Fermat's Last Theorem
Fermat’s Last Theorem
📖Read Time: 13 minutes
📊Readability: Easy (6th-7th grade)
🔖Core Topics: proof, theorem, case, numbers, number
Abstract
Fermat’s Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation
a^n+b^n=c^n
has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy
“Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et generaliter nullam in infinitum ultra quadratum potestatem in duas ejusdem nominis fas est dividere: cujus rei demonstrationem mirabilem sane detexi. Hanc marginis exiguitas non caperet.”
“It is not possible, however, to decompose a cube into two cubes, or a biquadrate into two biquadrates, and in general, to decompose a power higher than the second into two powers with the same exponent: I have discovered a truly wonderful proof for this, but this margin is too narrow to grasp here.”
which has been found after his death. Everybody understands the problem statement, however, it turned out to be extraordinarily difficult to solve, and nobody today assumes that Fermat had actually found a proof for the general case. For example,
6^3+8^3=9^3-1,
is almost a solution for the cubic case. Imagine how many natural numbers we have to rule out as possible solutions. Numbers we cannot even write down in a lifetime. Such considerations aren’t even evidence in number theory since exceptions can always occur, but it shows the principal difficulty of any proof of negative results. Non-existence is hard to prove.
Both aspects of the story – the simplicity of the statement and Fermat’s provocative remark – were a blessing as well as a curse. A blessing because, during the 350 years it took before Andrew Wiles and Richard Taylor succeeded in providing a complete proof in 1994, extraordinary developments in mathematics were initiated in the effort to prove the statement, especially in number theory, abstract algebra, class field theory, and the theory of elliptic curves. Its curse, however, lies in the fact that to this day, even after the more than 100-page solution to the problem, full of elaborate mathematics, laypeople still attempt to prove the theorem using simple means. It’s safe to say that such attempts are doomed from the start. This article aims to shed light on why this is the case.
The Simple Cases
It is immediately clear from a pure inspection of the equation
a^n+b^n=c^n
that ##a,b,c## may be assumed to be coprime, and that ##n=1## isn’t an issue. Setting
a=u^2-v^2\, , \,b=2uv\, , \,c=u^2+v^2
with arbitrary integers ##u >v>0## gives possibly not coprime solutions for ##n=2.## They are called Pythagorean triples. Pythagorean triples with coprime elements are called primitive. Many of them have been found on the Babylonian cuneiform tablet Plimpton 322 [6], dating back to 1800 BC, which strongly suggests that the Babylonians already knew this building rule. The first explicit occurrences that we know of are in Euclid’s Elements (300 BC) and by Brahmagupta (600 AD) in India. The crucial point is that all solutions for ##n=2## are Pythagorean triples.
If we divide the equation ##a^2+b^2=c^2 ## by ##c^2## then we get the equation of a unit circle where we are looking for its rational points. The Weierstraß substitution ##t=\tan(\alpha/2)## leads to
\left(\dfrac{a}{c}\, , \,\dfrac{b}{c}\right)=(\cos \alpha\, , \,\sin \alpha)=\left(\dfrac{1-t^2}{1+t^2}\, , \,\dfrac{2t}{1+t^2}\right)\in \mathbb{Q}^2
The first coordinate says that ##t^2\in \mathbb{Q},## and then the second says ##t\in \mathbb{Q}.## Hence ##t=u/v## and
\left(\dfrac{a}{c}\, , \,\dfrac{b}{c}\right)=\left(\dfrac{1-t^2}{1+t^2}\, , \,\dfrac{2t}{1+t^2}\right)=\left(\dfrac{u^2-v^2}{u^2+v^2}\, , \,\dfrac{2uv}{u^2+v^2}\right).
