by Sonin's book even though I find it unclear on the mathematical axioms.)
  45. Stephen Tashi says:
    [QUOTE="haruspex, post: 5620421, member: 334404"]That is because some interval has been fixed upon”But what would we mean by "fixed upon"?   If we are doing a physics problem, does "fixing upon" an interval of 1 meter give different numerical results than fixing upon an interval of 1 kilometer ?   If someone determines an equation with a given ##lambda## applies when the units of length are meters, shouldn't we be able to to deduce what equation applies when the units of length are kilometers by the usual conversion of units ?   “If you want to vary the interval you can make λ a rate:  ##f(k, t) = frac{ (lambda t)^k e^{-lambda t}}{k!}##”  Doesn't "varying" the interval require having some reference length stated in particular units to vary it from?   If ##lambda## is dimensionless, then ##lambda t## presumably has a dimension of time [T].
  46. haruspex says:
    [QUOTE="robphy, post: 5618407, member: 9587"]If i carries units, is there any meaning to (say) 1+i?”The + in 1+i is a different beast from that in 1+1.  The 1 and the i retain their separate identities.  That we write the sum of a real and an imaginary that way is mere convenience.  We could instead have the notation <x,y> to represent complex numbers.  Addition would be just like vectors, but a unique rule for multiplication.So the fact that we write 1+i creates no diffiiculty.  This kind of addition can cope with adding items of different dimension.  That is, to fit with the ϑ Dimension concept, I could define a complex number as an ordered pair, one of 0 dimension and one of dimension ϑ.
  47. haruspex says:
    [QUOTE="atyy, post: 5620414, member: 123698"]angles are ratios”As I thought I showed, you can think of them as fractions of a standard angle, but that does not make them ratios.Baluncore's argument could equally well be applied to masses: All masses can be thought of as a fraction of a standard kilogram mass.  If that makes it a ratio then masses are dimensionless.
  48. haruspex says:
    [QUOTE="Stephen Tashi, post: 5620356, member: 186655"]Is it also an error to have a term ##e^c## where c is a constant with dimensions?The Poisson distribution has density  ##f(k) = frac{ lambda^k e^{-lambda}}{k!}## where ##lambda## is "The average number of events in the interval".   So I assume ##lambda## has a dimension since "the interval" might mean 1 second or 1 hour etc..   How are the dimensions going to work out in that formula? .”That is because some interval has been fixed upon, making λ purely a number.  If you want to vary the interval you can make λ a rate:  ##f(k, t) = frac{ (lambda t)^k e^{-lambda t}}{k!}##
  49. Stephen Tashi says:
    “If you ever find you have an equation of the form ##e^x## where ##x## has dimension, you can be pretty sure you have erred.[QUOTE="Drakkith, post: 5620278, member: 272035"]I was not aware of this fact. Very interesting.””Is it also an error to have a term ##e^c## where c is a constant with dimensions?The Poisson distribution has density  ##f(k) = frac{ lambda^k e^{-lambda}}{k!}## where ##lambda## is "The average number of events in the interval".   So I assume ##lambda## has a dimension since "the interval" might mean 1 second or 1 hour etc..   How are the dimensions going to work out in that formula?  Oh well, maybe the whole idea of probability is an error –  God doesn't play dice etc.
  50. Drakkith says:
    [quote] Raising a dimensioned entity to a power is fine, because we can still express the dimensions of the result.  For other functions, such as exp, log and trig functions, it is more problematic.  If you ever find you have an equation of the form ##e^x##, where ##x## has dimension, you can be pretty sure you have erred.[/quote]I was not aware of this fact. Very interesting.
