Menu
Home
Action
My entries
Defined browse
Select
Then Select
Then Select
Search
finite field
Definition/Summary
All finite fields are known; they are the Galois fields GF(p^n), where p is a prime.
They have addition group Z(p)^n and multiplication group Z(p^n-1); their multiplication groups are cyclic.
If p = 2, then addition and multiplication can be done very fast by typical computer hardware using bitwise exclusive or and shifting.
Equations
Scientists
Évariste Galois
Recent forum threads on finite field
Breakdown
Mathematics
> Algebra
>> Field Theory
See Also
Images
Extended explanation
The finite fields GF(p) are {0, 1, ..., p-1} under addition and multiplication modulo p, which must be a prime number.
Finite fields GF(pn) for n > 1 can be described using polynomials in a variable x with coefficients having values in {0, 1, ..., p-1}.
Every element is a polynomial with a degree at most n-1.
Element addition is polynomial addition modulo p, while element multiplication is polynomial multiplication modulo p and a degree-n primitive or irreducible polynomial.
A primitive polynomial is one that cannot be factored in this construction of GF(pn). Primitive polynomials are not unique; there are
[itex]N(p,n) = \frac{1}{n} \sum_{m|n} \mu(m) p^{n/m}[/itex]
monic ones, where μ is the Möbius mu function. That function is (-1)number of prime factors if they all have power 1, and 0 otherwise.
A finite field GF(pn) has subfield GF(pm) if m evenly divides n. If n is a prime, then GF(pn) only has only the trivial subfields, itself and GF(p).
Commentary