It is somehow surprising that this result for squares doesn’t generalize to squares of squares. If the equation for ##n=4## is solvable, then
a^4+b^4=c^4=(c^2)^2=d^2
is solvable, too, i.e. ##\left(a^2=u^2-v^2,b^2=2uv,d=u^2+v^2\right)## is a Pythagorean triple which we may assume to be primitive, implying that ##u## and ##v## are of distinct parity. Since
a^2=u^2-v^2=(2r)^2-(2s+1)^2 \equiv 3\pmod{4}
is not possible because all squares are congruent ##0## or ##1## modulo ##4,## we know that ##u## is odd and ##v## is even, say ##v=2s.## As ##u,v## are coprime and ##u## is odd, so ##u,s## are also coprime, and ##us=uv/2=b^2/4## implies that ##u,s## are squares, i.e. ##u=x^2,s=y^2## with positive integers ##x,y## and ##x## odd. With
a^2+(2y^2)^2=u^2-v^2+(2s)^2=u^2=(x^2)^2,
we get another primitive Pythagorean triple ##(a,2y^2,x^2)## so, once more, we get a representation ##(a=\overline{u}^2-\overline{v}^2,2y^2=2\overline{u} \,\overline{v},x^2= \overline{u}^2+ \overline{v}^2)## with coprime positive integers ##\overline{u},\overline{v}.## By the same argument as above using primitivity, we may conclude that ##\overline{u},\overline{v}## are squares, say ##\overline{u}=\overline{x}^2## and ##\overline{v}=\overline{y}^2.## Thus
\overline{x}^4+\overline{y}^4=x^2
where ##x\leq x^2 =u\leq u^2<u^2+v^2=d.## This means that we have found an equation of the same form as our original one with a strictly lesser right-hand side. This cannot infinitely go on since the positive integers are bounded from below, i.e., our assumption of an existing solution was wrong, proving the case ##n=4.##
Not only that the case ##n=2## not generalize to the case ##n=4,## we even made wide use of solutions for ##n=2## to disprove the existence of solutions for ##n=4.## Assuming a minimal solution, finding an even smaller solution, and thus generating a contradiction, is a standard proof technique in the domain of natural numbers since they are bounded from below. A geometric proof can be found in [2]. It shifts the cumbersome zoo of variables into the statement that the area of a right triangle with integer side lengths is never a square number, and the useful observation that the integer equation system
x^2+y^2=z^2\text{ and }x^2-y^2=w^2
cannot be solved. It is the proof that is assumed to be known to Fermat [4].
The proof for the case ##n=3## is even more complicated but basically along the same lines of assuming a minimal solution, considering congruences of now Eisenstein numbers, i.e. numbers of the form ##\mathbb{Z}+\mathbb{Z}\cdot e^{2\pi i/3}##, and divisibility; for details, see [1]. Leonhard Euler (1707-1783) published proofs for both cases. For the case ##n = 4##, at least ##20## different proofs have been found. At least ##14## different proofs exist for ##n = 3.##
a^{rs}+b^{rs}=c^{rs} \Longleftrightarrow (a^r)^s+(b^r)^s=(c^r)^s
So if there are no solutions for ##n=s## then there are no solutions for ##n=rs.## Hence, it is sufficient to show that there are no solutions for ##s=4## and all odd primes ##s## because every positive integer greater than two has either an odd prime as a divisor or is divisible by four. This leaves us with the case of odd primes ##n=p.##
In 1825, Adrien-Marie Legendre (1752–1833) and, independently of him, the young Peter Gustav Lejeune Dirichlet (1805–1859) succeeded in proving the Fermat conjecture for the exponent ##n = 5.## In 1839, Gabriel Lamé (1795–1870) followed with a proof for the exponent ##n = 7.##
The Three Worlds
We have solved the cases ##n=2,4,## and the case ##n=3## already required the introduction of certain concepts of abstract algebra, Eisenstein numbers.
The hope expressed by Cauchy and Lamé in 1847 for a quick (and general) proof was dashed, however, by Ernst Eduard Kummer, who discovered a logical error in Lamé’s and Cauchy’s considerations: They had tacitly, and falsely assumed that in the entire closure of integers of the extension fields of rational numbers they considered (cyclotomic fields of order ##p,## which arises from the adjunction of the ##p##-th roots of unity), the unique prime factorization still holds.