  51. haruspex says:
    [QUOTE="Stephen Tashi, post: 5620006, member: 186655"]It's interesting to consider the distinction between a mathematical definition of a function and a physical definition of a function.   To define ##sin(theta)## mathematically (i.e. a mapping from real numbers to real numbers)  one would have to unambiguously answer questions like "What is ##sin(0.35)##?" without any discussion of "units of measure" – e.g. 0.35 deg vs 0.35 radians.  From a mathematical point of view,  ##sin(theta  deg)## and ##sin(theta  radians)## are different functions, even though we use the ambiguous notation ##sin(theta)## to denote both of them.  Only the family of trig functions where ##theta## is measured in radians satisfy mathematical laws like ##D sin(theta) = cos(theta)##.To give a physical law in the form of a function we may do it by assuming certain units of measure. Then it is assumed that changing the units of measure appropriately produces a new mathematical function which states the same physical law.  So a physical definition of a function defines a set of different mathematical functions that are regarded as physically equivalent.The physical definition of ##sin(theta)## defines  a set of different, but physically equivalent mathematical functions.”Yes, I think that is why I have never been satisfied with the view that angles are utterly dimensionless.[QUOTE="robphy, post: 5619841, member: 9587"]Which circle are you referring to?”Whatever circle Baluncore had in mind.[QUOTE="robphy, post: 5619841, member: 9587"]At this stage, my question of the consistency of "1+i" in post 2 stands out as still unresolved, despite your reply in post 5.”I haven't forgotten this.  I want to take a look at the Brownstein article first.
  52. robphy says:
    [QUOTE="Stephen Tashi, post: 5619988, member: 186655"]Let me see if I understand you viewpoint.In the PDF linked in the Insight and post #10, the author, A. Sonin,  makes a distinction among:1) A physical object or phenomena (e.g. a stick)2) A "dimension", which is a property of a physical object or phenomena (e.g. length)3) A "unit of measure", which is a way to quantify a dimension (e.g. meters)The author is careful to point out that a "dimension" is not a physical phenomena.  It is a property of a physical phenomena.You describe "an angle" in mathematical terms, but since you say an "angle" can have various properties, I think you mean an "angle" to denote a physical phenomena, which is alternative 1)…[snip]…”I didn't read the PDF. So, I can't answer your questions using that author's distinctions.I think the bottom line here is: clearly define terms, especially when one is trying to change definitions.
  53. Stephen Tashi says:
    [QUOTE="haruspex, post: 5618575, member: 334404"]Not if you redefine trig functions as taking arguments of dimension Θ, as I did.”It's interesting to consider the distinction between a mathematical definition of a function and a physical definition of a function.   To define ##sin(theta)## mathematically (i.e. a mapping from real numbers to real numbers)  one would have to unambiguously answer questions like "What is ##sin(0.35)##?" without any discussion of "units of measure" – e.g. 0.35 deg vs 0.35 radians.  From a mathematical point of view,  ##sin(theta  deg)## and ##sin(theta  radians)## are different functions, even though we use the ambiguous notation ##sin(theta)## to denote both of them.  Only the family of trig functions where ##theta## is measured in radians satisfy mathematical laws like ##D sin(theta) = cos(theta)##.To give a physical law in the form of a function we may do it by assuming certain units of measure. Then it is assumed that changing the units of measure appropriately produces a new mathematical function which states the same physical law.  So a physical definition of a function defines a set of different mathematical functions that are regarded as physically equivalent.The physical definition of ##sin(theta)## defines  a set of different, but physically equivalent mathematical functions.