Kummer developed a theory in which the unique prime factorization could be salvaged by combining certain sets of numbers from the number field (ideals) and investigating the arithmetic of these new “ideal numbers.” He was thus able to prove Fermat’s Last Theorem for regular prime numbers in 1846. A prime number ##p## is called regular if no numerator of the Bernoulli numbers ##B_0, B_2,\ldots B_{p-3}## is divisible by ##p.## In this case, the class number, i.e., the number of non-equivalent ideal classes of the cyclotomic field of order ##p## is not divisible by ##p.## However, it is not known whether there are infinitely many regular prime numbers. With the help of computers and by further developing Kummer’s methods, Harry Vandiver succeeded in proving the theorem for all prime numbers less than 2,000 in the early 1950s. [5]
Thus, until the beginning of the 1980s, it remained essentially a matter of refinements to Kummer’s work, and after computer technology had improved more and more, numerical verifications of the Fermat conjecture; for example, in 1976, Wagstaff proved that Fermat’s conjecture was correct for prime exponents smaller than 125,000. [3]
This demonstrates several phenomena that are typical of Fermat’s Last Theorem. First, even the greatest mathematicians sometimes make mistakes, and even Wiles’s first draft of the proof was flawed. Second, one suddenly and quickly finds oneself in algebraic realms where new concepts are required and specialized terminology is indispensable, even for partial results.
We will briefly outline this complexity along Kramer’s presentation in [3]. He coined the term of the three worlds to describe the progress in different areas, trying to prove Fermat’s Last Theorem. In a way, we already met them: the non-existence character of the statement, elliptic curves like ##y^2=x^3-1## that lead to ##e^{2\pi i /3},## and generalized divisibility considerations, modules.
The Anti-Fermat World …
… outlines the path to a proof. We want to show that there is no solution, and the only way we can do this is to assume the existence of a solution and derive a contradiction; simply because we cannot test all infinitely many possibilities. We have seen that we can make a few assumptions, such as coprime ##a,b,c,## and ##n=p## being an odd prime greater than ##7,## and eventually impose some kind of minimality of a solution due to the lower bound of positive integers. Many partial results for certain exponents and certain bases have been found, e.g., in the case where ##p\nmid a,b,c.## Subclasses of the problem statement simply mean that people used additional properties and therewith additional constraints and equations to approach the problem. However, the union of all these results never exhausted the entire problem within 350 years of attempts prior to Wiles’ proof. The union of all subclasses remained a proper subset of all cases. It should be noted that the exhaustion method is not an alternative to the contradiction method. In fact, it is merely a different perspective since the contradiction method does the same: excluding cases so that more equations can be used to finally arrive at a contradiction. The case ##n=4## was such an example since it widely used the primitivity of Pythagorean triples. The restriction to odd primes is another such condition.
The Elliptic World
Every odd prime number is congruent ##1## or congruent ##3## modulo ##4.## This led already for ##n=3## into the consideration of elliptic curves, i.e., algebraic curves of the form
Y^2=X^3+A X+B
with integer coefficients ##A,B.## It turned out that the projective version of elliptic curves, i.e., the extension by the infinite points of these curves, with three pairwise different zeros of the cubic polynomial, their continuous deformations, and their images modulo ##p## played a central role in the examination of Fermat’s equation. It also automatically involves complex numbers. A big part of Wiles’ proof, and its prior partial results, deals with invariants of such algebraic varieties.
Elliptic curves occur naturally in the ancient congruence problem: Find to a given natural number ##M## all right triangles with rational side lengths and area ##M.## The solution to this problem uses the elliptic curve
Y^2=X^3-C^2X=X(X^2-C^2)=X(X-C)(X+C)
and results in ##a=\dfrac{X^2-C^2}{Y}\, , \,b=\dfrac{2CX}{Y}\, , \,c=\dfrac{X^2+C^2}{Y}.##
The similarity to Pythagorean triples is no coincidence.
The Modular World …
… deals with modular forms and moduli of algebraic curves. A modular form ##f## of weight ##k\in \mathbb{Z}## and level ##N## is a complex, meromorphic function of the upper complex plane ##\mathcal{H}=\left\{z\in \mathbb{C}\,|\,\operatorname{Im}(z)\geq 0\right\},## such that
f\left(\dfrac{\alpha z+\beta}{\gamma z+\delta}\right)=(\gamma z+\delta)^kf(z)
for all elements of the subgroup
\Gamma(N)=\left\{ \left. \begin{pmatrix}\alpha&\beta\\\gamma&\delta\end{pmatrix}\in \operatorname{SL}_2(\mathbb{Z})\, \right| \, \gamma\equiv 0\pmod{N}\right\} \leq \operatorname{SL}_2(\mathbb{Z}),
and that has a representation as
f(z)=\sum_{m=0}^\infty f_me^{2\pi i mz}.
A moduli space of algebraic curves in algebraic geometry is a geometric space (typically a scheme or an algebraic stack) whose points represent isomorphism classes of algebraic curves. Short: It is about topological surfaces and their genus, the number of their holes or handles. [7]
The modular world leads us directly into algebraic geometry with its own terminology, and we could ask what this has to do with Fermat’s Last Theorem. A look into the history of modular forms gives us a first insight.
The origins of the theory of modular forms go back to Carl Friedrich Gauß (1777-1855), who considered transformations of special modular forms under the modular group, the level in the context of his theory of the arithmetic-geometric mean in complex systems (1805). The founders of the classical (purely analytical) theory of modular forms in the 19th century are Richard Dedekind, Felix Klein, Leopold Kronecker, Karl Weierstrass, Carl Gustav Jacobi, Gotthold Eisenstein, and Henri Poincaré. A well-known example of the application of modular forms in number theory was Jacobi’s theorem about the representations of a number by four squares. The modern theory of modular forms emerged in the first half of the 20th century by Erich Hecke and Carl Ludwig Siegel, who pursued applications in number theory. [8]
The Bridges Between The Worlds
The proof of Fermat’s Last Theorem is now the path from one world to the next one, setting up a mathematical environment that provides tools, constraints, and further equations to finally derive a contradiction to an assumed solution. The transition from Fermat’s statement into an algebraic and topological environment turned out to be the key that embedded four numbers ##a,b,c,n## into a mathematical framework. We therefore need bridges between these worlds. The first bridge can be attributed to Gerhard Frey [9], the second bridge is Andrew John Wiles’ [10] great achievement.
We assume a solution to the equation
a^p+b^p=c^p
with coprime positive integers ##a,b,c,## and an odd prime ##p>5.## We next define an elliptic curve ##F##, a Frey curve with these data by
F\, : \,Y^2=X\left(X-a^p\right)\left(X+b^p\right)=X^3+\left(b^p-a^p\right)X^2-(ab)^pX.
Note that ##F## is an elliptic curve since the transformation ##X’=X+(b^p-a^p)/3## eliminates the quadratic term and ##F## is of the required form. Now it can be shown that
N_F=2\prod_{\substack{p \text{ prime}\\ p\,|\,abc\, , \,p\neq 2}} p
is an invariant of the Frey curve. Every Frey curve allows the definition of a modular form ##f_F## of level ##N_F## depending on its prime number ##p,## see definition 2.9 in [2] for details. Frey supposed in 1986, and Ken Ribet [11] has proven it in the same year, that the Frey curve would provide a counter-example to the Taniyama-Shimura conjecture about modular forms from 1958. The conjecture was proven in 2001 by Richard Taylor [12] and others after Wiles had provided the proof of the most important and difficult case of so-called semistable elliptic curves in 1994. This is our second bridge, the Taniyama-Shimura conjecture, now known as Modularity Theorem.