  54. Stephen Tashi says:
    [QUOTE="robphy, post: 5619952, member: 9587"]  Before somehow specifying an angle-measure, one could talk about all sorts of properties of angles at this stage. Then, when introducing an angle-measure, it probably should be explicitly defined—maybe operationally.””But all of this "angle-measure" discussion is distinct from the "angle" discussion in the previous paragraph.”Let me see if I understand you viewpoint. In the PDF linked in the Insight and post #10, the author, A. Sonin,  makes a distinction among:1) A physical object or phenomena (e.g. a stick) 2) A "dimension", which is a property of a physical object or phenomena (e.g. length)3) A "unit of measure", which is a way to quantify a dimension (e.g. meters)The author is careful to point out that a "dimension" is not a physical phenomena.  It is a property of a physical phenomena.You describe "an angle" in mathematical terms, but since you say an "angle" can have various properties, I think you mean an "angle" to denote a physical phenomena, which is alternative 1)When you say "angle measure", I'm not sure whether you mean alternative 3) or alternative 2).  But does alternative 3) (units of measure)  make any sense without the existence of alternative 2) (dimension) ?As I mentioned previously,  I haven't yet seen a precise statement of what mathematical or physical properties a "dimension" must have.   I don't know whether other thread participants agree with those listed by A. Sonin.  In regards to "dimensionless ratios",  a dimensionless ratio can associated with a property of a physical object.  Different dimensionless ratios can be associated with different properties (e.g. height of a person/ length of that persons right leg,  weight of a person now / weight of that person at birth).     "Dimensionless ratios" can obviously be quantified.    So it is rather confusing to consider the question of whether a "dimensionless ratio" is (or isn't) a associated with a "dimension".
  55. robphy says:
    [QUOTE="Stephen Tashi, post: 5619931, member: 186655"]You could also ask "The unit circle with center (0,0)?  The unit circle with center (15,12)?"You have to use a circle with its center at the vertex of the angle, so the measurement process isn't really independent of which circle is used unless we think of  "a circle" as a portable measuring instrument, just as we think of a meter stick as portable measuring instrument.[snip][/quote]Yes, but I didn't think I had to make further clarification on this. Shall we bring up issues of parallel transport on a non-Euclidean space as well?I would hope that when one says "arc-length divided by radius" that the rest of this is assumed.[quote][snip]I agree.  It's the distinction between "a dimension" (e.g. length) and "a unit of measure" (e.g. meters).”My distinction is this… If two lines (or two segments) meet at a point, then one can talk about the angle [or an angle] at the location where the two lines meet, labeled by the vertex (call it) C or that vertex with a two points, one on each segment–like ACB.  Before somehow specifying an angle-measure, one could talk about all sorts of properties of angles at this stage. Then, when introducing an angle-measure, it probably should be explicitly defined—maybe operationally.Given two lines (or line segments) meeting at a point, one could define an angle-measure the usual way (essentially with a circular protractor, appropriately calibrated in the likely possibility that protractors have different radii), or maybe in a different way (e.g. https://mathnow.wordpress.com/2009/11/06/a-rational-parameterization-of-the-unit-circle/ ) although it might not give your angle-measure the desired properties of additivity, or maybe using a hyperbolic-protractor (as one might use in special relativity). Issues of "units of angle-measure" come into play here. But all of this "angle-measure" discussion is distinct from the "angle" discussion in the previous paragraph.
  56. Stephen Tashi says:
    [QUOTE="robphy, post: 5619841, member: 9587"]Which circle are you referring to?The unit circle? Or maybe the circle of radius 7?”You could also ask "The unit circle with center (0,0)?  The unit circle with center (15,12)?"”One feature of the angle measure (defined as the ratio of circular-arc-length to radius) is that it is independent of the circle used to make that measurement.  “You have to use a circle with its center at the vertex of the angle, so the measurement process isn't really independent of which circle is used unless we think of  "a circle" as a portable measuring instrument, just as we think of a meter stick as portable measuring instrument.If we have an object that moves along a path, to measure the property of the path called its "total length" with a meter stick, we have to move the meter stick to various locations on the path.  If we are dealing with an object moving in a circular path and want to measure a property of the path called the "total angle swept out", we may need a measuring instrument that can produce results greater than 360 deg.  Such a measuring instrument could involve a circle, but it would have to have the added feature of keeping track of arc lengths greater than ##2pi##.”In this general discussion, one needs to distinguish an "angle" from an "angle measure".”I agree.  It's the distinction between "a dimension" (e.g. length) and "a unit of measure" (e.g. meters).
  57. Stephen Tashi says:
    [QUOTE="Baluncore, post: 5619648, member: 447632"]Polynomials and dimensions are incompatible. Transcendental functions that are approximated by polynomials must have dimensionless inputs and outputs.”I'm curious why you say that polynomials are incompatible with dimensions.  Coefficients of different powers of x in a polynomial can be assigned different dimensions, so that each power of x is converted to the same dimension.If we have an equation that describes a dimensioned physical quantity as a power series, aren't we assigning different dimensions to each coefficient in the power series ?
  58. robphy says:
    [QUOTE="haruspex, post: 5619650, member: 334404"]A ratio can have no dimension since it must be a ratio of two things of the same dimension.  But at an angle is not a ratio.  You can say it is a certain fraction of a complete circle, but whether that has dimension depends on whether you consider the complete circle as having a dimension.  You are not used to thinking of it that way, but that does not mean it cannot be done.”Which circle are you referring to?The unit circle? Or maybe the circle of radius 7?One feature of the angle measure (defined as the ratio of circular-arc-length to radius) is that it is independent of the circle used to make that measurement.In this general discussion, one needs to distinguish an "angle" from an "angle measure".Certainly, you can try to make definitions… but they have to lead to a consistent system.At this stage, my question of the consistency of "1+i" in post 2 stands out as still unresolved, despite your reply in post 5.
  59. haruspex says:
    [QUOTE="Baluncore, post: 5619648, member: 447632"]Angles are ratios, parts of a circle.”A ratio can have no dimension since it must be a ratio of two things of the same dimension.  But at an angle is not a ratio.  You can say it is a certain fraction of a complete circle, but whether that has dimension depends on whether you consider the complete circle as having a dimension.  You are not used to thinking of it that way, but that does not mean it cannot be done.[QUOTE="Baluncore, post: 5619648, member: 447632"]Polynomials and dimensions are incompatible.”Not if the dimension has the unusual property that it becomes dimensionless when raised to some finite power.  The ϑ[SUP]2[/SUP]=1 axiom means that a polynomial function of an angle is fine if all the terms are even powers (dimensionless result) or all odd powers (result of dimension ϑ).
  60. Baluncore says:
    Angles are ratios, parts of a circle. Neither angles nor ratios have a dimension.Polynomials and dimensions are incompatible. Transcendental functions that are approximated by polynomials must have dimensionless inputs and outputs.
  61. Stephen Tashi says:
    It would be nice to have a list of what axioms a "dimension" must satisfy.  Until that is available, arguments about what is or isn't a dimension are going to be personal opinions.A convenient online reference for dimensional analysis is http://web.mit.edu/2.25/www/pdf/DA_unified.pdf.   However, I don't know whether the axioms stated in that work are standard – or appropriate.For sake of discussion, consider what p10-11 of that book says about dimensions.  It says that there must be an operation of comparison and an operation of addition defined on the dimension.    All sorts of familiar ambiguities and confusions arise with angles because their "wrap-around" feature – e.g. is  360 degrees "equal" to zero degrees?  Does the sum ##pi## radians + ##pi## radians have a unique answer ?  – i.e. are ##2pi## radians and zero radians physically distinct ?    If we assume there is an "addition" is defined for dimensions, are we assuming (as we do in mathematics) that a sum is unique ?Page 11 postulates that  physical dimension must admit an ordering:”the concept of larger and smaller for like quantities (if there exists a finite B such that A+B=C then C > A)”To me, this is troublesome assumption for any dimension (including mass, length, time) where we wish to give a negative quantity a physical interpretation.    For example, is " – 10 meters"  a physical quantity ?  If we consider "-10 meters" a finite physical quantity  then the above assumption lets us conclude things like  15 meters + (-10 meters) = 5 meters,  so  15 meters < 5 meters.The topics of "changing units" and "changing coordinates" are usually treated as different subjects.  Are they really different concepts ?  Sometime as  "change of units" can involve more than mutiplying by a factor (e.g. converting degrees centigrade to degrees Kelvin).     In a  coordinate system for a "thing" it is permissible for the same thing to have several sets of different coordinates.   Does saying something is a "dimension" imply that there exists a coordinate system for measuring it where each distinct description in coordinates represent a different physical situation ?