The Modularity Theorem and its proof are considered one of the great mathematical advances of the 20th century. Consequences of the modularity theorem include Fermat’s Last Theorem and the well-defined nature of the Birch-Swinnerton-Dyer conjecture, since the modularity theorem guarantees an analytic continuation of the L-function associated with an elliptic curve. Today, the Modularity Theorem is considered a special case of the much more general and important Serre conjecture on Galois representations. This conjecture was proven in 2006 by Chandrashekhar Khare, Jean-Pierre Wintenberger, and Mark Kisin, building on the work of Andrew Wiles. [13]
Modularity Theorem
If ##F## is a Frey curve and ##f_F## its modular form of weight ##2## and level ##N_F## then
  1. $$
    f_F\left(\dfrac{\alpha z+\beta}{\gamma z+\delta}\right)=\left(\gamma z+\delta\right)^2 f_F\left(z\right)\text{ for all }\begin{pmatrix}\alpha&\beta\\\gamma&\delta\end{pmatrix}\in \Gamma(N_F)
  2. $$
    f_F\left(-\,\dfrac{1}{N_F \,z}\right)=\pm N_F \,z^2\, f_F(z)
holds for all ##z\in \mathcal{H}.##
Summary
There are essentially three things that are remarkable about Fermat’s Last Theorem. It took about 350 years for Wiles and Taylor to prove it finally, and shortly after Wiles’s publication, rumors circulated that at most a handful of other mathematicians worldwide could even understand the proof. Well, that may have changed. Nevertheless, countless mathematicians have striven for a proof over those 350 years. Quite a few of them were of the stature of brilliant scientists, such as Euler, Cauchy, Legendre, Dirichlet, Kummer, and finally Wiles. Until the late 20th century, partial results were achieved and published, not least thanks to the development of increasingly powerful computers. Moreover, the further development of many mathematical concepts and areas was required before a proof could be provided. And this form of mathematics is anything but simple and easily understandable. So if someone today believes they have found a “simple” proof, they would have achieved what mathematical luminaries have failed to achieve in 350 years. He would have also found a “simple” approach to all the profound results which were necessary to even understand the proof we have, or to obtain partial results. These three things – time, geniuses, and new mathematics – all of which were necessary to ultimately provide a proof would all seem unnecessary if someone were to find a “simple” proof. Such a scenario is extremely unlikely.
Sources
[1] Fermats großer Satz, Daniel Zachow, Freiburg 2020
[2] Modularität und Fermats letzter Satz, Christian Geyer, Kaiserslautern 2011
[3] Der große Satz von Fermat – die Lösung eines 300 Jahre
alten Problems, Jürg Kramer, Berlin
[4] Wikipedia, Pierre de Fermat
[5] Wikipedia, Großer Fermatscher Satz
[6] The Babylonian tablet Plimpton 322
[7] Wikipedia, Moduli of algebraic curves
[8] Wikipedia, Modulform
[9] Wikipedia, Gerhard Frey
[10] Wikipedia, Andrew Wiles
[11]Wikipedia, Ken Ribet
[12]Wikipedia, Richard Taylor (mathematician)
[13] Wikipedia, Modularitätssatz
  1. noelbcornerstone says:
    Two things have led directly from Fermat’s Last Theorem in my world.
    1. That maths as a language is not fit for purpose. Two things the same not being recognised, that’s a fundamental context free grammar problem which is fixable. L-functions are clearly not defined in a way that understands the underlying properties.
    2. That I have never seem the simple proof for Fermat’s Last Theorem be debunked if someone can help, as I believe this is what he had in the margin that for some reason everyone seems to have forgotten… here’s similar to what Fermat said…
    a^2 + b^2 = c^2
    Any integer that works for a higher power will be in the form above where we need to multiply by a power of c. And this covers all solutions if they exist, that started as the sum of two squares.
    We then have another simple equation which covers ALL other integers…
    a^2 + b^2 = c^2 + k
    This covers all other integers. If we subtract k from the right hand side, we would need to multiply both sides by one or more powers of c to get a result that contradicts the conjecture. This is also EASY to prove.
    So, can anyone tell me why this is harder than the above which came apparently from Fermat at the time?
  2. Aric8800 says:
    Vportal.me is your ultimate destination for smart, accessible, and future-ready learning. Whether you’re a student aiming to excel in exams, a professional upgrading your skills, or simply someone who loves to learn VPortal.me has something for you. With expertly crafted lessons, interactive tools, and a user-friendly experience, our platform turns complex topics into clear, engaging content. Learning is no longer a task it’s a journey, and VPortal.me is here to guide you every step of the way.