  62. haruspex says:
    [QUOTE="Ygggdrasil, post: 5618633, member: 124113"]I guess I don't get the point of trying to give angles a dimension.  Angles are defined as a ratio (arc length : circumference) which is a dimensionless quantity and seems fundamentally different than something like mass.”Fair question.I have always found it a bit unsatisfactory that some quite different pairs of physical entity are dimensionally indistinguishable.  I mentioned some in the post.  There seemed to be something distinct about rotational entities, such as angular momentum, that was not captured by DA.As regards utility, as I showed in the table, it can be added to normal DA for an extra bit (literally) of information.
  63. Ygggdrasil says:
    [QUOTE="haruspex, post: 5618594, member: 334404"]I don't understand your point.  They are normally considered dimensionless anyway; I'm looking for a way to give them dimension. Would thinking of all masses as fractions of 1kg make mass dimensionless?”I guess I don't get the point of trying to give angles a dimension.  Angles are defined as a ratio (arc length : circumference) which is a dimensionless quantity and seems fundamentally different than something like mass.
  64. haruspex says:
    [QUOTE="Ygggdrasil, post: 5618591, member: 124113"]Angles can be defined as dimensionless quantities if one thinks of them as fractions of a circle (multiplied by the constant 2π).”I don't understand your point.  They are normally considered dimensionless anyway; I'm looking for a way to give them dimension.  Would thinking of all masses as fractions of 1kg make mass dimensionless?
  65. haruspex says:
    [QUOTE="robphy, post: 5618407, member: 9587"]What is the justification of the claim: "The cross product operator also has dimension Θ"?”That is not a claim, it is part of the definition of Θ.[QUOTE="robphy, post: 5618407, member: 9587"]If i carries units, is there any meaning to (say) 1+i?”I'm not especially attached to the part relating to i.  It is independent of the rest and probably needs more thought.  There might be a way around the 1+i problem similar to how I resolved s = rθ, i.e. one would have to agree to treating complex algebra in a slightly different way.[QUOTE="robphy, post: 5618407, member: 9587"]Note: in exp (x), the x must be dimensionless”That's why I assigned i the dimension Θ, to make iθ dimensionless.[QUOTE="robphy, post: 5618409, member: 9587"]You might be interested in this old article from the American Journal of Physics.http://scitation.aip.org/content/aapt/journal/ajp/65/7/10.1119/1.18616"Angles—Let’s treat them squarely" by K. R. Brownstein”That sounds very much as though it is not a new idea, which is at once heartening and disappointing.  Thanks for the reference.[QUOTE="A. Neumaier, post: 5618432, member: 293806"]Angles have the dimension of 1. That this is a true dimension”By definition, real numbers are dimensionless, so I do not understand what you mean by saying it is a true dimension.  Indeed, the fact that angles have units but not dimension is somewhat awkward, as I mentioned in the article.[QUOTE="A. Neumaier, post: 5618432, member: 293806"]for s=sinθ to make sense, the dimension of θ must be 1.”Not if you redefine trig functions as taking arguments of dimension Θ, as I did.
  66. Arnold Neumaier says:
    Angles have the dimension of 1. That this is a true dimension can be seen from the fact that one measures angles in different units , namely either degrees or radians, and they convert into each other just like units for other dimensional quantities. Your ##\Theta## doesn't make sense unless it equals ##1## since for ##s=\sin\theta## to make sense, the dimension of ##\theta## must be ##1##.
Newer Comments »
